Printing with MFC sometime result in missing parts
I am writing a program in MFC that prints very large drawings. I am using standard printing methods, and uses the same drawing code for screen and for printing. Most of the time this works fine, but with very large drawings parts og my print is missing. The error never occurs on the screen. Missing parts appears to be random, and I cannot reproduce the problem. It happens also when using other printers, like printing to pdf. What could I be doing wrong?
Ruskialt
Ruskialt
  • 7
  • 5
pgnatyukCommented:
You need to show the code.
You need to explain more. "standard printing methods" says nothing. I can guess that you use GDI (or an MFC wrapper) to draw an image. If it is so, probably, there is a GDI leak in the drawing procedure. For example, a bitmap forgotten in the device context.
RuskialtAuthor Commented:
I have created a Doc/View project in VS6, and do all my drawing is in OnDraw(CDC* pDC). I use the standard printing functionality built into the template that creates the doc/view project. So I don't know what code to show, as I cannot point to anything special.
Is it possible there is a limit to how much data can be sent to the printer?
pgnatyukCommented:
I don't think so. How big is the image you are drawing? If it's too big for the printing, it is for the screen view drawing too. Do you create an internal bitmap? How big is it?
Usually the problem is in OnDraw(CDC* pDC) method. Check that you don't have a GDI leak there. If you say that this is a random bug, it's most likely a leak.
Beside OnDraw you use other methods: OnPreparePrinting, OnBeginPrinting, OnPrepareDC?
There is a leak/s in one of these methods.
We value your feedback.
pgnatyukCommented:
Here is an article about the MFC printing (VS6):
http://www.dotnetheaven.com/Uploadfile/mahesh/MFCPrinting05242005051835AM/MFCPrinting.aspx
There is a code attached too.
How can I check for leaks, any typical GDI leaks/pitfalls?
pgnatyukCommented:
If you have Bound Checker, it will show everything.
You can simply check GDI objects in Task Manager, so you will see the counter for your process.
There is a special tool GDIView (?): http://www.nirsoft.net/utils/gdi_handles.html
You can verify your code:
1. If you cal GetDC, you need to call ReleaseDC when you already don't need this DC.
2. If you call CreateDC, CreateCompatibleDC, you call DeleteDC in the end.
3. If you create a bitmap or a font, delete them.
4. If you select a bitmap,a font in a DC, you save the old GDI object and restore it in the end.
The last item is very important. Almost always the leak is there. The DC object is not deleted if it contains a bitmap or a font. So if you have:
HDC hDC = GetDC(hWnd);
HDC hMemDC = CreateCompatibleBitmap(hDC);
HBITMAP hOldBitmap = (HBITMAP)SelectObject(hMemDC, m_hBitmap);
do not forget:
SelectObject(hMemDC, hOldBitmap);
DeleteDC(hMemDC);
ReleaseDC(hWnd, hDC);
I got notified on inactive question. I am still working with your suggestions. I found no leaks in task managers gdi object count, does this mean that 1, 2 and 3 is no problem? (Still searching my code for violations to all of this) What is Bound checker?
pgnatyukCommented:
It's a commercial product. Use Google. The price is about 1000$.
But... it's really inactive question. You say that you used a task manager and didn't find any leak with the GDI counter. Please do not think that it's sarcasm, but it's not serious. If you really tried that, you saw that this counter changes all the time. Probably its value is about 100-200. Let's say before this problematic print operation the value was 154. When the printing finished it's 154 again. If it is so, your application is perfect and you can be proud and show the printing code here.
pgnatyukCommented:
You can use GDIView: http://www.nirsoft.net/utils/gdi_handles.html
It's not Bound Checker, but it will detect the leaks.
Brilliant thinking
Thanks for all your help. I am still digging through my codes looking for any of your suggestions. It is a large project, and I have other tasks at work to, so progress on this is a little slow. I have found some leaks, but have yet to conclude that this fixes the printing problem. However I want to close this and dedicate my points to excellent answers and suggestions.
pgnatyukCommented:
Thank you too.
Good luck.
  • 7
  • 5
