I need help finding a driver for my Sony TV Tuner Capture card
1namyln
1namyln used Ask the Experts™
on
I have a Sony Desktop computer that I've recently had to reload due to viruses.  I'm missing a driver for the capture card and I'm unable to find the driver on Sony's website.  My PC model number is PCV-RS724G.  I've listed the device information below.  I'm running Windows XP Home Edition.  Thanks in advance.
Video Controller (VGA Compatiable) PCI\VEN_8086&DEV_2582&SUBSYS_819C104D&REV_04\3&11583659&0&10
Multimedia Video Controller  PCI\VEN_4444&DEV_0016&SUBSYS_813D104D&REV_01\4&23C0B1C&0&28F0
Watch Question
Do more with
Expert Office
From what I read on this forum:
http://forums.afterdawn.com/thread_view.cfm/5/223993
This driver should work. The forum thread also talks about using Sage software with it. I guess you also need the correct capture software??? I don't know. Anyway, try this:
http://www.cc.utah.edu/~scm8/files/mpeg_encoder_1_1_4_6020.zip
BTW... you may want to read through the forum a little as there is another link (on the same page I believe) that claims to have another driver.
Jackie Man IT Manager
Top Expert 2010
Flubbster, the .zip file worked for the multimedia controller.  I was mistaken though about the Video driver.  I didn't have it installed already.  The file I'm missing is the video driver.  I was able to download and install the chipset driver for this PC but it didn't include the VGA driver.  This I was unable to find on Sony's site.
Look here: Based on the pci/dev numbers you posted. Says these are the vga video drivers for the intel chipset you installed.
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Graphics&ProductLine=Desktop+graphics+controllers&ProductProduct=Intel%c2%ae+82915G%2f82910GL+Express+Chipset+Family
Thanks a ton!!!  Fast response and easy to use.  Thanks again.
Do more with
Expert Office
Start 7-Day Free Trial
