Solved
Display problem with TCoolbar in Delphi 2010 when not using runtime Themes in application
Posted on 2010-08-17
Last Modified: 2013-11-23
Since we use Delphi 2010 we're having a problem with all TCoolBar in our applications. We are not using the runtime Themes. The left part of the component (grip) is invisible and unavailable (no mouse pointer, no action). The content of the coolbar (TToolBar) works as usual.
When runtime themes are enabled in application, the coolbar works perfectly. Unfortunately we cannot use themes since some other components don't work correctly.
Does someone have a solution/workaround to this problem?
Question by:waeberd
2 Comments
LVL 38
Accepted Solution
by:
Geert Gruwez earned 2000 total points
I think borland uses a TControlbar instead of a TCoolbar
I remember I stopped using TCoolbar because of all the bugs
this is also what i find on google and in the embarcadero/borland qc
Author Comment
by:waeberd
Thanks a lot for your advice. I replaced my CoolBars with ControlBars, it doesn't work exactly the same (normal cursor on grip, toolbars size is fixed) but it's ok. Thanks!
Creating an auto free TStringList The TStringList is a basic and frequently used object in Delphi. On many occasions, you may want to create a temporary list, process some items in the list and be done with the list. In such cases, you have to…
In my programming career I have only very rarely run into situations where operator overloading would be of any use in my work.  Normally those situations involved math with either overly large numbers (hundreds of thousands of digits or accuracy re…
Loops Section Overview
Screencast - Getting to Know the Pipeline
Suggested Courses
Course of the Month13 days, 21 hours left to enroll
581 members asked questions and received personalized solutions in the past 7 days.
Join & Ask a Question
