zend form with captcha problem: please help
Hi
i have a zend view helper that has a contact form within it. the form include a captcha field. i atach the code.
i echo the view helper and the form is there with the captcha. the form is submitted with ajax.
so in my controller i have the code for proccesing the form.
the problem:
there is no validation on the captcha, but all the other fields does get the validation. so if i fill the form correctly but do not enter any captcha or a wrong captcha the form is passing validation as if it was good.
i have no idea what else i can do. hope someone might help me.
the form that is a view helper:
<?php
class Zend_View_Helper_Contact extends Zend_View_Helper_Abstract
     public function contact()
       $contactform = new Zend_Form();
       $contactform->setMethod('post')
        ->setName('contactform')
        ->setAction(Zend_Controller_Front::getInstance()->getBaseUrl() . '/emails/contactform')
        ->setAttrib('class','clean')
        //validators
        // customize the errors
        $notEmpty = new Zend_Validate_NotEmpty();
        $notEmpty->setMessages(
        array(Zend_Validate_NotEmpty::IS_EMPTY => 'ÔéÓÔ ÐÙàÕ ÙÛÕÜ ÜÔÙÕê èÙç')
        $alphanumeric = new Zend_Validate_Alnum();
        $alphanumeric->setMessages(array(
        Zend_Validate_Alnum::NOT_ALNUM => 'èç ÐÕêÙÕê ÕÞáäèÙÝ ÙêçÑÜÕ'
        $email = new Zend_Validate_EmailAddress();
        $email->setMessages(array(
        Zend_Validate_EmailAddress::INVALID_FORMAT => 'ÔÓÕÐÜ ÐÙàÕ êçã èÐÔ ÔÓÕÒÞÔ'
        $length = new Zend_Validate_StringLength(4,20);
        $length->setMessages(array(
        Zend_Validate_StringLength::TOO_LONG => 'ÔâèÚ ÐèÕÚ ÞÓÙ',
        Zend_Validate_StringLength::TOO_SHORT => 'ÔâèÚ çæè ÞÓÙ'
        //filters
        $allowedTags = array('br','b','i');
        $alnumfilter = new Zend_Filter_Alnum();
        $htmlentities = new Zend_Filter_HtmlEntities();
        $stringtrim = new Zend_Filter_StringTrim();
        $striptags = new Zend_Filter_StripTags($allowedTags);
        //create the elements
        //first name
        $contactform->addElement(new Zend_Form_Element_Text('name'));
        //its attributes
        $contactform->name->setLabel('éÝ:')
        ->setRequired(true)
        ->setAttrib('class','validate[required,length[4,20]]')
        ->addValidator($notEmpty,false)
        ->addValidator($length,false)
        ->addFilter($alnumfilter)
        ->addFilter($stringtrim)
        //email
        $contactform->addElement(new Zend_Form_Element_Text('email'));
        //its attributes
        $contactform->email->setLabel('ÓÕÐÜ:')
                    ->addValidator($email,false)
                    ->setRequired(true)
                    ->setDescription('example@example.com')
        //phone
        $contactform->addElement(new Zend_Form_Element_Text('phone'));
        //its attributes
        $contactform->phone->setLabel('ØÜäÕß:')
        ->setRequired(true)
        ->setAttrib('class','validate[required]')
        //message
        $contactform->addElement(new Zend_Form_Element_Textarea('message'));
        //its attributes
        $contactform->message->setLabel('ÔÔÕÓâÔ:')
        ->setAttrib('cols',20)->setAttrib('rows',10)
        ->setRequired(true)
        ->setAttrib('id','message')
        ->addFilter($striptags)
        ->addFilter($htmlentities)
          $contactform->addElement(new Zend_Form_Element_Captcha('captcha',array(
          'label' => 'ÐàÐ ÛêÕÑ Ðê ÞÔ éÛêÕÑ ÑêÞÕàÔ',
          'required' => true,
          'captcha' => array(
          'captcha' => 'image',
          'wordLen' => 4,
          'font' => 'captcha/ARIAL.TTF',
          'fontSize' => 30,
          'imgDir' => 'captcha',
          'imgUrl' => '/captcha/',
          'timeout' => 300,
          'height' => 50,
          'fontSize' => 22,
          'DotNoiseLevel' => 0.5,
          'LineNoiseLevel' => 0.5,
          'Expiration' => 20
        //submit button
        $contactform->addElement(new Zend_Form_Element_Submit('submit'));
        $contactform->submit->setLabel('éÜ×');
        $contactform->addDisplayGroup(
        array('name', 'email','phone','message','captcha','submit'),
        'contacts',
        array('legend' => 'æÕè çéè')
        return $contactform;
the controller code:
    public function contactformAction()
        $contactform = $this->view->Contact();
        $request = $this->getRequest();
                 if ($request->isXmlHttpRequest()) {
                  $this->_helper->layout->disableLayout();
                  $this->getHelper('viewRenderer')->setNoRender();
                  $response = $contactform->processAjax($request->getPost());
                  if ($response == 'true')
                      // $name = $contactform->getValue('name');
                     // $email = $contactform->getValue('email');
                     //$captchainput = $contactform->getValue('captcha[input]');
                     //echo $captchainput;
                     $this->getResponse()->setHeader('Content-type','application/json')->setBody($response);
                  }else{
and the jquery:
	$("#contactform input#submit").click(function() {
		var name = $("#contactform input#name").val();
		var email = $("#contactform input#email").val();
		var phone = $("#contactform input#phone").val();
		var message = $("#contactform textarea#message").val();
		var captchainput = $("#contactform input#captcha-input").val();
		var captchaid = $("#contactform input#captcha-id").val();
