sahanz
Jquery Help, Body on load
I'm using color box, light box plugin. http://colorpowered.com/colorbox/
This is the script.
$(document).ready(function (){
//Examples of how to assign the ColorBox event to elements
$(".example7").colorbox({w idth:"80%" , height:"80%", iframe:true, overlayClose: false});
so heres the html
<a class='example7' href="http://google.com">Outside Webpage (Iframe)</a>
So when click the link the popup appear, so what I want is, I want to open the popup on the page load. How can I do that ?
This is the script.
so heres the html
Thanks, is there anyway to make them work without the existing text link ?
