Help with a .NET/SQL Timout problem
   I've been wrrestling with this problem for over a week,  I am using the the query posted below to create a dataset that feeds a Crystal Report.  This query does return data in SQL Manager, although it takes about 2 minutes.  However, when I call the stored procedure in my ASP.NET app, it always times out in about 30 seconds.  I've changed the connection timeout value in my WEB.CONFIG and in SQL Server (both posted).  Doesn't make sense to me.  What can I do?  Thanks!
WEB,CONFIG
  <add name="XXX_prodSQLConnectionString" connectionString="Data Source=XXX-PC\SQLEXPRESS;Initial Catalog=OrderEntry_prodSQL;Integrated Security=True;Connection Timeout=0" providerName="System.Data.SqlClient"/>
USE [OrderEntry_prodSQL]
GO
/****** Object:  StoredProcedure [dbo].[SELECTInvoiceForm]    Script Date: 07/02/2009 13:22:05 ******/
SET ANSI_NULLS ON
GO
SET QUOTED_IDENTIFIER ON
GO
-- Author:		<Author,,Name>
-- Create date: <Create Date,,>
-- Description:	<Description,,>
ALTER PROCEDURE [dbo].[SELECTInvoiceForm]
(@InvoiceNumber int)
AS
BEGIN
	-- SET NOCOUNT ON added to prevent extra result sets from
	-- interfering with SELECT statements.
	SET NOCOUNT ON;
    -- Insert statements for procedure here
SELECT DISTINCT i.Consignment,n.InvoiceNumber,n.InvoiceDate,n.ShipVia,n.CustomerNumber,n.ShipToNumber,n.BillToNumber,a.BOLNumber,a.ShipDate,e.Name, g.Name,g.Address1,g.Address2,g.City,g.State, g.ZipCode, g.Country,c.PricePerCWT,i.RodSize,i.Grade,i.Price,i.CustomerPO AS RodPO,j.Name AS VendorName, CASE WHEN f.Name != Null AND f.CustomerNumber != g.CustomerNumber THEN f.Name ELSE g.Name END AS ShipToName, CASE WHEN f.Name != Null AND f.CustomerNumber != g.CustomerNumber THEN f.Address1 ELSE g.Address1 END AS ShipToAddress1, CASE WHEN f.Name != Null AND f.CustomerNumber != g.CustomerNumber THEN f.Address2 ELSE g.Address2 END AS ShipToAddress2, CASE WHEN f.Name != Null AND f.CustomerNumber != g.CustomerNumber THEN f.City ELSE g.City END AS ShipToCity, CASE WHEN f.Name != Null AND f.CustomerNumber != g.CustomerNumber THEN f.State ELSE g.State END AS ShipToState, CASE WHEN f.Name != Null AND f.CustomerNumber != g.CustomerNumber THEN f.ZipCode ELSE g.ZipCode END AS ShipToZipCode,CASE WHEN h.Name != Null AND f.CustomerNumber != h.CustomerNumber THEN h.Name ELSE g.Name END AS BillToName, CASE WHEN h.Name != Null AND f.CustomerNumber != h.CustomerNumber THEN h.Address1 ELSE g.Address1 END AS BillToAddress1, CASE WHEN h.Name != Null AND f.CustomerNumber != h.CustomerNumber THEN h.Address2 ELSE g.Address2 END AS BillToAddress2, CASE WHEN h.Name != Null AND f.CustomerNumber != h.CustomerNumber THEN h.City ELSE g.City END AS BillToCity, CASE WHEN h.Name != Null AND f.CustomerNumber != h.CustomerNumber THEN h.State ELSE g.State END AS BillToState, CASE WHEN h.Name != Null AND f.CustomerNumber != h.CustomerNumber THEN h.ZipCode ELSE g.ZipCode END AS BillToZipCode,b.*,m.CoilNumber,m.Weight AS CoilWeight,l.CoilID,l.Weight
           --  ( SELECT DISTINCT SUM(m.Weight) AS RodWeight FROM tblCoilID m JOIN tblCoilLog l ON l.MasterCoilNumber = m.CoilNumber AND l.BOLNumber = a.BOLNumber AND l.Control = c.Control GROUP BY l.MasterCoilNumber)
             FROM tblInvoiceHeader AS n
             JOIN tblInvoiceDetail AS o ON o.InvoiceNumber = n.InvoiceNumber
             JOIN tblBOLHeader AS a ON a.BOLNumber = o.BOLNumber
             JOIN tblBOLDetail AS b ON a.BOLNumber = b.BOLNumber
             JOIN tblOrderDetail AS c ON c.Control = b.Control
             JOIN tblOrderHeader AS d ON d.OrderNumber = c.OrderNumber
             JOIN tblHeatTransaction AS k ON k.Control = c.Control
             JOIN tblHeat AS i ON i.ID = k.HeatID
             JOIN tblVendor AS j ON j.VendorNumber = i.VendorNumber
             LEFT JOIN tblCoilLog AS m ON a.BOLNumber = m.BOLNumber AND m.Control = c.Control
             JOIN tblCoilID AS l ON l.CoilNumber = m.MasterCoilNumber
             LEFT JOIN tblCarrier AS e ON a.CarrierNumber=e.CarrierNumber
             LEFT JOIN tblMultipleShipToAddress AS f ON a.ShipToNumber=n.ShipToNumber
             LEFT JOIN tblCustomer AS g ON g.CustomerNumber=n.CustomerNumber
             LEFT JOIN tblMultipleBillToAddress AS h ON a.BillToNumber=n.BillToNumber
            WHERE n.InvoiceNumber = @InvoiceNumber
            GROUP BY n.InvoiceNumber,n.InvoiceDate,n.ShipVia,n.CustomerNumber,n.ShipToNumber,n.BillToNumber,a.BOLNumber,b.Control,a.ShipDate,e.Name,
            g.Name,g.Address1,g.Address2,g.City,g.State,g.ZipCode,g.Country,c.PricePerCWT,i.RodSize,i.Grade,i.Price,i.CustomerPO,
            j.Name,b.ID,b.BOLNumber,b.HeatID,b.NoOfCoils,b.Description,b.CustomerPONumber,b.PartNumber,b.NetWeight,b.TareWeight,b.SplitCoils,b.NoOfCarriers,b.HeatNumber,b.Grade,b.FinishedSize,b.BW,b.PackageDescription,b.MaterialDescription,b.ClassRate,b.HazardousMaterial,b.upsize_ts,c.Control,
            i.Consignment,l.CoilID,l.Weight,m.CoilNumber,m.Weight,
            h.CustomerNumber,f.CustomerNumber,g.CustomerNumber,f.Name,f.Address1,f.Address2,f.City,f.State,f.ZipCode,f.Country,h.Name,h.Address1,h.Address2,h.City,h.State,h.ZipCode,h.Country
END
jvalescuAsked:
Bob HoffmanDeveloperCommented:
set the command timeout in your connection object to 0.
