How to fix display problem of Ajax Tool Kit's Accordion when it is binded with Craigslist Feed?
I have solved the display problem: Instead of fetching feed directly from Craigslist, I am fetching data from Yahoo Pipe. I believe Yahoo Pipe takes care of many Rss syntax error, and I believe, originally I was having sometimes problem in my webpage as some elements were semantically incorrect at craigslist rss feed. But as now I am fetching data from Yahoo Pipe, the main problem is solved.
However, I have another question, which is at below:
I need some help. Please read my problem scenerio:
I made a webpage that utilizes .NET 3.5 C# and Ajax tool kit's Accordion control to show rss feed from Craigslist.
My question is:
how to modify an element of XDocument?
Please see the below code to understand my  question:
 var feeds = from feed in xdoc.Descendants(rss + "item")
                    select new
                        title = feed.Element(rss + "title").Value,
                        url = feed.Element(rss + "link").Value,
                        description = feed.Element(rss + "description").Value<------------------------***
        Accordion1.DataSource = feeds;
        Accordion1.DataBind();
My question is: after I get the value of description, title, url and save it into varriable feeds, how can I modify "descrition" of feeds?
An example would be: "description" has 1000 words, with images; I want to show only 500 words and no images. How to do this? I know I can use many string methods like Replace or remove,
but if I want to do multiple string operation on description, to show only specific contents, before it gets saved in "var feeds" or gets binded with "Accordion1", how to do that?
Another example can be, I want to replace some specific characters like & or - and also show only the first 100 words.  Say if the description node has "Mary has an Apple. Mary has a book. Mary is playing," I would like to show only 20 characters: "Mary has an Apple. M" and then bind the modified description with the Accodion.
Please tell me how to do multiple string operations on elements of XDocument before the var feed get binded with a control?
Please answer.
My latest code behind file is at below, where I am fetching Craigslist feed via Yahoo Pipe.
using System;
using System.Collections.Generic;
using System.Linq;
using System.Web;
using System.Web.UI;
using System.Web.UI.WebControls;
using System.Xml.Linq;
public partial class _Default : System.Web.UI.Page
    protected void Button1_Click(object sender, EventArgs e)
        XNamespace rss = "http://purl.org/rss/1.0/";
        string selectedValue = DropDownList1.SelectedValue;
        string url, firstPart, secondPart= null;
        if (selectedValue.Length == 0)
            url = "http://sfbay.craigslist.org/sof/index.rss";
        else
            firstPart = "http://sfbay.craigslist.org/search/sof?query=";
            secondPart = "&catAbbreviation=sof&format=rss";
            url = firstPart + selectedValue + secondPart;
        XDocument xdoc = XDocument.Load(url);
                    select new
        Int32 listCount = xdoc.Descendants(rss + "description").Count();
        Accordion1.SelectedIndex = -1;
    protected void Page_Load(object sender, EventArgs e)
        XDocument xdoc = XDocument.Load("http://pipes.yahoo.com/pipes/pipe.run?_id=78ecc6a683ee31295094af9ba5b66df4&_render=rss");
      //  XNamespace rss = "http://purl.org/rss/1.0/";
        var feeds = from feed in xdoc.Descendants("item")
                    select new
                        title = feed.Element("title").Value,
                        url = feed.Element("link").Value,
                        description = feed.Element("description").Value
<%@ Page Language="C#" AutoEventWireup="true"  CodeFile="Default.aspx.cs" Inherits="_Default" %>
<%@ Register Assembly="AjaxControlToolkit" Namespace="AjaxControlToolkit" TagPrefix="cc1" %>
<head runat="server">
    <title></title>
    <style type="text/css">
    .accordionHeader
    border: 1px solid #EBDDE2;
    color: white;
    background-color: 	#5E5A80;
	font-family: Arial, Sans-Serif;
	font-size: 12px;
	font-weight: bold;
    padding: 5px;
    margin-top: 5px;
    cursor: pointer;
