Solved
drop index does not work for unique keys
Posted on 2010-08-19
8
Last Modified: 2012-05-10
what is the reason DROP index syntax is disabled for deleting unique keys (non PKs)
thanks
Question by:anushahanna
  • 4
  • 3
8 Comments
LVL 143
Assisted Solution
by:Guy Hengel [angelIII / a3]
Guy Hengel [angelIII / a3] earned 1700 total points
this is because the PK is relying on the underlying index for it's function.
imagine you had a 2GB table with a primary key, but no index on that column.
the primary key constraint would have to do a full table scan for each insert & update for that field value !!!
LVL 18
Assisted Solution
by:Cluskitt
Cluskitt earned 300 total points
If you want to drop the index (possibly for rebuilding it), then drop the constraint first.
LVL 6
Author Comment
by:anushahanna
even if PK and UK are both different? (example PK is on Col1 and UK is on Col3..)
Fill in the form and get your FREE NFR key NOW!
Veeam is happy to provide a FREE NFR server license to certified engineers, trainers, and bloggers.  It allows for the non‑production use of Veeam Agent for Microsoft Windows. This license is valid for five workstations and two servers.
LVL 143
Accepted Solution
by:
if you have a PK and a UK, you will also have 2 indexes, 1 index per UK or PK constraint.
for the rest, it's the same situation: the database engine will not allow to drop the index.
LVL 6
Author Comment
by:anushahanna
are you saying PK will be relying on the unique index, regardless if they are the same or 2 diff indexes?
LVL 6
Author Comment
by:anushahanna
will DROP INDEX syntax work sometimes and othertimes not, for UNIQUE Indexes?
LVL 143
Assisted Solution
no. let me clarify:
when you create a PK, sql server will create automatically create a index, for that PK constraint. and it will not let you drop that index.
when you create a UC (unique constraint), sql server will create automatically create a index, for that UC constraint. and it will not let you drop that index.
when you create whatever index, they will NOT be used for any PK or UC, and sql will let your drop that index without issues
this includes also unique indexes, as they are not created by a constraint as such
LVL 6
Author Comment
by:anushahanna
thanks angelIII, for the helpful explanation.
VIDEO: THE CONCERTO CLOUD FOR HEALTHCARE
Modern healthcare requires a modern cloud. View this brief video to understand how the Concerto Cloud for Healthcare can help your organization.
I have a large data set and a SSIS package. How can I load this file in multi threading?
When trying to connect from SSMS v17.x to a SQL Server Integration Services 2016 instance or previous version, you get the error “Connecting to the Integration Services service on the computer failed with the following error: 'The specified service …
This video shows how to set up a shell script to accept a positional parameter when called, pass that to a SQL script, accept the output from the statement back and then manipulate it in the Shell.
Via a live example, show how to extract information from SQL Server on Database, Connection and Server properties
Suggested Courses
581 members asked questions and received personalized solutions in the past 7 days.
Join & Ask a Question
