Solved
Problems with IIS7, HTTPS, FBA and WSS3.0
Posted on 2010-01-13
Last Modified: 2012-05-08
I am unable to get a https site working properly. I want that if a user go to https://portal.domain.com, he needs to login with FBA authentication.
Situation:
I have a WSS3.0 site running on a Windows 2008 server with IIS7.
SharePoint:80 is the default site with Windows Authentication. This is for internal usage
I extended the webapplication to port 1010.
WIth AAM I set for the extranet zone to https://portal.domain.com and I configured this part for FBA.
If I am trying to go to localhost:1010, FBA works fine. But if I go to https://portal.domain.com, I got the Windows Authention box.
I assume, it something to do with IIS7, but I cannot figure out what. Can somebody help me? Thanks in advance!
Question by:rseabird
  • 2
3 Comments
LVL 15
Expert Comment
by:Tray896
This may just be an IE setting.  Do you get the windows authentication prompt both from the server and when browsing from your machine?  Try adding portal.domain.com to your trusted sites in IE.  If this is only happening from the server, then the likely cause is a security 'feature' that Microsoft introduced on 2003 server.  You can read about that issue and the fix here on my blog: http://geekswithblogs.net/WorldofTray/archive/2009/03/25/fix-you-receive-a-401.1-error-when-browsing-a-web.aspx
LVL 8
Author Comment
by:rseabird
I don't think it's an IE setting. Going to https://portal.domain.com just go straight to the sharepoint:80 website, which uses windows authentication. It doesn't go to the sharepoint:1010 website (which is an extended website of sharepoint:80).
I don't understand why this could be a security feature.
LVL 8
Accepted Solution
by:
rseabird earned 0 total points
I found the solution via another way.
My extended web application needed to be bind to port 443. During extending the web application I needed to 'use an existing IIS web site'. And, of course, I needed a certificate...
I thought I'd write this up for anyone who has a request to create an anonymous whistle-blower-type submission form created using SharePoint 2010 (this would probably work the same for 2013). It's not 100% fool-proof but it's as close as you can get…
When using a search centre, I'm going to show you how to configure Sharepoint's search to only return results from the current site collection. Very useful when using Office 365 with multiple site collections.
This Micro Tutorial will teach you how to add a cinematic look to any film or video out there. There are very few simple steps that you will follow to do so. This will be demonstrated using Adobe Premiere Pro CS6.
Whether it be Exchange Server Crash Issues, Dirty Shutdown Errors or Failed to mount error, Stellar Phoenix Mailbox Exchange Recovery has always got your back. With the help of its easy to understand user interface and 3 simple steps recovery proced…
564 members asked questions and received personalized solutions in the past 7 days.
Join & Ask a Question
