Ctrl + alt + del problem in Remote control by RealVNC
Is anyone use RealVNC to remote control dedicated server here?
I got a question here. When I use VNC connect to my remoted dedicated server, which is based on windows 2003 standard version, I need use CTRL + ALT + DEL to active login username and password input field. But when I did that, those 3 keys only have effect on my local computer(windows task manager pop up!) not in remoted server.
What should I do? plz help~
Ahead thanks
Rocky
RockychnAsked:
booktopiaCommented:
Click the VNC icon in the op left and it will give you the option to send ctrl+alt+del
Hope this helps
RockychnAuthor Commented:
haha,  that's cool, I got it, thanks man, super fast response!!!! +++++
Remote Access
