Arabsoft_AD
problem between Edge and HUB in exchange 2010
Dear All,
I have install exchange 2010 hub/cas/mailbox in two servers and edge role in one server. I did the synchronization file from edge, imported in HUB server. When I make "Test- Edgesynchronization" I got the following error:
FailureDetails : The LDAP server is unavailable
DNS working fine between all servers, windows firewall is off in all servers.
I don't know, I read something related to the certificate in exchange edge!?
Please help
Please help
Edge not in DMZ, i now thisi is not right but it's not there
IS ADAM correctly installed on Edge server ?
and also above port should be opened no matter if you have your server in DMZ or not.
or try to import your Edge subscription file again to Hub server.
ADAM installed correctly, i think so, how to check that?
This is helpful, as well.
http://www.exchangelog.info/2007/05/ports-that-need-to-be-open-on-firewall.html
Have you run Start-EdgeSynchronization?
check the link it show how to install ADAM , you may check there , as well as check your DNS settings too
http://www.msexchange.org/articles_tutorials/exchange-server-2007/planning-architecture/uncovering-exchange-2007-edge-transport-server-part2.html
hi all,
i check the dns, start-edgesy..., network and all staff
i mentioned something related to certificate, can anyone help on that?
You need to open ports for the edge server to talk to the Hub server.
External
25/TCP
SMTP
Internal
25/TCP
SMTP
Internal
50389/TCP
LDAP
Internal
50636/TCP
LDAP