.accordionContent
    border: 2px solid #EBDDE2;
    color: #444444;
	font-size: 12px;
    padding: 5px;
    margin-top: 5px;
#content
   width:700px;
   height:550px;
   overflow:auto;
    </style>
</head>
<body>
    <div>
        <asp:DropDownList ID="DropDownList1" runat="server">
            <asp:ListItem Value="">All Software/Qa/DBA Job</asp:ListItem>
            <asp:ListItem Value="Senior+Software+Engineer">Senior Software Engineer</asp:ListItem>
            <asp:ListItem Value="Junior+Software+Engineer">Junior Software Engineer</asp:ListItem>
            <asp:ListItem Value="ASP+.NET">ASP .NET</asp:ListItem>
            <asp:ListItem Value="Front+End+Engineer">Front End Engineer</asp:ListItem>
            <asp:ListItem Value="C%23+ASP+.NET">C# ASP .NET</asp:ListItem>
            <asp:ListItem Value="JAVA">Java</asp:ListItem>
            <asp:ListItem Value="PHP">PHP</asp:ListItem>
            <asp:ListItem Value="Ruby+On+Rails">Ruby on Rails</asp:ListItem>
            <asp:ListItem Value="Flash">Flash</asp:ListItem>
            <asp:ListItem Value="SQL">SQL</asp:ListItem>
            <asp:ListItem Value="Database">Database</asp:ListItem>
            <asp:ListItem Value="Perl">Perl</asp:ListItem>
            <asp:ListItem Value="COBOL">COBOL</asp:ListItem>
            <asp:ListItem Value="Web+2.0">Web 2.0</asp:ListItem>
            <asp:ListItem Value="Web+Developer">Web Developer</asp:ListItem>
            <asp:ListItem Value="Software+Developer">Software Developer</asp:ListItem>
            <asp:ListItem Value="Programmer Analyst">Programmer Analyst</asp:ListItem>
            <asp:ListItem Value="JavaScript">Java Script</asp:ListItem>
            <asp:ListItem Value="JQuery">JQuery</asp:ListItem>
        </asp:DropDownList>
        <asp:Button ID="Button1" runat="server" Text="Submit Query" onclick="Button1_Click"/>
    </div>
    <div id="content">
    <asp:ScriptManager ID="ScriptManager1" runat="server">
    </asp:ScriptManager>
    <cc1:Accordion ID="Accordion1" runat="server"
         HeaderCssClass="accordionHeader"
         HeaderSelectedCssClass="accordionHeader"
         ContentCssClass="accordionContent"
         AutoSize="None"
         FadeTransitions="true"
         TransitionDuration="250"
         FramesPerSecond="30"
         RequireOpenedPane="false"
         SuppressHeaderPostbacks="True"
         SelectedIndex="-1"
         <HeaderTemplate >
            <%# Eval("title") %>
         </HeaderTemplate>
         <ContentTemplate> <div id="accordionContent">
            <%#Eval("description")%></div>
         </ContentTemplate>
</cc1:Accordion>
<br /><br />
   </div>
    </form>
</body>
</html>
using System;
using System.Linq;
using System.Web;
        else
                    select new
        XDocument xdoc = XDocument.Load("http://sfbay.craigslist.org/sof/index.rss");
                    select new
LVL 3
ashley2009Asked:
ashley2009Author Commented:
Hello, I have also solved the second part of the problem: it seems that we can call a method from the query block:
                    select new
                        url = feed.Element("link").Value.Replace("http://us.rd.yahoo.com/dailynews/rss/topstories/*",""),
                        description = modify(feed.Element("description").Value),
                        date = feed.Element("pubDate").Value
    private object modify(string p)
        p = p.Replace("http://us.rd.yahoo.com/dailynews/rss/topstories/*", "");
        p = p.Replace("&", "&amp;");
        return p+"AHA";
Therefore, this problem is solved for now as I now know how to modify element that is inside of a block.
I had two questions:
First was:
And the second was:
how to do multiple string operation on an element of XDocument before that var feed object gets binded with some control.
I have solved both of the problem.
First One's solution:
By creating Yahoo Pipe for craigslist RSS feed, I got rid of problems that were coming from some specific craigslist entry.
Second One's Solution:
Now I know that a method can ne called from a query block. Therefore, I will be able to do string operation on an element before the feed object gets binded with some control.
Therefore, this question got resolved.
.NET Programming
