Solved
EPHD (Pc Guardian) problem.  Need advice on recovering info from drive
Posted on 2009-12-23
Last Modified: 2012-05-08
Okay....here is my issue.
I had a pc that became infected with a root-kit and numerous other malware and viruses.  I unencrypted the drive and began the cleaning process.  All went well until after I rebooted.  Each time I went to log in I kept getting a message that there was an issue loading the encryption program.  I decided to unistall the encryption program but it would not let me.  It gave me the message that the "drivers were still encrypted."  I set the unit aside for the day and came back to it a few days later.  I decided to run an emergency unencrypt (bad move) from a floppy and now my drive is not bootable and when viewing the drive externally from a working xp machine the folders and files show up as ascii characters.  I called Pc GUardian and was told that I'm SOL because of the double drive decypt.  Anyone experience this and know of a fix?
Question by:dlo32
1 Comment
LVL 47
Accepted Solution
by:
noxcho earned 2000 total points
Forget about your data and OS. Encryption software is not written the way you could decrypt it. If one could get to it this way then the software is not worth of a penny.
Save your time and nerves, reformat the drive and start from scratch.
As hardware bugs go, this is a strange one! I upgraded a laptop in December 2011 with a 512GB Crucial m4 2.5-inch/9.5mm SATA Solid State Drive (SSD), Crucial part number CT512M4SSD2: http://www.crucial.com/store/partspecs.aspx?IMODULE=CT512M4SSD2 …
When we purchase storage, we typically are advertised storage of 500GB, 1TB, 2TB and so on. However, when you actually install it into your computer, your 500GB HDD will actually show up as 465GB. Why? It has to do with the way people and computers…
This video Micro Tutorial explains how to clone a hard drive using a commercial software product for Windows systems called Casper from Future Systems Solutions (FSS). Cloning makes an exact, complete copy of one hard disk drive (HDD) onto another d…
This lesson discusses how to use a Mainform + Subforms in Microsoft Access to find and enter data for payments on orders. The sample data comes from a custom shop that builds and sells movable storage structures that are delivered to your property. …
569 members asked questions and received personalized solutions in the past 7 days.
Join & Ask a Question
