seanf85
Need help making sum, difference, product, average in java using eclispe
hello Need help making sum, difference, product, average in java using eclispe i want to make this work in my program i only need two integers and have it display it sum, difference, product, and average how do you build it to do that.
thanks for the help it worked
java.lang.NoClassDefFoundE
Caused by: java.lang.ClassNotFoundExc
at java.net.URLClassLoader$1.
at java.security.AccessContro
at java.net.URLClassLoader.fi
at java.lang.ClassLoader.load
at sun.misc.Launcher$AppClass
Exception in thread "main"
