Which PCI-E fibre cards will work or are compatible with a IBM DS4100 (2GB Fibre) storage unit?
Storage
jvutechnc
jvutechnc
Even though the fibre switch and storage enclosure are 2GB, I believe that an installed 4GB fibre adaptor in the computer will auto negotiate down to 2GB, right?
jvutechnc
Hmmmm...the 4100 spec sheet shows support for old PCI-X cards. Does this mean that PCI-E cards will not work? SANXpressKitDS4300.pdf
