Help with SQL Grouping
Hi..
I have the following table/data   I need to get the earliest sales date  by product.
PRODUCT        SALES           DATE
APPLES             20                 1/1/2010
BANANAS         5                  3/5/2009
APPLES            9                   2/9/2008
BANANAS            5                     11/29/2007
APPLES             4                   3/6/2007
THE RESULT SHOULD LOOK LIKE
APPLES     33   3/6/2007
BANANAS    10    11/29/2007
LVL 1
JElsterAsked:
Patrick MatthewsCommented:
SELECT Product, SUM(Sales) AS Sales, MIN([Date]) AS [Date]
FROM SomeTable
GROUP BY Product
Aneesh RetnakaranDatabase AdministratorCommented:
SELECT * FROM products p WHERE date = (SELECT MIN(date) FROM products p1 WHERE p1.Product = p.Product )
JElsterAuthor Commented:
what's the dff between these two?  thanks
Powerful Yet Easy-to-Use Network Monitoring
Identify excessive bandwidth utilization or unexpected application traffic with SolarWinds Bandwidth Analyzer Pack.
Try them both, and I think the difference will be readily apparent :)
dshrivallabhCommented:
Try this
DECLARE @Result TABLE
      Product varchar(20),
      Sales int,
      Date Datetime
INSERT @REsult VALUES('APPLES',20,'1/1/2010')
INSERT @REsult VALUES('BANANAS',5,'3/5/2009')
INSERT @REsult VALUES('APPLES',5,'11/29/2007')
INSERT @REsult VALUES('BANANAS',20,'1/1/2010')
INSERT @REsult VALUES('APPLES',4,'3/6/2007')
Select Product, Sales,Date from @Result
Where Date IN (Select MIN(Date) FROM @Result GROUP BY Product)
dshrivallabh,
1) Your suggestion will not return the right answer.  Indeed, if the second-lowest date for Product B is the same as the lowest for Product A, then your query will return at least two rows for Product B
2) Please explain how your suggestion is materially different from http:#a30057641, posted more than 8 hours earlier than yours
Patrick
Microsoft SQL Server 2005
