Need help setting up IP routing to SBS 2003 with Public LAN/WAN
Experts-
I received static IP addresses from AT&T.  They gave me two sets, a public WAN and a public LAN (these are obviously not the real IPs):
WAN
IPs: 89.123.11.142/143
Subnet Mask: 255.255.255.252
Gateway: 89.123.11.141
LAN
Useable IPs: 79.123.22.241/245
Subnet Mask: 255.255.255.248
Gateway: 79.123.22.246
The office consists of a DSL modem ->Linksys WRT54G router -> SBS 2003 server ->workstations
Additionally, the SBS 2003 server is a mail server with an MX record and linked to a LAN IP.  I need to be able to see the server from the Internet (ping it, send mail, remote access, etc).  SBS has a dual NIC and from what I understand is supposed to be setup with one internal NAT network and one external ISP network.
Diagram below is how I have it setup now.
My problem is that I cannot see the server from the Internet.  I need the Linksys router for office wireless connectivity (printers, notebooks, etc).  AT&T will not allow the LAN IPs to be on their network and they control routing from the 89.x subnet to resolve to 79.x.  I can ping both 89.x IP addresses as well as the Linksys LAN side (79.123.22.246).  But, even putting the SBS server IP (79.123.22.245) in the DMZ does not allow me to see it from the Internet.  Port forwarding also doesnt work.  Am I missing something?
-Joe
jetcosysAsked:
CitacompConnect With a Mentor Commented:
If you need the Linksys router for office printers, etc., why don't you have it on the LAN side of your SBS?  This should take care of your problems.
If you need to keep the Linksys at it's place in the chain for some reason, then I would think that static routing might need to be configured on the device.
murgroupCommented:
First you need to put the DSL modem in bridged mode so that it forwards all traffice to the Linksys. My guess is the modem is doing NAT and probably has a built in firewall. your DSL provider can help you get it into bridged mode.
Then setup the LInksys with your public IP of 142 or 143, the subnet of 255.255.255.252 and gateway of 141.
Once you have internet access create port forwarding rules for your needed services to the sbs server.
Keep in mind the Linksys is a home router and not intended for business. I would purchase a business class firewall.
jetcosysAuthor Commented:
Thanks for the quick responses!
murgroup: The modem is in bridged mode already and must be set to the WAN IP (141), so the Linksys WAN side is set to 142 and the Linksys LAN side to the 246.  That part all works as expected.  The forwarding of ports doesn't work however.  I can ping 246 and have ports forwarded to 245 (SBS Server), but the traffic never relays.  You're right, I should use a biz class router, but for a small office, this is fine.
Citacomp: interesting idea.  I actually never thought of that.  Do you know if this Linksys can be a router instead of a gateway and forward DHCP from the server?
Thanks for the help,
-Joe
Learn to develop an Android App
Want to increase your earning potential in 2018? Pad your resume with app building experience. Learn how with this hands-on course.
murgroupConnect With a Mentor Commented:
Yes you can use the Linksys for wireless only. just plug it into your network and make sure it's on the same subnet at the internal LAN.
I've never heard of a Public LAN being assigned by the ISP. Normally you choose what your internal range is going to be ie 192.168.1.1-254
If the modem is in bridged mode your setup in the linksys would look like:
WAN:
Static IP: 89.123.11.142
Subnet: 255.255.255.252
DNS: your public DNS servers
LAN IP: 192.168.1.1 or whatever.
Subnet: 255.255.255.0
Then in SBS you would only use one NIC and it would have an IP of say:
IP: 192.168.1.5
SUB:255.255.255.0
Gateway: 192.168.1.1
Run the Internet connection wizard and tell it to use only one NIC. The defualt gateway of 192.168.1.1, your external dns servers and finish the wizard.
Everything should work fine if your modem is in bridged mode. If not the modem could be your issue.
Also I'm not sure if AT&T uses PPPoE or PPPoA. That can cause issues and the router should support PPPoE.
Ok, will move the Linksys and see what happens.  I've never heard of the ISP giving two IP ranges either, but it's what AT&T did this time.  The reason I need the Public LAN IP is because the server is an MX and to properly register the reverse lookup in DNS, I had to have AT&T assign the IP.  I had it setup as you described above exactly but too much mail has been non-deliverable due to the reverse DNS not being the mail.server.com address.  It's a mess man.
murgroupCommented:
Strange, AT&T should control RDNS for your public IP and it should be an easy fix on their end. I have many many clients setup like that and the ISP always controls RDNS. Good luck with this issue.
CitacompCommented:
A further note about the Linksys.  When you connect it to your LAN side, don't plug anything in to the WAN port and make sure DHCP is off (assuming that the SBS is serving DHCP).  I suppose it'd be possible to use the WAN port if you turned of NAT, but instead of messing around with the configuration it's easier to just not use it.
Is your SBS Premium or Standard?
Yah, I already disabled DHCP on the router since SBS is issuing DHCP and will plug in on the LAN side only.  SBS is standard version.  Thanks for the advice!  :)
-J
Ok, I removed the Linksys router which did not work because my server must have an IP address on the public LAN side (79 subnet) and the DSL modem is on the WAN side (89 Subnet) which makes the gateway on the different ip segment.  Then, in looking at the options on the server NIC, I remembered that you can multi-home a single NIC.  I used the advanced TCP/IP settings and assigned the server NIC an IP address from 79, gateway from 89...then in the advanced area, an IP from 89 and the gateway from 79.  Not sure why or how, but this configuration works.
Split the points evenly between the two experts as both assisted with advice on a solution I ultimately determined.
