What uses more battery on iPhone? Edge, 3G, Wi-Fi?
I have an iPhone 3GS and I have several combinations to keep it connected.
I find everywhere that wi-fi uses less battery than 3G, so I should use wi-fi with 3G to save battery power.
My question is: what combination should I use to save battery the most?
Edge alone
Edge + wi-fi
3G + wi-fi
martinewski
martinewski
mastooCommented:
I'd guess the first one, but that would just be a guess.  Why not try each one while running one of the Battery Magic apps and time how long it takes to go from 100% to 95%?
Alan HardistyCo-OwnerCommented:
I have found that switching 3G Off and only using 2G makes no noticeable difference to my battery life at all.  3G sucks the hell out of the battery and Wi-Fi is my connection of choice, but then I don't use my iPhone for calls etc, just for email and web browing (on EE) and even then it can't last a day!
The iPhone is configured to use the fastest conenction that it can find, so it will always be switching if you are constantly mobile.
Here is a link from Apple on how to get the most out of your iPhoen battery:
http://www.apple.com/batteries/iphone.html
MicahJPCommented:
I believe if you're connected to wifi+3G, your phone will use wifi for most/all data, but 3G is still needed for calls. If wifi is available I'd say use wifi+edge. Wifi will handle data, edge will handle calls, and you won't have 3G draining your battery.
Evaluating UTMs? Here's what you need to know!
Evaluating a UTM appliance and vendor can prove to be an overwhelming exercise.  How can you make sure that you're getting the security that your organization needs without breaking the bank? Check out our UTM Buyer's Guide for more information on what you should be looking for!
martinewskiAuthor Commented:
We all agree 3G is the iPhone´s battery drainer.
I use the phone mostly for data. So, the question could be simplified. If I´m on 2G, I have the option to use the Edge network or joining a wifi network.
The question could be: does wifi uses more power than edge? If it does, using only edge is the best to save battery. If it uses less than edge, than edge+wifi is the best option.
According to metagrapher on http://theappleblog.com/2009/06/25/iphone-3-0-battery-draining-heres-a-possible-fix/
Wi-Fi radio consumes the least battery power, then the 3G radio, then BlueTooth.  So I would stick to Wi-Fi, then Edge.  Turning off Push (which communicates every 30 seconds) will also drain your battery.
I know Wi-Fi uses less power than 3G. But does it use less power than Edge? I can't find that answer from a reliable source.
Please check out this page just after the initial graph which says that wifi uses less battery power than edge:
http://www.anandtech.com/printarticle.aspx?i=3036
Concerto Cloud for Software Providers & ISVs
Can Concerto Cloud Services help you focus on evolving your application offerings, while delivering the best cloud experience to your customers? From DevOps to revenue models and customer support, the answer is yes!
Learn how Concerto can help you.
