Split a form into 3 or 4 parts.
emi_sastra
emi_sastra used Ask the Experts™
on
Hi All,
I want split windows form into 3 or 4 parts.
I also want those parts will resize automatically when its form is resized.
How could I do it ?
Thank you.
Watch Question
Do more with
Expert Office
ǩa̹̼͍̓̂ͪͤͭ̓u͈̳̟͕̬ͩ͂̌͌̾̀ͪf̭̤͉̅̋͛͂̓͛̈m̩̘̱̃e͙̳͊̑̂ͦ̌ͯ̚d͋̋ͧ̑ͯ͛̉Glanced up at my screen and thought I had coded the Matrix...  Turns out, I just fell asleep on the keyboard.
Most Valuable Expert 2011
Top Expert 2015
Have you tried a TableLayoutPanel? You can dock the panel to the form so it fills the working region, then add three panels to the TableLayoutPanel, putting each in a different cell and docking it to the cell. Set the RowSpan/ColumnSpan property for the panel which you would like to be the larger panel.
Top Expert 2015
By "three panels" above I mean three regular panels, not another three TableLayoutPanels :)
Hi kaufmed,
It is interesting.
Let me try first.
Thank you.
Rowby Goren Makes an Impact on Screen and Online
Learn about longtime user Rowby Goren and his great contributions to the site. We explore his method for posing questions that are likely to yield a solution, and take a look at how his career transformed from a Hollywood writer to a website entrepreneur.
Top Expert 2015
No problem  :)
I have tried it.
I use one TableLayoutPanel and three panels (groupbox plus panel).
It works.
Just curios why you suggest TableLayoutPanel, not SplitContainer ?
Thank you.
Top Expert 2015
I think either would do, but I knew that TableLayoutPanel would give you the option of Row/Column spanning. You could still achive the same thing with SplitContainer. Also, SplitContainer would allow the user to resize the panels using the "splitter". You can, of course, disable this, but if that is something you are after, then I would probably go the SplitContainer route. Just nest a SplitContainer inside of another to achive 3 sections.
Would you please guide me how to split SplitContainer into three parts (top, middle and bottom) ?
I have tried it before but failed to do so.
Thank you.
Top Expert 2015
Hmmm...
I was on a different line of thinking. So you want a form with 3 horizontal sections. I personally would stick with TableLayoutPanel and just give it 3 rows and no columns, but since you asked for SplitContainer...
Add a SplitContainer to your form and dock it to the form, if not already. Then choose on of either of its panels and add another SplitContainer to it, docking it to that panel. Like:
I have tried, it becomes three part, but in vertical not horizontal?
Thank you.
Top Expert 2015
Oh, sorry about that. If you select each SplitContainer, you will find a Property called "Orientation." Change that from Vertical to Horizontal.
It works.
Now, I have two options control to be use (SplitContainer  and TableLayoutPanel).
Thank you very much for your help.
Top Expert 2015
NP. Sorry for the initial confusion, but glad it ultimately worked out for you :)
Do more with
Expert Office
Start 7-Day Free Trial
