T-60 Monitor only on Battery Power
I have a T-60 which is past it's lease life and must be returned with a dozen others.  It has to work to be returned, otherwise we're paying some annoying bucks for it.
I have replaced the motherboard, inverter, LCD monitor, and keyboard.
The LCD monitor fades out in a few minutes only while under AC power
An additional desktop monitor will stay on if connected.
If under battery power, the LCD will stay on.
If I FN-F7 a few times, it will cycle between monitors and the LCD will come on...shortly to fade out...to the point where the display can be barely seen.  That takes a minute or less to happen.  Never any problems with the second monitor.  While under AC power, the LCD exhibits mild flickers before it dies out - the secondary monitor is always solid.
I have tried different power cubes.  I have tried it in a docking station.
Behavior is the same.
handgunowner
handgunowner
  • 5
  • 4
  • 2
3 Solutions
MrVoidCommented:
Did you already check the Power Management settings in the OS. Try turning all the power settings to never. Also how do the brightness FN keys effect it?
handgunownerAuthor Commented:
The FN-brightness keys work normally (as long as the monitor is up).  The power settings are all never.  The FN-brightness keys have no effect on the second monitor if connected.
MrVoidCommented:
Is there any settings in the BIOS for APM or advanced power management?
Concerto Cloud for Software Providers & ISVs
Can Concerto Cloud Services help you focus on evolving your application offerings, while delivering the best cloud experience to your customers? From DevOps to revenue models and customer support, the answer is yes!
Learn how Concerto can help you.
nobusCommented:
it can be the lcd screen, backlight or inverter as well, since it produces more light when running from AC
can you swap these for testing ?
LCD screen, inverter, as well as keyboard and motherboard have been swapped out.  I won't be able to check the BIOS/APM until tomorrow.
I find it odd that it works fine on battery power, but not on AC.
nobusCommented:
agreed - me too
>>  I have replaced the motherboard, inverter, LCD monitor, and keyboard.  <<    then i suppose you missed one somewhere, unless you have 2 with the same problem !
Seeing that the motherboard, inverter, monitor, and keyboard are new, I'm going to get a new video ribbon cable for it.  The secondary monitors are analog, while the internal screen is digital...different technologies...probably why the external monitor works fine.
nobusCommented:
looks reasonable
I blew out the profiles and rebuilt them, and the problem (mostly) went away.  It still flickers when booting, but then stabilizes when someone logs in.  Left it on for days, and it worked fine.  I just got the video ribbon and will replace that for giggles.
nobusCommented:
here another idea : boot from a live cd and test if it does it then
if so - your OS or drivers are bad
ftp://ftp.kernel.org/pub/dist/knoppix/KNOPPIX_V6.0.1CD-2009-02-08-EN.iso
  • 5
  • 4
  • 2
