I am running the following sql script through an application and I am getting Error setting output directory in the deamon log - suggests environment, but I have tried putting the absolute path in the script but I get the same. Any ideas?
REM *************************************************************************:
REM *** System : First Software Benefits ***
REM *** Subsystem : Benefits ***
REM *** Module : bccsched ***
REM *** File : bccsched.sql ***
REM *** Called By : Generic Process Interface GPI ***
REM *** Author : Rebecca Barry ***
REM *** Request By : User request ***
REM *** Purpose : Batch Report ***
REM *** Parameters : $1 Log file name ***
REM *** : $2 Schedule Start date ***
REM *** : $3 Schedule End date ***
REM *** : $4 created date ***
REM *** Tables : BATCH_REQUEST_INSTANCES (SELECT) ***
REM *** : BATCH_REQUESTS (SELECT) ***
REM *** : PARAMETER_VALUES PVA (SELECT) ***
REM *** ***
REM **************************************************************************
REM *** Change History ***
REM *** ***
REM *** Date Done By Description ***
REM *** 24-Nov-2009 R. Barry Initial Creation ***
REM *** ***
whenever sqlerror exit 1;
spool &outfile
REM *** Set up Report Titles ***
SELECT user USERCOL,
TO_CHAR(SYSDATE, 'DD-MON-YYYY') TODAY,
prm.prm_value WHO
FROM parameters prm
WHERE prm.prm_domain = 'SYSINFO'
AND prm.prm_code = 'OWNER'
ttitle LEFT uservar CENTER whovar RIGHT datevar SKIP 1 -
LEFT 'Schedule' RIGHT 'Page ' FORMAT 9999 SQL.PNO SKIP 1 -
CENTER 'RBLIVE Schedule parameter report '&startdt' to '&enddt' Checked by: _________________' SKIP 2
REM *** Set up Column Formats, Totals and breaks ***
set lines 120 pages 42 trimspool on verify off newpage 0
column mname format a20 heading 'Module|'
column refno format 9999999 heading 'Run |number '
column edate format a10 heading 'Execution|time'
column parmn format a25 heading 'Parameter name|'
column pvalu format a30 heading 'Parameter value|'
column qname format a8 heading 'Queue|'
break on qname skip page on mname skip 0 on refno skip 0 on edate skip 1 nodup
SELECT BRI.BRI_BRE_MOD_NAME mname,
TO_CHAR(BRI.BRI_REQUESTED_EXECUTION_DATE,'HH24:MI:SS') edate,
BRE.BRE_BQU_QUEUE_NAME qname,
NVL(PVA.PVA_PDU_PDF_NAME, 'N/A') parmn,
NVL(PVA.PVA_CHAR_VALUE, ' ') pvalu,
PVA.PVA_REUSABLE_REFNO refno
FROM BATCH_REQUEST_INSTANCES BRI,
BATCH_REQUESTS BRE,
WHERE BRI.BRI_REQUESTED_EXECUTION_DATE BETWEEN TO_DATE ('&startdt 12:00:00','DD-MON-YYYY HH24:MI:SS') AND
TO_DATE ('&enddt 11:59:00', 'DD-MON-YYYY HH24:MI:SS')
AND BRI.BRI_BRE_CREATED_DATE >= '&created_date'
AND BRI.BRI_REUSABLE_REFNO = PVA.PVA_REUSABLE_REFNO (+)
AND BRI.BRI_BRE_USR_USERNAME = BRE.BRE_USR_USERNAME
AND BRI.BRI_BRE_MOD_NAME = BRE.BRE_MOD_NAME
AND BRI.BRI_BRE_CREATED_DATE = BRE.BRE_CREATED_DATE
AND BRE.BRE_BQU_QUEUE_NAME != 'FSW_I_QUEUE'
AND BRI.BRI_BRE_MOD_NAME != 'FIPRELIST'
AND BRI.BRI_BRE_MOD_NAME != 'LTRREQPRELIST1'
AND SUBSTR(BRI.BRI_BRE_MOD_NAME,1,2) != 'CT'
AND SUBSTR(BRI.BRI_BRE_MOD_NAME,1,2) != 'CA'
AND BRI.BRI_BRE_USR_USERNAME = 'RB'
ORDER BY BRE.BRE_BQU_QUEUE_NAME,BRI_REQUESTED_EXECUTION_DATE, PVA.PVA_REUSABLE_REFNO, PVA.PVA_PDU_DISPLAY_SEQNO
spool off
Experts Exchange always has the answer, or at the least points me in the correct direction! It is like having another employee that is extremely experienced.
Jim Murphy
Programmer at Smart IT Solutions
When asked, what has been your best career decision?
Deciding to stick with EE.
Mohamed Asif
Technical Department Head
Being involved with EE helped me to grow personally and professionally.
Carl Webster
CTP, Sr Infrastructure Consultant
Ask ANY Question
Connect with Certified Experts to gain insight and support on specific technology challenges including:
