Help with PCI-e SAS controller on an IBM x236 system not being recognised
Posted on 2009-07-13
Last Modified: 2013-11-16
Hi All,
I'm having some trouble trying to get this IBM SAS HBA controller (25R8060) to work with my IBM x236 server. I'm getting an NMI error on the led panel of the server.
First of all, I just recently confirmed that this setup is not supported by IBM, but IBM won't comment on whether its compatible. I landed in this predicament because IBM gave me some wrong advice in the start (lesson learned... use email so there's something written).
Anyway, long story short, whether or not its supported I still don't see why its not compatible. This is what I've got so far... The SAS controller is an (IBM rebranded) LSI Logic card that has PCI-e 8x connection. According to the x236 documentation, the x236 has PCI-e 4x slots... BUT... the SAS controller fits perfectly into the slots. So I'm assuming these are actually 8x slots...
On boot up, I get past post, but once its about to start the OS, I get a blank screen and the NMI error lights up on the led panel. Within 30 secs, the server reboots itself. I don't believe its an OS issue as I've tried to boot it up with WinPE and same issue happens.
I've updated all BIOS and BMC firmware and I've disabled all PCI rom execution in BIOS. I'm using the onboard raid for my hdds.
Anyone have any suggestions or similar issues? Anyone got SAS working on a x236 even if its a 3rd party product?
Can anyone confirm the PCI-e ports on the x236 are actually 4x or 8x?
Question by:plauit
  • 2
LVL 26
Expert Comment
It's 8x
It should be noted however that using a physical socket that is 'more X' than the actual wiring is common.
What I mean is a 1x or 4x 'wired' slot may physically be an 8x type slot.
They can do this because all the control functions pass through the 1x portion and all the rest of the 'X's' just increase the cards bandwidth.
An 8x card will work fine in a 4x 'wired' slot but it will be limited to 4x speed.
In fact some PCI-E slots are open ended so longer cards and be installed.
Author Comment
Ok, I've tried some system analysing software and its reporting the PCIe ports as x4.
Either way, I've bought another SAS controller to try again. This time its an Adaptec 1045 PCIe x4 SAS controller card. But I still get the same NMI issue!!! What's going on!
However, this time, during boot, I do get the Adaptec POST messages saying press Ctrl-A to access the raid bios settings. So, it is registering the Adaptec card during POST. However, as soon as it tries to boot the OS, the NMI led comes up at the same time as previously on the LSI x8 card.
To clarify further, with either card, when I use WinPE to boot, it gets stuck on the screen "Setup is inspecting your computer's hardware configuration..."
So i'm guessing, with either Win2k3 or WinPE, as soon as the server tries to I/O the card, it faults out with the NMI led.
Any ideas on what I should try?
Accepted Solution
plauit earned 0 total points
Ok, so I finally started from scratch.
Shutdown the server, unplugged PSUs, took out all the RAM, put it all back in and booted the server.
Went into BIOS and loaded defaults.
Rebooted and it started working!!! Detected the SAS controllers during post and went into OS fine.
No more NMI errors!
Get 10% Off Your First Squarespace Website
Ready to showcase your work, publish content or promote your business online? With Squarespace’s award-winning templates and 24/7 customer service, getting started is simple. Head to Squarespace.com and use offer code ‘EXPERTS’ to get 10% off your first purchase.
Join & Write a Comment
MSSQL DB-maintenance also needs implementation of multiple activities. However, unprecedented errors can hamper the database management. In that case, deploying Stellar SQL Database Toolkit ensures fast and accurate database and backup repair as wel…
An introductory discussion about Oracle Analytic Functions which are used to calculate or compute Aggregate values, based on a group of rows.
In this video, Percona Solution Engineer Dimitri Vanoverbeke discusses why you want to use at least three nodes in a database cluster. To discuss how Percona Consulting can help with your design and architecture needs for your database and infras…
This lesson discusses how to use a Mainform + Subforms in Microsoft Access to find and enter data for payments on orders. The sample data comes from a custom shop that builds and sells movable storage structures that are delivered to your property. …
607 members asked questions and received personalized solutions in the past 7 days.
Join & Ask a Question
