Start Free TrialLog in
Avatar of Michael Murphy
Michael MurphyFlag for Ireland
Problem with Power Unit Replacement
I have a Dell Inspiron 1100. It broke down and after performing tests  (helped by Experts Exchange) I was able to identify the fault as the Power Unit. (I got the loan of an identifal power unit, inserted it, and it worked perfectly). Since then I purchased a power unit, but when I went to fit it I discovered problems. Basically the new power unit's main connection is for 24 pins, while the socket on my Motherboard allows for 20 pins. Is there any adapator which might be used. I doubt it, but just thought I'd pose the question. What they gave me was a Switching Power Supply ATX 12V PA (ACE), Model: 400W
Avatar of ComputerTechie
ComputerTechie
Avatar of Mark Poirier
Mark Poirier
Flag of Canada image
I want to thank the three you you who responded. I have the computer up and running thanks to you. It may have been simple for you, but for me, getting the solution prevented me from going back to the Company (in Cork, Ireland - Cork is the real Capital of Ireland, but keep it secret), to harrangue the sales staff. Really grateful
