Need help with connect string for SQL DB created within Visual Studio 2008 and VB.Net
I'm having issues with the following VB code which is within a VB project in VS2008.
I've created a local SQL database within this project named contacts (and so it shows up at contacts.sdf) with a table named contacts.  This is a test program/project.  The table has firstname, lastname, emailaddress as fields.  It's for a simple test.
When I run the program below VS complains about the connection string (after "thinking" for quite a long period of time).  The exact error message is "replace the value of the connString variable with a connection string that is valid for your system."
Can anyone say what a valid connection string would be for this situation?
Imports System
Imports System.Data
Imports System.Data.SqlClient
Imports System.Windows.Forms
Public Class Form1
    Inherits System.Windows.Forms.Form
    Private dataAdapter As New SqlDataAdapter()
    Private bindingSource1 As New BindingSource()
    Private Sub Form1_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load
        ' Bind the DataGridView to the BindingSource
        ' and load the data from the database.
        Me.DataGridView1.DataSource = Me.bindingSource1
        GetData("select * from Contacts")
    End Sub
    Private Sub GetData(ByVal selectCommand As String)
        Try
            ' Specify a connection string. Replace the given value with a
            ' valid connection string for a Northwind SQL Server sample
            ' database accessible to your system.
            Dim connString As String = "Persist Security Info = False; Data Source = 'Contacts.sdf';"
            ' Create a new data adapter based on the specified query.
            Me.dataAdapter = New SqlDataAdapter(selectCommand, connString)
            Dim commandBuilder As New SqlCommandBuilder(Me.dataAdapter)
            ' Populate a new data table and bind it to the BindingSource.
            Dim table As New DataTable()
            '     table.Locale = System.Globalization.CultureInfo.InvariantCulture
            Me.dataAdapter.Fill(table)
            Me.bindingSource1.DataSource = table
            ' Resize the DataGridView columns to fit the newly loaded content.
            Me.DataGridView1.AutoResizeColumns(DataGridViewAutoSizeColumnsMode.AllCellsExceptHeader)
        Catch ex As SqlException
            MessageBox.Show("To run this example, replace the value of the " + _
                "connString variable with a connection string that is " + _
                "valid for your system.")
        End Try
    End Sub
End Class
LVL 1
Gene KlamerusTechnical ArchitectAsked:
SriVaddadiCommented:
As i see that is your message and the basic exception message. Please look at the ex.Message and see what is the original message.
Also try giving the full path of the contacts.sdf in the connection string
cyberkiwiCommented:
Like the other expert has said, try using full path for the sdf file.
Also, you don't need the quotes.
Finally, do not have spaces before and after the "=" signs
"Persist Security Info=False;Data Source=Contacts.sdf;"
halfbloodprinceCommented:
Try giving the connection string as follows:
Dim strConn As String = "server=YOURSERVERNAME;database=YOURDBNAME;uid=YOURSQLSERVERUSERNAME;pwd=YOURSQLSERVERPASSWORD"
Active Protection takes the fight to cryptojacking
While there were several headline-grabbing ransomware attacks during in 2017, another big threat started appearing at the same time that didn’t get the same coverage – illicit cryptomining.
Gene KlamerusTechnical ArchitectAuthor Commented:
Thanks for the suggestion on printing the ex.message.
The message I'm receiving is:
"A network-related or instance-specific error occurred while establishing a connection to SQL Server.  The server was not found or was not accessible.  Verify that the instance name is correct and that SQL Server is configured to allow remote connections. (provider: Named Pipes Provider, error: 40 - Could not open a connection to SQL Server)"
I created this database from within Visual Studio 2008.  Would I need to list server=localhost or something?
I went to the properties on this database, which I created within VS2008 and it has a property called "Connection String" with the value "Data Source=C:\Users\Gene\Desktop\Contacts\Contacts\Contacts.sdf"
so I modified my code to have the statement:
            Dim connString As String = "Data Source=C:\Users\Gene\Desktop\Contacts\Contacts\Contacts.sdf;"
which was copy and past from the property.
I get the same error message with tis.
I also tried this without the leading C: (but with the \Users....).  Same issue
Did you check the exception message? ex.message? That would be helpful to locate the issue
srikanthreddyn143Commented:
Out of that all your database is compact edition. You need to use SqlCe connection and command objects
Dim sqlConn As New SqlCeConnection("Data Source = "fullpath\test.sdf";PASSWORD=test")
http://msdn.microsoft.com/en-us/library/system.data.sqlserverce.sqlceconnection.connectionstring%28VS.80%29.aspx
cyberkiwiCommented:
re #32272599
Never put spaces between paramname and arg in connection strings
the ex.message is posted a few posts ago.  I always get the same message at this point.
I think sri may be onto something here.  This is a SQL database created within VS 2008 and VS is telling me that the provider is .NET Framework Data Provider for Microsoft SQL Server Compact 3.5
I'll give this a try and report back.
Sorry I missed that post. Try this
Dim connString As String = "Data Source=(local);Initial Catalog=C:\Users\Gene\Desktop\Contacts\Contacts\Contacts.sdf;Integrated Security=SSPI;"
Also check this site
http://www.connectionstrings.com
I think poster Sri...143 is close but he's providing a connection string and what I need to create is a data adapter as per the other code I've seen.  What would a data acapter for a SQL Server CE look like?
Okay,
So I'm going to ask something that is perhaps out of line, but...
Would anyone be able to put together the limited amount of code that would replace the code above, but actually work.
I would gladly pay a few bucks (paypal?) for something that works in the above scenario.  The scenario is VS 2008 vb.net talking to a database created in that same VS project to get data from a query and puts it on a datagridview.
I'm just apparently very thick, but I'm unable to use the right object types to do this.
I'm not aware if offering cash for solutions is outside the rules of experts-exchange or not (and I've been a member of EE for something like 5 yrs).  I've just never found myself in this sort of corner.
Okay,
sorry, hit the button twice.
I could send donuts instead...
Dim pSQL As String = ur sql
Dim dsResult As New Dataset
Dim da As SqlCeDataAdapter
da = New SqlCeDataAdapter(pSQL, sqlConn)
        da.Fill(dsResult)
get the sqlconn from my above comment.This is a pseudo code.
Are there special imports we need to include with tihs as well?
wtb typing skills...
cyberkiwiCommented:
C#
            String connString = @"Data Source=Database1.sdf;";
            // Create a new data adapter based on the specified query.
            SqlCeDataAdapter dataAdapter = new SqlCeDataAdapter("select name from person", connString);
            SqlCeCommandBuilder commandBuilder = new SqlCeCommandBuilder(dataAdapter);
            // Populate a new data table and bind it to the BindingSource.
            DataTable table = new DataTable();
            dataAdapter.Fill(table);
VB
            Dim connString as String
            connString = "Data Source=Database1.sdf;"
            Dim dataAdapter as SqlCeDataAdapter
            dataAdapter = New SqlCeDataAdapter("select name from person", connString)
            Dim commandBuilder as SqlCeCommandBuilder
            commandBuilder = New SqlCeCommandBuilder(dataAdapter)
            Dim table as DataTable
I left out the full path name, but you can drop it in the same folder as the \Debug executable location.
Note the sqlce* bits
i saw all kinds of various additional parameters for connect strings.
Since this DB is in my VS project and I'm running the application is this all I need (the name of the database)?
cyberkiwiCommented:
In a word - yes
Thanks so much to the experts.  With this help my son was able to get his code working.  Everyone was very responsive (which is why I come here) and super smart.
Thanks again.
.NET Programming
