Primary key constraint violation problem using Insert in SQL Server Management Studio 2008
I am getting the following error when trying to insert new records into a table.
Msg 2627, Level 14, State 1, Line 7
Violation of PRIMARY KEY constraint 'MLFML_PK'. Cannot insert duplicate key in object 'dbo.MLFML'.
The statement has been terminated.
Here is my code:
declare @TODAY varchar(10)
SET @TODAY = (SELECT CONVERT(VARCHAR(10), GETDATE(), 101) AS [MM/DD/YYYY])
INSERT INTO MLFML (BOOK_QTY, CREATED_BY, DATE_CREATED, DATE_LAST_ACT, DATE_LAST_ISSUE, DATE_LAST_PHY, DATE_LAST_PRINT,
DATE_LAST_RECPT, MLFML_USER_1,  MLFML_USER_2, MLFML_USER_3, MLFML_USER_4, ON_HAND_QTY, OPERATOR_ID, PART_ID, PHYSICAL_QTY,
STOCK_LOCATION, STORES_CODE, DATE_LAST_UPDT,  TIME_LAST_UPDT,  DELETE_FLAG)
SELECT 0, 'SYS.DM', GETDATE(), @TODAY, NULL, @TODAY, NULL, @TODAY, 0, 0, '', '', PI.QUANTITY, 'SYS.DM', PI.PART_ID, 0, PI.TO_LOCATION,
PI.STORES_CODE,  convert(char(11),getdate(),101), convert(char(5),getdate(),108), 'N'
FROM PISTOCKTRANSFER PI, MLFML ML
WHERE ((PI.STORES_CODE <> ML.STORES_CODE) AND (PI.PART_ID <> ML.PART_ID) AND (PI.TO_LOCATION <> ML.STOCK_LOCATION))
The primary key is STORES_CODE, PART_ID, STOCK_LOCATION
I try and validate the records by using the following select:
SELECT * FROM MLFML ML
JOIN PISTOCKTRANSFER PI
ON PI.PART_ID = ML.PART_ID
WHERE (ML.STORES_CODE = PI.STORES_CODE) AND (ML.STOCK_LOCATION = PI.TO_LOCATION)
Of course I get 0 results from the above SELECT statement, however I get the primary key constraint when trying to insert.
Please help
LVL 1
rbmacctAsked:
CboudrozCommented:
you need to used left join or if not exists
-- whit a left join
SELECT
FROM
	PISTOCKTRANSFER PI
	left join MLFML ML
			and PI.STORES_CODE = ML.STORES_CODE
			and PI.STOCK_LOCATION = ML.STOCK_LOCATION
WHERE
	ml.PART_ID is null
-- whit if not exists
SELECT
FROM
	PISTOCKTRANSFER PI
WHERE
	not exists
			select
			from
				MLFML ML
			where
rbmacctAuthor Commented:
The problem is with the Insert, not the Select.
However, for information only, I did use the exact where clause with the "not exists" in my insert statement and still got the same error message.
CboudrozCommented:
--The problem is with the Insert, not the Select.
I know the select I sent was to put in the insert statement.
--However, for information only, I did use the exact where clause with the "not exists" in my insert statement and still got the same error message.
2 possibility,
1- your primary key is not STORES_CODE, PART_ID, STOCK_LOCATION
2- you have a trigger on the table MLFML  trying to insert something that create duplicate
SELECT
FROM
	PISTOCKTRANSFER PI
WHERE
	not exists
			select
			from
				MLFML ML
			where
Solution found.  Solution is as follows:
INSERT INTO MLFML (BOOK_QTY, CREATED_BY, DATE_CREATED, DATE_LAST_ACT, DATE_LAST_ISSUE, DATE_LAST_PHY, DATE_LAST_PRINT, DATE_LAST_RECPT, MLFML_USER_1,
MLFML_USER_2, MLFML_USER_3, MLFML_USER_4, ON_HAND_QTY, OPERATOR_ID, PART_ID, PHYSICAL_QTY, STOCK_LOCATION, STORES_CODE, DATE_LAST_UPDT,
SELECT 0, 'SYS.DM', GETDATE(), @TODAY, NULL, @TODAY, NULL, @TODAY, 0, 0, '', '', PI.QUANTITY, 'SYS.DM', PI.PART_ID, 0, PI.TO_LOCATION, PI.STORES_CODE,
WHERE NOT EXISTS (SELECT 1 FROM MLFML WHERE (STORES_CODE = PI.STORES_CODE) AND (PART_ID = PI.PART_ID) AND (STOCK_LOCATION = PI.TO_LOCATION)
Found solution elsewhere.  Updating posting with a solution that works.  Tried to award some points to Cboudroz but the system did not let me.  It was all or nothing.  It would not let me award partial points without awarding all the points.
Microsoft SQL Server 2008