		alert(captchaid);
		/*if("ul.errors"){
			$("ul.errors").remove();
			$("br").remove();
			sendContactInfo(name,email,phone,message,captchainput,captchaid);
	        return false;
function sendContactInfo(name,email,phone,message,captchainput,captchaid)
	$.post(
		"/emails/contactform",
		"name" : name,
		"email" : email,
		"phone" : phone,
		"message" : message,
		"captchainput" : captchainput,
		"captchaid" : captchaid
		function(result){
			//alert(result.name);
			if(result != true)
				for ( var i in result.name )
	   			 //alert( result.name[i] );
	   			 $("#contactform dd#name-element").append("<ul class='errors'><li>" + result.name[i] + "</li></ul><br/>");
				for ( var i in result.email )
	   			 $("#contactform dd#email-element").append("<ul class='errors'><li>" + result.email[i] + "</li></ul><br/>");
				for ( var i in result.phone )
	   			 $("#contactform dd#phone-element").append("<ul class='errors'><li>" + result.phone[i] + "</li></ul><br/><br/>");
				for ( var i in result.message )
	   			 $("#contactform dd#message-element").append("<ul class='errors'><li>" + result.message[i] + "</li></ul><br/><br/>");
				for ( var i in result.cpatchainput )
	   			 $("#contactform dd#captcha-element").append("<ul class='errors'><li>" + result.captachainput[i] + "</li></ul><br/><br/>");
			}else{
				$('#contactform').hide();
				$('#resultmsg').append('<h3>êÕÓÔ âÜ ÔÓÕÐÜ. Ð×ÖÕè ÐÜÙÚ ÑÔçÓÝ ÔÐäéèÙ!</h3>')
		},'json'
derrida
derrida
  • 7
  • 4
Richard QuadlingSenior Software DeveloperCommented:
'expiration', NOT 'Expiration'
"All of the above options may be passed to the constructor by simply removing the 'set' method prefix and casting the initial letter to lowercase: "suffix", "height", "imgUrl", etc."
http://framework.zend.com/manual/en/zend.captcha.adapters.html#zend.captcha.adapters.image
And can you show the HTML for the <form> tag so we can see that it is all tying together correctly.
derridaAuthor Commented:
hi
i attach the html that zend generate.
ron
<!-- contact form -->
<form id="contactform" enctype="application/x-www-form-urlencoded" method="post" action="/emails/contactform" class="clean"><dl class="zend_form">
<dt id="contacts-label">&nbsp;</dt><dd id="contacts-element"><fieldset id="fieldset-contacts"><legend>æÕè çéè</legend>
<dl>
<dt id="name-label"><label for="name" class="required">éÝ:</label></dt>
<dd id="name-element">
<input type="text" name="name" id="name" value="" class="validate[required,length[4,20]]"></dd>
<dt id="email-label"><label for="email" class="required">ÓÕÐÜ:</label></dt>
<dd id="email-element">
<input type="text" name="email" id="email" value="">
<p class="description">example@example.com</p></dd>
<dt id="phone-label"><label for="phone" class="required">ØÜäÕß:</label></dt>
<dd id="phone-element">
<input type="text" name="phone" id="phone" value="" class="validate[required]"></dd>
<dt id="message-label"><label for="message" class="required">ÔÔÕÓâÔ:</label></dt>
<dd id="message-element">
<textarea name="message" id="message" cols="20" rows="10"></textarea></dd>
<dt id="captcha-label"><label for="captcha-input" class="required">ÐàÐ ÛêÕÑ Ðê ÞÔ éÛêÕÑ ÑêÞÕàÔ</label></dt>
<dd>
<img width="200" height="50" alt="" src="/captcha/10149f01db736a887e042612bbe343b0.png"/><br/>
<input type="hidden" name="captcha[id]" value="10149f01db736a887e042612bbe343b0" id="captcha-id">
<input type="text" name="captcha[input]" id="captcha-input" value=""></dd>
<dt id="submit-label">&nbsp;</dt><dd id="submit-element">
<input type="submit" name="submit" id="submit" value="éÜ×"></dd></dl></fieldset></dd></dl></form><!-- end contact form -->
Can you confirm (using FireBug and watching the AJAX call) to make sure that the JS side is sending the right information?
Get your problem seen by more experts
Be seen. Boost your question’s priority for more expert views and faster solutions
hi
yes it does. in firebug on the post tab i get the right info i entered the form.
ron
hi
and whe i alert the variables they all go well:
alert(captchaid);
ron
The form generated captcha[id] and captcha[input].
You are sending, via AJAX, captchaid and captchainput.
These aren't the same things.
Try ...
      $.post(
            "name" : name,
            "email" : email,
            "phone" : phone,
            "captcha[input]" : captchainput,
            "captcha[id]" : captchaid
(UNTESTED).
hi
first let me thank you, cause that was indeed the problem. now i do get true when the captcha is fine and i get an error when its not true.
but still there is one problem:
when there is a problem in firebug i get this in the json tab:
{"captcha":{"badCaptcha":"Captcha value is wrong"}}
and i get the error that result.captcha is undefined.
in my jquery i have this to show the error:
for ( var i in result.captcha )
$("#contactform dd#captcha-element").append("<ul class='errors'><li>" + result.captacha[i] + "</li></ul><br/><br/>");
ron
hi
i have done this for every error messages but it does not work for the captch.
ron
hi
when i set validatoer error message i use:
now when i try to set custom error messages for the captcha i get nothing like:
Zend_Validate_Captcha::BAD_CAPTCHA => 'this is bad captcha'
am i missing something here?
ron
hi
ok manage to fix the problem now i have just the problem of the custom message.
in any case. i want to thank you for your great help.
i needed it:)
best regards
ron
Glad to have helped.
Join & Write a Comment
Free Tool: Site Down Detector
  • 7
  • 4
