akromyk4
I need help finding a way to confirm my predication regarding my laptop mouse problem.
My laptop mouse intermittently clicks on its own while I am typing, which is extremely annoying when trying to type code or a paper. I am pretty sure that this is a hardware problem, but I need a way to confirm that it is not a driver or OS issue so that when I call up Dell I don't get blamed for causing it with my self-installed Windows 7 OS that didn't come with the computer.
How can I confirm that this is a hardware problem and not a driver, software, or OS issue?
I think I was just missing the Windows 7 drivers. I went to the Dell site and updated them. So far everything appears to be working well.
Do you have a touch pad on your laptop? It could be that you are touching it a little bit when you type. This would only be if you are using the keyboard on your laptop and not a keyboard plugged to it.
Do you have a wireless mouse? Try changing channel and/or secure it to your sender. It could be someone in your neighbourhood has a mouse like yours and their signal gets interfered with yours.
