BostonMA
SQL Case statement within a case statement syntax problem
Im wondering if someone can look at this sql statement and tell me where my syntax is incorrect.
---This statement works
select
MonthTotal_Bucket1 = case when Date_ACTUALDATE = @PM_Comparison_StartDate then Amount1 else 0 end,
MonthTotal_Bucket1 = case when Date_ACTUALDATE >= @PM_Comparison_StartDate then Amount2 else 0 end
From Sales
blah blah
---This statement does not work. The error message is: "Incorrect syntax near '='."
Select
case when @productflag =1 then
else
MonthTotal_Bucket1 = case when Date_ACTUALDATE > @PM_Comparison_StartDate then Amount1 else 0 end
end
From Sales
blah blah
select
From Sales
blah blah
Select
else
end
From Sales
blah blah
Thanks guys, but neither of those worked.
The first one by gallitin, i got the message: "Incorrect syntax near the keyword 'set"
The second one by matthew, isnt what I was aiming for. I need the MonthTotal_Bucket1 to be calculated differently depending on what the value of this flag is. Let me write this isn psudeo code:
Select
Case when ProductFlag = 1 Then
MonthTotal_Bucket1 = case (criteria 1 current year date range)
MonthTotal_Bucket2 = case (criteria 1 current prior year date range)
MonthTotal_Bucket3 = case (criteria 1 current prior year-1 date range)
MonthTotal_Bucket4 = case (criteria 1 current prior year-2 date range)
MonthTotal_Bucket5 = case (criteria 1 current prior year-3 date range)
Else
MonthTotal_Bucket1 = case (criteria 2 current year date range)
MonthTotal_Bucket2 = case (criteria 2 current prior year date range)
MonthTotal_Bucket3 = case (criteria 2 current prior year-1 date range)
MonthTotal_Bucket4 = case (criteria 2 current prior year-2 date range)
MonthTotal_Bucket5 = case (criteria 2 current prior year-3 date range)
End
SO the output would look like the following everytime, except the values change in each column:
MonthTotal_Bucket1 MonthTotal_Bucket2 MonthTotal_Bucket3 MonthTotal_Bucket4 MonthTotal_Bucket5
100 48 4201 4524 1475
500 64 2451 1897 4517
75 487 748 1154 4156
Notice how the column name is the same, but the criteria used in calculating it changes based on the case statement...Does that make sense?
Select
Else
End