Anthony PerkinsCommented:
>>set the command timeout in your connection object to 0.<<
And be prepared to wait indefinitely or fix the problem in the first place by optimizing the query.
>> it always times out in about 30 seconds. <<
That is because the default is 30 seconds. :)
On second thoughts, unless you are prepared to re-write your query and perhaps the underlying table structure you would be better of waiting a long time.
Please do not take this the wrong way, but I have very rarely seen on this site (and i have seen a few) such a poorly written query.  With a GROUP BY clause like yours I am surprised it takes only 2 minutes. Here is the Stored Procedure in a clearer format:
GO
SET ANSI_NULLS ON
GO
GO
AS
BEGIN
      SET NOCOUNT ON;
SELECT DISTINCT
        i.Consignment,
        n.InvoiceNumber,
        n.InvoiceDate,
        n.ShipVia,
        n.CustomerNumber,
        n.ShipToNumber,
        n.BillToNumber,
        a.BOLNumber,
        a.ShipDate,
        e.Name,
        g.Name,
        g.Address1,
        g.Address2,
        g.City,
        g.State,
        g.ZipCode,
        g.Country,
        c.PricePerCWT,
        i.RodSize,
        i.Grade,
        i.Price,
             ELSE g.Name
        END AS ShipToName,
             ELSE g.Address1
             ELSE g.Address2
             ELSE g.City
        END AS ShipToCity,
             ELSE g.State
        END AS ShipToState,
             ELSE g.ZipCode
             ELSE g.Name
        END AS BillToName,
             ELSE g.Address1
             ELSE g.Address2
             ELSE g.City
        END AS BillToCity,
             ELSE g.State
        END AS BillToState,
             ELSE g.ZipCode
        b.*,
        m.CoilNumber,
        l.CoilID,
        l.Weight
        LEFT JOIN tblCarrier AS e ON a.CarrierNumber = e.CarrierNumber
        LEFT JOIN tblMultipleShipToAddress AS f ON a.ShipToNumber = n.ShipToNumber
        LEFT JOIN tblCustomer AS g ON g.CustomerNumber = n.CustomerNumber
        LEFT JOIN tblMultipleBillToAddress AS h ON a.BillToNumber = n.BillToNumber
        n.InvoiceDate,
        n.ShipVia,
        n.CustomerNumber,
        n.ShipToNumber,
        n.BillToNumber,
        a.BOLNumber,
        b.Control,
        a.ShipDate,
        e.Name,
        g.Name,
        g.Address1,
        g.Address2,
        g.City,
        g.State,
        g.ZipCode,
        g.Country,
        c.PricePerCWT,
        i.RodSize,
        i.Grade,
        i.Price,
        i.CustomerPO,
        j.Name,
        b.ID,
        b.BOLNumber,
        b.HeatID,
        b.NoOfCoils,
        b.Description,
        b.CustomerPONumber,
        b.PartNumber,
        b.NetWeight,
        b.TareWeight,
        b.SplitCoils,
        b.NoOfCarriers,
        b.HeatNumber,
        b.Grade,
        b.FinishedSize,
        b.BW,
        b.ClassRate,
        b.upsize_ts,
        c.Control,
        i.Consignment,
        l.CoilID,
        l.Weight,
        m.CoilNumber,
        m.Weight,
        h.CustomerNumber,
        f.CustomerNumber,
        g.CustomerNumber,
        f.Name,
        f.Address1,
        f.Address2,
        f.City,
        f.State,
        f.ZipCode,
        f.Country,
        h.Name,
        h.Address1,
        h.Address2,
        h.City,
        h.State,
        h.ZipCode,
        h.Country
END
At the very least lose the DISTINCT clause, with the existing GROUP BY clause, it serves no purpose whatsoever.
jvalescuAuthor Commented:
Changed it around and it completes in 8 seconds.  Thanks.
Microsoft SQL Server 2005
