Loop while sound position is less than sound duration
I understand loops, I understand if statements, I even understand position and duration.  What I don't get is how to put them all together to create a single frame loop based on the position of a sound object.
My syntax makes sense to me but does not work.  And thanks again in advance for looking.
So this is what I got so far
// sets variable for sound
var soundObj:Sound = new Sound(this);
// controls sound in movie
paraSoundStart = function (a) {
	paraSoundStop();
	soundObj.attachSound(a);
	soundObj.start();
//the loop
i = soundObj.position;
t = soundObj.duration;
while (i<t) {
	if (i<t) {
		//stay on current frame
	} else {
		//advance to next frame
frankybonesAsked:
Aneesh ChopraCommented:
While loop runs all at once with in the framecode,
you need an event which can check after a timeInterval so that each code frame can get executed.
I updated your code and used "onEnterFrame" event,
Below is working code, just change "sound instance linkage ID"
stop();
	paraSoundStop();
	soundObj.start();
paraSoundStart("sound1");
//the loop
this.onEnterFrame = function(){
	var i = soundObj.position;
	var t = soundObj.duration;
	trace("i:"+i+" & t: "+t );
	if (i<t) {
	} else {
		// stop onEnterFrame loop
		delete this.onEnterFrame;
		gotoAndStop(this._currentframe+1);
frankybonesAuthor Commented:
wow...have i been black listed?
Thank you very much for your help.  It is greatly appreciated.
