I have a couple of questions regarding XML and doing a select query in SQL Server 2005. I need to extract some parts of a field and I need to end my query with a WHERE clause.
I first insert the XML file into a table like this:
INSERT INTO OrdersXML(xmlCol)
SELECT CONVERT (xml, A.Col1, 2)
FROM OPENROWSET( BULK '\\myfolder\Orders.xml', SINGLE_BLOB) AS A(Col1)
This is a sample of the CustomerInfo field containing the customer info. I need to extract the First Name, Last name, and Customer Number from this field.
<CustomerInfo>First Name = John
Last Name = Smith
CustomerNumber = 123456
shippingID = 654321
</CustomerInfo>
In this field, the labels are always going to be the same
First Name =
Last Name =
CustomerNumber =
shippingID =
Only the actual name, cust. number and ID changes. Also, notice there's a line break for each part.
And this is my select statement.
SELECT
c.value('(Shipping/Products/Product/CustomerInfo)[1]', 'varchar(200)'),--I need the First selected.
c.value('(Shipping/Products/Product/CustomerInfo)[1]', 'varchar(200)'),-- I need the Last Name selected.
c.value('(Shipping/Products/Product/CustomerInfot)[1]', 'varchar(200)'),-- I need the Customer Number selected.
c.value('(Shipping/Products/Product/SKU)[1]', 'varchar(10)'), -- This is will part of the WHERE statement.
c.value('(Billing/NameParts/FirstName)[1]', 'varchar(50)'),
c.value('(Billing/NameParts/LastName)[1]', 'varchar(50)'),
c.value('(Billing/Address/Street1)[1]', 'varchar(50)'),
c.value('(Billing/Address/Street2)[1]', 'varchar(50)'),
c.value('(Billing/Address/City)[1]', 'varchar(50)'),
c.value('(Billing/Address/State)[1]', 'varchar(2)'),
c.value('(Billing/Address/Code)[1]', 'varchar(6)'),
c.value('(Billing/Address/Country)[1]', 'varchar(10)'),
c.value('(Payment/CreditCard/Issuer)[1]', 'varchar(50)'),
c.value('(OrderDate)[1]', 'datetime'),
c.value('(ShopSiteTransactionID)[1]', 'varchar(300)'),
c.value('(OrderNumber)[1]', 'int'),
c.value('(Other/Comments)[1]', 'varchar(300)')
FROM OrdersXML CROSS APPLY XMLCol.nodes('AllOrders/Order') T(c)
Right now, if I run this select query I can get all the records. However, I need to be able to select only the records containing a certain SKU, so I will need a WHERE clause that looks for a particular SKU value. I don't know how to make this work.
Therefore, my selected records would like this:
John, Smith, 123456, BMW302, Donald, Trump, 1234 Hollywood Blvd, Los Angeles, ETC.
Does anyone knows how to accomplish this?
Thanks!
Thanks for replying. I believe you're in the right path. I tried what you suggested at first it did not work because I was looking for a particular SKU in a order containing 3 products. It was the second one.
Therefore, if I modify the where clause to:
WHERE c.value('(Shipping/Product
I guess I was not couting on the fact that someone can order more than one product in the same orderl.
How can I select the records based on All the products instead of the orders? I assuming the [1] in the Shipping/Products/Product/
