HP DV2000 screen blurry and divided into 6 parts
HP DV2000 Pavilion laptop screen  is divided into 6 parts. The picture is blurry ans you can see 6 parts  on the screen. The system is Vista
I wonder what causes it. Is it a video card?
Many thanks
RemapAsked:
skywalker39Commented:
Hi Remap,
It's possible it could be a bad video card, have you tried going into Safe Mode? If you go into Safe Mode does it still occur? Have you tried updating the video card's drivers if there are any?
RemapAuthor Commented:
the screen is devided into 6 parts straight when you power it up. I do not see what is on this very well, hence can not get into safe mode. Could this is a faulty cable rather then a video card? I come across a similar problem, although the screen was divided into 8 parts.
Very well can be a faulty cable, if you wiggle the cable does the screen change?
Cloud Class® Course: Microsoft Azure 2017
Azure has a changed a lot since it was originally introduce by adding new services and features. Do you know everything you need to about Azure? This course will teach you about the Azure App Service, monitoring and application insights, DevOps, and Team Services.
dbruntonCommented:
Could be cable.  Could be bad settings for the monitor or the graphics card.
Boot in Safe Mode and set the display to VGA mode.  From there slowly adjust for higher resolutions and frequencies.
nobusbiljart fanCommented:
Here my troubleshooting procedure :
clean the system from dust, then  test with the minimum setup - disconnect also all peripherals and network cables :
motherboard + cpu + 1 ram stick, video card, 1 HDD, power supply keyb + mouse
verify that the 4-pin cpu Aux power plug is connected
on boot, do you have the problem ?
if yes it is one of the connected, swap ram, Power supply, video card or monitor - leaving only motherboard and cpu
if No, add devices till the problem shows
you can also check the motherboard for bad capacitors as shown here :   www.badcaps.net
The computer is a laptop. I can not do everything
true, but you can remove cd drive (or boot from cd and remove disk) etc...
