Using Distinct in Entity frame work need urgent help
I am using entity frame work to get the things from database.
Actually i want to use distinct to get data from the view so i am coding like the following but i am getting an error can you please help me.
var test = (from t in details()
where t.id = id
select t.name,t.date,t.number).distinct();
but the above code is not working and it is giving me error at the place of t.name,t.date,t.number.
i mean it is not showing even to select t.date and next one.
Can you please help me in this situation.
Thanks in advance.
If you have any questions let me know .I will explain the question clearly.
Thanks.
Not exactly the question you had in mind?
Sign up for an EE membership and get your own personalized solution. With an EE membership, you can ask unlimited troubleshooting, research, or opinion questions.
I tried it and it's working fine.I am not getting any build errors but unfortunately i did not have data to check the output.
But i think this will work.
When i get the data i will check and if anything wrong i will ask you again.
Thank you so much.
Chpk,
Fernando Soto
Not a problem, always glad to help. ;=)
Thank you so much.
Chpk,
