Problem using Remote Desktop Connection through VPN(PPTP) connection
Posted on 2009-05-21
Last Modified: 2012-05-07
Hi All,
I have a little problem whereby upon connecting to work using my PPTP connection, I cant connect to my machine using the Remote Desktop Connection, however, if I then disconnect from the vpn and then connect again, it works.
This seems to happen for most our clients, and it doesnt always fail on the first attempt.
We use a Watchguard Firebox and all client PCs are Win XP Pro
Very annoying.
Has anyone had a similar issue??
Question by:daviesgroup
  • 2
Expert Comment
Try to fix a lower MTU
Author Comment
Could you explain how this would help please?
Accepted Solution
htam earned 2000 total points
A series of ping tests using the command, ping "remotge ip" -f -l xxxx, where xxxx is the packet size, can be used to determine the optimal MTU for your connection. Start from xxxx = 1400 and after lower
Begin increasing the packet size from this number in small increments until you find the largest size that does not fragment. Add 28 to that number (IP/ICMP headers) to get the optimal MTU setting. For example, if the largest packet size from ping tests is 1462, add 28 to 1462 to get a total of 1490 which is the optimal MTU setting.
The Windows built-in PPPoE client has a default MTU of 1480. To change the MTU, please refer to the Microsoft Knowledgebase: http://support.microsoft.com/default.aspx?scid=kb;en-us;283165 and http://www.microsoft.com/windowsxp/pro/using/howto/networking/pppoe.asp
WEBINAR: GDPR Implemented - Tips & Lessons Learned
Join the WatchGuard team on Thursday, March 29th as we recount some valuable lessons learned in weighing the needs of a business against the new regulatory environment, look ahead at the two months left before implementation, and help you understand the steps you can take today!
Join & Write a Comment
When you connect to your workplace's VPN, you may not notice that you are using your workplace's servers to serve up webpages.  This might be undesirable since the workplace can log all the places you've been.  It also might be very slow to load pag…
Like many others, when I created a Windows 2008 RRAS VPN server, I connected via PPTP, and still do, but there are problems that can arise from solely using PPTP.  One particular problem was that the CFO of the company used a Virgin Broadband Wirele…
After creating this article (http://www.experts-exchange.com/articles/23699/Setup-Mikrotik-routers-with-OSPF.html), I decided to make a video (no audio) to show you how to configure the routers and run some trace routes and pings between the 7 sites…
Windows 10 is mostly good. However the one thing that annoys me is how many clicks you have to do to dial a VPN connection. You have to go to settings from the start menu, (2 clicks), Network and Internet (1 click), Click VPN (another click) then fi…
619 members asked questions and received personalized solutions in the past 7 days.
Join & Ask a Question
