Prysson
Help with SQL view using SUM(CASE WEHN
Ive got a series of three table
tbl_cc
tbl_heir
tbl_join_cc_hier
column in the tables are simple
tbl_cc
col1 = cc_id int identiy true
col2 = cc varchar
tbl_heir
col1 = heir_id int identity true
col2 = heir
tbl_join_cc_heir
col1 = join_id int identity true
col2 = cc_id int (FK Constarint to tbl_cc.cc_id)
col3 = heir_id int (FK Constraint to tbl_heir.heir_id)
col4 = heir_cc_id int (FK constraint with tbl_cc.cc_id)
tbl_cc are const centers
tbl_heir contains heirarchy levels (there are only 6 levels)
Basically I have a table of cost centers.
and a heirarchy table
All of the cost centers have hierarchical relationships to other cost centers.
6 maximum level but not all have 6 levels.
So the tbl_heir has only 6 entries period heir 1, heir 2, heri 3, heir 4, heir 5, heir 6
the tbl_cc has about 5000 values.
the join is essential a join for a cost center and the heir level cost center of its related cost centers.
so it might look something like this
join_id cc_id heir_id cc_heir_id
1 1 1 8
2 1 2 12
3 2 1 3
4 2 2 4
5 2 3 6
6 2 4 11
7 3 1 7
Now I need to construct a view that contains a colum for cost center
and then a colum for each of the possible heirarchies
so basically six columns one for each value of the 6 heir values and then a column for the corresponding cc entry for that heir level
The statement I am using now returns the primary keys as contained in the join table...
So it returns something lthat looks like this
cc_id heir_1 heir_2 heir_3 heir_4 heir_5 heir_6
1 8 12 NULL NULL NULL NULL
2 3 4 6 11 NULL NULL
3 7 NULL NULL NULL NULL NULL
But the value of that heirachical column that I need displayerd isnt the primary key value but rather the value of the cc column that corresponds to it.
so lets say the tbl_cc has 12 entries
tbl_cc
cc_id cc
1 cc_A
2 cc_B
3 cc_C
4 cc_D
5 cc_E
6 cc_F
7 cc_G
8 cc_H
9 cc_I
10 cc_J
11 cc_K
12 cc_L
So the join table above viewed through teh view instead looks like this
1 cc_H cc_L
2 cc_C cc_D cc_F cc_K
3 cc_G
Could someone tell me how to adjust my view code to display the cc column value rather than the cc_id value as shown in the example above...
Here is my query code
SELECT tbl_cc.cc_id, SUM(CASE WHEN dbo.tbl_join_cc_heir.heir_
FROM dbo.tbl_cc LEFT JOIN
tbl_join_cc_heir ON tbl_join_cc_heir.cc_id = tbl_cc.cc_id
GROUP BY tbl_cc.cc_id
Not quite what I am looking for.
The code you posted display the cc value for the cc_id..which is fine...but what I need is for the heir columns to display the cc value that corresponds with the cc_heir_id primary key.
The cc_heir_id is in fact the same as cc_id..its a foreign kety constraint..which means that heach column above
has a value in the tbl_cc column that matches the id like below
1 cc_H cc_L
3 cc_G
your code displays the view like so
cc_A 8 12 NULL NULL NULL NULL
cc_B 3 4 6 11 NULL NULL
cc_C 7 NULL NULL NULL NULL NULL
1 cc_H cc_L
3 cc_G
GROUP BY tbl_cc.cc
