Problems between Tandberg system and Polycom Bridge
schleckser
schleckser asked
on
Last Modified: 2012-05-07
Hello.
We are experiencing issues when trying to use our MXP3000 Tandberg unit to call into a Polycom Bridge.  Our call causes their bridge to reboot.  We are running current firmware, v7.2.3, and can call to other endpoints without problem.  We have heard that different versions of Tandberg firmware work better with Polycom bridges, but are unsure with version to load.  Does anyone have any experience with this?
Watch Question
Unlock this solution and get a sample of our free trial.
(No credit card required)
UNLOCK SOLUTION
Thank you so much for your quick reply!  May I add a twist?  The group with the Polycom have no intention of upgrading anything, and are not at all cooperative.  They have put the onus on us to develop a solution to connect to them.  Do you perhaps know of any existing releases that can co-exist between the two systems.  I will try to find the version that they are currently running.  Thanks again!
I would strongly advise them to upgrade their MGC, it is after-all in their best interest. If they are providing bridging services to multiple customers and they call anyone running your current version of MXP it will reboot the entire bridge (i.e. ALL current calls at the time will get disconnected)
However, at the end of the day, that is their problem - not yours. By upgrading your Tandberg 3000 MXP to version 8.0, this should also correct this particular problem.
But going back to the Polycom bridge - if they call someone else on an older MXP version, they run the risk of their entire bridge rebooting - untill they upgrade also.
Let me know how you get on!
I have learned that they are using Polycom version 8.0.0.1.4, hope this helps!
In the Tandberg release notes for version F8.0 MXP it says that it has been interop tested with
Polycom MGC version  8.0.2.6 & 9.0.1.8.
Please provide your email to receive a sample view!
OR
Please enter a first name
Please enter a last name
