darthvader747
If I connnect my monitor via VGA-USB connector using a USB Hub instead of connecting it directly to my laptop - would the preformance be affected? (See Links to products I have)
Products I bought:
USB Hub:
http://www.amazon.com/gp/product/B0006TIA8Y/ref=ox_ya_oh_product
EVGA - VGA to USB
http://www.amazon.com/gp/product/B00191GZ8U/ref=ox_ya_oh_product
Would you recommend that I connect the' VGA to USB' connecter directly to my laptop (Thinkpad T400) or would it be okay to connect it to my powered USB hub?
I would prefer connecting it to the hub but dont want to see a drop in performance. Do you guys expect a drop in performance if I were to connect the monitor using the hub and not directly to the computer?
USB Hub:
EVGA - VGA to USB
As long as it's a powered hub (be sure you're using the AC adapter to power the hub) there's no difference in the bandwidth UNLESS you've got multiple devices attached to the hub -- in which case the devices on the hub have to share the bandwidth for that specific USB port.
In general, I'd recommend attaching the video adapter directly to one of the laptop's USB ports, and connecting your other devices through the hub, as the video adapter is likely the most bandwidth-intensive device you're using.
Okay! Thanks.
Now I am curious to know if I attach 6 devices to a USB port (hard drives, printers etc) do each one of those devices get 1/6th of the bandwidth of the USB port (ie- The one to which the USB hub is connected)?
This would imply that connecting multiple devices through a USB hub and using them simultaniously will slow things down significantly!!
If I am doing data transfer between 2 external drives, I am best to connected them to separate USB ports on the computer and not to the hub. Correct?
How much bandwidth does a single USB port have?
Very nicely explained. Thanks!
Also, the 'negative impact' is usually only noticeable when I am playing a game. (ie: slower refresh... lack of crispness)
