Solved
Virtual Memory settings help required for 64bit XP
Posted on 2009-05-05
Last Modified: 2013-12-24
Can anyone advise me what the appropriate minimum and maximum virtual settings should be
for a 64 bit Computer with following specs.
Intel i7
12GB Ram,  Two  250 GB HDD's
Windows XP Professional version 5.2 Service Pack 2
Software installed Stata Version 10  data sets exceeding 7GB
Following  Info required please
Minimum and maximum virtual memory
Which box to tick   Custom size / System managed size / No paging file
for both  C:\  and D:\
Look forward to your advice
Ian
Question by:racepro
2 Comments
LVL 2
Accepted Solution
by:
FatManc earned 1500 total points
You have two options:
1. You can click on the System Managed Size option and let Windows managed the pagefile for you. This is the option most users would choose as you can just click and forget it.
2. If you want to manage the size yourself then click on Custom Size and make sure the maximum size is 3 times the amount of ram you have. In your case 36Gb.
I would select only one of the drives to store the paging file either C: or D:
Use whichever drive doesn't have the OS installed (so normally would be D:)
Using both will degrade performance.
Hope this helps
John
Author Closing Comment
by:racepro
Hi John
Thanks for this advice
After following your instructions by allowing Windows do it for me my settings now read
Minimum Allowed    16 MB
Recommended        15343 MB
Currently Allocated 10229 MB
Hope this sounds right and thanks again
Ian
VIDEO: THE CONCERTO CLOUD FOR HEALTHCARE
Modern healthcare requires a modern cloud. View this brief video to understand how the Concerto Cloud for Healthcare can help your organization.
Today, still in the boom of Apple, PC's and products, nearly 50% of the computer users use Windows as graphical operating systems. If you are among those users who love windows, but are grappling to keep the system's hard drive optimized, then you s…
In the modern office, employees tend to move around the workplace a lot more freely. Conferences, collaborative groups, flexible seating and working from home require a new level of mobility. Technology has not only changed the behavior and the expe…
The purpose of this video is to demonstrate how to create a Printer Friendly PDF on a WordPress Page. This will be demonstrated using a Windows 8 PC. Tools Used are Photoshop, Awesome Screenshot” Google Chrome Extension, and SmallPDF.com Log…
The purpose of this video is to demonstrate how to Test the speed of a WordPress Website. Site Speed is an important metric of a site’s health. Slow site speed can result in viewers leaving your site quickly and not seeing your content. This…
Suggested Courses
Course of the Month15 days, 11 hours left to enroll
580 members asked questions and received personalized solutions in the past 7 days.
Join & Ask a Question
