artradis
Gigabit LAN switch - casacde cable more efficient than CAT6 cross cable?
I have 4 Gigabit LAN switches with one central (star config) switch and 3 other switches connected to it in a star config.
We run several streaming data apps and sometimes the user session connection (to apps server) gets dropped, I suspect it is due to heavy load on the LAN.
Should we change to switches with backplan cuscade cable which I suspect is much more efficient than using CAT6 cbales to join all the switches?
Also which managed 48port GBE switch is able to cuscade?
Cheers
Joo
Cheers
Joo
