How to read Facebook wall posts using Visual Basic
onemorecoke
onemorecoke used Ask the Experts™
on
Has any attempted to read wall posts from your Facebook account via Visual basic or ASP?
Watch Question
Do more with
Expert Office
Top Expert 2005
ASP has the server side XMLHTTP object so:
Set objXMLHTTP = Server.CreateObject("Microsoft.XMLHTTP")
objXMLHTTP.Open "GET", "http://www.facebook.com/????????????????????, False
objXMLHTTP.Send
Set HTML = objXMLHTTP.responseText
But how you get to your page (e.g. the correct URL) and login others will need to help you with.
It's easy, you just need to parse the content. And there are a lot of different ways of doing it.
One, use the webbrowser1.navigate method, get the page contents (i.e., innerHTML), then parse the data. Alternatively, you can use the DOM and navigate the elements.
But programming wise, you will need to spend at least 2-3 hours to get a working program.
Do more with
Expert Office
Start 7-Day Free Trial
