Generating class hierarchy for my Flex project using Flex Builder or otherwise
Is it possible to generate the class hierarchy tree
for my flex project using Flex Builder or otherwise?
For example,
If Class A extends B,
Class C extends B
I want to see A and C as the children of B
in the resulting diagram/structure.
dtivmk
dtivmk
  • 3
  • 2
moagriusCommented:
AFAIK, it's not built into Flex Builder, but there are lots of tools out there that will:
http://www.senocular.com/flash/tutorials/starumltoas3/
http://selfmummy.appspot.com/vasgen
http://www.flashcoder.net/blog/?p=159
I've never worked with any of them, but at a quick glance it looks like there might be some ideas there.
the above were found just using a quick google on:  "AS3 generate class UML"
hth
dtivmkAuthor Commented:
Hi moaqrius,
What I want is the exact opposite of what you have suggested,
i.e. generating a  UML diagram from a given actionscript project.
moagriusCommented:
not sure - maybe someone else can chime in here - here's another blog post with some links to UML tools - one might do what you want...
http://seantheflexguy.com/blog/2007/11/20/actionscript-30-uml-and-code-generation-tools/
Didn't find any solution. Still I would accept one answer, so that this question doesn't get deleted.
No Comments.
Concerto Cloud for Software Providers & ISVs
Can Concerto Cloud Services help you focus on evolving your application offerings, while delivering the best cloud experience to your customers? From DevOps to revenue models and customer support, the answer is yes!
Learn how Concerto can help you.
  • 3
  • 2
