conversion solution to convert Corel presentation to Power Point
anyone knows of a conversion solution to convert Corel presentation to Power Point?
Mamdouh2009Asked:
gsnshankarCommented:
Mamdouh2009Author Commented:
Thank you for the response, I forgot to add that we no longer have corel presentation, we only now have Powerpoint and some old files in corel format will not open, it doesn't recognize the .shw format.
Oh! Then it might be grueling.
One idea is to download & install a 30-day trial (free) of Corel WordPerfect Office from their site at www.Corel.com  - Apparently the trial is fully-functional, so you should be able to view your presentation in it.  And you must be able to export the .shw to PPT using the trial version.
Meanwhile let me look other solutions and will post it if I get one.
Thanks for the suggestion.
I Downloaded 30 day package it starts to convert files but only converts the first page and the rest are blank pages.
any other thoughts?
It was a grueling task, I was looking for a simpler solution :(
Thanks for all your help.
Windows XP
