derekfurman
POWER SUPPLY and UPS BATTERY BACKUP
My computers power supply specs are:
Input Voltage: 115V AC to 230V AC
Output Voltage: 3.3V DC , 5V DC , 12V DC V1, 12V DC V2, -12V DC , 5V DC Standby
Current: 10A @ 115V AC - Input Current, 5.5A @ 230V AC - Input Current, 30A @ 3.3V DC - Output Current, 45A @ 5V DC - Output Current, 18A @ 12V DC - V1Output Current, 16A @ 12V DC - V2Output Current, 1A @ -12V DC - Output Current, 2.5A @ 5V DC - StandbyOutput Current
Output Power: 500 W
This is just home computer but I would prefer it did not just snap off in the case of a power outage
is this UPS battery back up adequate
UPS link
keep in mind I do not intend to continue working after the power outage I want the computer to power down as if I had told it to shut down normally.
Output Power: 500 W
UPS link
That is true, but I do not have a 500 watt supply in my desktop (300 watts or so). It has a couple of hard drives running. There is no way I would consider such a threadbare battery backup to keep it going. Remember, that is (likely) the peak output of the battery backup.
@derekfurman - you will be much better served with a decent (500W) UPS as we have both noted before.
... Thinkpads_User
... Thinkpads_User
Thank you
Thank you, and good luck going forward. ... Thinkpads_User
-J
