Solved
Problem with DHCP not handing out IP on Sonicwall Wireless WLAN connections
Posted on 2009-05-04
I have a Sonicwal TZ170w and it was working just fine. Now all of a sudden, when I try to connect from "LAPTOP A" I can't. (Laptop B" works just fine. SO I tried a few things. (1) I disabled Wireless, changed hte WEP key, and re-enabled it several times to no avail. (2) I deleted and re-added the SSID to the perfered networks on Laptop A a dizen times to no avail. (3) I took the opportunity to switch from WEP to WPA/PSK TKIP. Laptop B continues to work just fine. When I change laptop A to use a static IP with the SSID, it works fine. But I can NOT get a DHCP IP address on laptop A !!! <argh>
Any help would be appreciated.
Thanks.
