psychic_zero
Samba Domain Controller join problem with error "Device attached to the system is not functioning"
I have a Samba Domain Controller + OpenLDAP in a server. Then I've setup new server and install Samba and OpenLDAP. Using LDAP Browser tools, I have export and import all the LDAP tree from old to new server and do the initial configuration and after that copy exact all the smb, openldap and smbldap-tools configuration from old server to the new server.
Then using other isolated network, I want to try this new migrated Domain Controller server, but when I want to join to this domain using WindowsXP, the error "Device attached to the system is not functioning". But if I open the server for sharing using command \\PDCSVR, I can access to the shared folder in this new server. Can anyone help me? Attached is the copy of smb.conf for my server.
#====================== Global Settings =====================================
[global]
workgroup = PDCSVR
server string = PRIMARY DOMAIN CONTROLER
interfaces = lo eth0
domain master = yes
domain logons = yes
preferred master = yes
os level = 255
wins support = yes
dns proxy = yes
remote announce = 10.23.10.255 10.23.11.255
remote browse sync = 10.23.10.255 10.23.11.255
log level = 0
log file = /var/log/samba/samba.log
max log size = 50
syslog = 0
passdb backend = ldapsam:ldap://127.0.0.1
ldap suffix = ou=OxObjects,dc=abc,dc=com,dc=my
ldap admin dn = cn=sambaadmin,ou=OxObjects,dc=abc,dc=com,dc=my
ldap user suffix = ou=users
ldap group suffix = ou=groups
ldap machine suffix = ou=computers
ldap passwd sync = yes
add machine script = smbldap-useradd -w "%u"
#add user script = smbldap-useradd "%u"
add group script = smbldap-groupadd "%g"
delete user script = smbldap-userdel "%u"
delete group script = smbldap-groupdel "%g"
add user to group script = smbldap-groupmod -m "%u" "%g"
delete user from group script = smbldap-groupmod -x "%u" "%g"
set primary group script = smbldap-usermod -g "%g" "%u"
admin users = root administrator @"Domain Admins"
guest ok = no
socket options = TCP_NODELAY SO_RCVBUF=8192 SO_SNDBUF=8192
logon script = default.bat
logon drive =
logon path =
logon home =
#name resolve order = wins lmhosts bcast
#lm announce = yes
#browse list = yes
# printing
printing = bsd
printcap name = /dev/null
#============================ Share Definitions ==============================
[homes]
comment = Home Directories
browseable = no
writable = yes
valid users = %S
[netlogon]
comment = Network Logon Service
path = /home/samba/netlogon
guest ok = yes
read only = no
create mask = 0664
directory mask = 0775
write list = @"domain admins"
force group = "domain admins"
[profiles]
path = /home/samba/profiles
read only = no
create mask = 0600
directory mask = 0700
nt acl support = yes
browseable = No
guest ok = Yes
profile acls = yes
csc policy = disable
force user = %U
valid users = %U "Domain Admins"
[regset]
path = /home/samba/regset
writeable = yes
force user = root
create mask = 0644
hide dot files = no
sync always = yes
[Public]
path = /home/samba/smbshares/public
comment = Public Shared Folder
create mask = 0770
directory mask = 2770
force group = "Domain Admins"
write list = @"Domain Admins"
[Applications]
path = /home/samba/smbshares/applications
comment = Application Sources
create mask = 0770
