Front audio cable won't work
There is a HDaudio cable which is attached with the case.
I plugged in HDAudio cable to AAFP1 on the motherboard and plugged in the headphone to the case audio hole but it didn't work.
When I plug the headphone directly to the motherboard audio it works but when I plug the headphone to the case audio hole it doesn't work.
what is the problem?
my motherboard is P5B Deluxe
bt1942
bt1942
  • 4
  • 4
nobusCommented:
did you use this connector , as described in the manual?
and how is the sound set in the bios, AC97 or HD Audio ?
bt1942Author Commented:
I just used a cable that says "HDAUDIO" and plugged in to the AAFP1
as you can see the image I've also set the audio option to HD Audio in the bios
Free Tool: Site Down Detector
nobusCommented:
and the front panel connector, was it 1 block, or separate pins?  in the last case, verify the connections.
otherwise, you can have a bad contact, in the front panel cable(s) or connectors..
Never mine.
I had to go to the control panel and set the headphone as a "default device".
the problem is every time when I want to use the headphone I have to go to the control panel and manually configure the audio device.
How do I make this automatically?
What I want is when I plug the headphone to the case audio hole the system will automatically detects the headphone and change it to the headphone as a default device.
nobusCommented:
btw - i'm using a P5B-VM board
Problem Solved.
I just had to set the headphone as a "default device".
So whenever I unplug the headphone the sound will automatically come out from the speaker because there is no default device detected which is the headphone.
And when I plug the headphone again the system will detect headphone as a "default device" and the sound will come out from the headphone.
And Thanks for the comment nobus. your comment helped me to learn something which is the bios.
I didn't know there was a audio option(HD Audio and AC97) in the bios and because of your comment I know now. Thanks.
nobusCommented:
glad to hel p
Join & Write a Comment
  • 4
  • 4
