Welcome to Experts Exchange
Add your voice to the tech community where 5M+ people, just like you, are talking about what matters.
  • Help others & share knowledge
  • Earn cash & points
  • Learn & ask questions
Solved
Sun Blade 1000 - doesn't power up
Posted on 2010-08-28
5
Last Modified: 2013-12-28
My Sun Microsystems Sun Blade 1000 doesn't power up when I press the on button.  It acts like it has a blown fuse (if it had one).  I tried replacing the power supply and the power cord but no change.  Absolutely nothing happens when I press the on button.  Is there a fuse or a reset button somewhere?  Aside from trying a third power supply, what else can I try?
Question by:w6hr
  • 2
  • 2
5 Comments
LVL 6
Expert Comment
by:radnbne
A couple of things to check.....
1) Does the power cord actually have power?  Sometimes if a power supply goes and it is connected to a power board, it blows the power board as well.
2) Do you see any lights when you plug the power in?
3) what led up to you finding the fault?  Did it shutdown? Was it moved?
Author Comment
by:w6hr
1 - Yes the power cord has power - just to be sure I have tried 3 different cords.
2 - To there are no lights, either when I plug in the power or when I attempt to turn it on.  No sounds either.
3 - It hadn't been on for a few days - I moved it to my workbench to replace the DVD drive with a spare.  While still on the workbench I tried to start it up to make sure the DVD drive was working before returning it to its original position.  That's when I discovered that it wouldn't start up.
LVL 6
Accepted Solution
by:
radnbne earned 250 total points
General Fault Diagnosis Questions:
1) Have you removed the DVD drive again?  some devices if they are faulty can cause the power supply to appear faulty.
2) Have you checked the mainboard power is still connected properly, and has not been bumped?
3) Have you checked the power button is still connected to the mainboard? These are also bumped during installation of peripherals.
4) If you unplug everything except the mainboard and power switch do you get power?
LVL 9
Assisted Solution
by:amolg
amolg earned 250 total points
did u hear any sound when you push the power button. check the memory stick, if it is installed properly.
Author Comment
by:w6hr
radnbne
I tried removing the recently installed DVD drive and put it all back together.  And I'm pleased to report that it's back to normal (except for the DVD drive).  I'll tackle that next.  Thanks for your help.
PRTG Network Monitor: Intuitive Network Monitoring
Network Monitoring is essential to ensure that computer systems and network devices are running. Use PRTG to monitor LANs, servers, websites, applications and devices, bandwidth, virtual environments, remote systems, IoT, and many more. PRTG is easy to set up & use.
Suggested Solutions
More or less everybody in the IT market understands the basics of Networking, however when we start talking about Storage Networks, things get a bit dizzier, and this is where I would like to help.
this article is a guided solution for most of the common server issues in server hardware tasks we are facing in our routine job works. the topics in the following article covered are, 1) dell hardware raidlevel (Perc) 2) adding HDD 3) how t…
Learn how to navigate the file tree with the shell. Use pwd to print the current working directory: Use ls to list a directory's contents: Use cd to change to a new directory: Use wildcards instead of typing out long directory names: Use ../ to move…
This video shows how to set up a shell script to accept a positional parameter when called, pass that to a SQL script, accept the output from the statement back and then manipulate it in the Shell.
808 members asked questions and received personalized solutions in the past 7 days.
Join & Ask a Question
