Solved
Can't connect to my wireless using Realtek RTL8191SE Wireless LAN 802.11n PCI-E NIC
Posted on 2010-09-19
27
Last Modified: 2013-12-09
I am using Realtek RTL8191SE Wireless LAN 802.11n PCI-E NIC  for my Toshiba laptop. I cannot connect to my Linsky wireless. My other computers connect with no problem.  It is Windows 7 64 bit.   I get this:
Connection-specific DNS Suffix:
Description: Realtek RTL8191SE Wireless LAN 802.11n PCI-E NIC
Physical Address: ¿1C-65-9D-16-B2-75
DHCP Enabled: Yes
Autoconfiguration IPv4 Address: 169.254.149.20
IPv4 Subnet Mask: 255.255.0.0
IPv4 Default Gateway:
IPv4 DNS Server:
IPv4 WINS Server:
NetBIOS over Tcpip Enabled: Yes
Link-local IPv6 Address: fe80::5cc7:85e2:6a23:9514%14
IPv6 Default Gateway:
IPv6 DNS Servers: fec0:0:0:ffff::1%1, fec0:0:0:ffff::2%1, fec0:0:0:ffff::3%1
I know I'm not supposed to have the 169 address but I reset the modem and I still get it.  I don't have any virus protection on it yet. I searched realtek and it said I have the best driver installed.
I went here as suggested:
http://www.intel.com/support/wireless/wlan/sb/cs-010623.htm
It says it doesn't recognize the driver as an Intel driver. I see the name of my wireless and I put in my security code.
What do I have to do to connect?
Question by:artismobile
[X]
Welcome to Experts Exchange
Add your voice to the tech community where 5M+ people just like you are talking about what matters.
  • Help others & share knowledge
  • Earn cash & points
  • Learn & ask questions
  • 13
  • 11
  • 3
27 Comments
LVL 95
Expert Comment
by:John Hurst
First, the 169.x.x.x address is an autoconnect error address which means your Windows 7 machine is not really trying to connect.
Second, Windows 7 64-bit (Pro I assume) works perfectly well (in general) with wireless. I have such a machine and it is connected wirelessly to do this.
So:
1. Try to update the wireless driver on your card. Get a new driver, uninstall the old one, restart and install the new one (even if the same version). Get the driver from Toshiba it the laptop came preinstalled with Windows 7. If not, get the driver from the card vendor.
2. Update the firmware in your LinkSys router and see if you can connect.
3. Try the laptop on another wireless router (friend, office, etc.)
If none of the above work, consider replacing the wireless card with a genuine Intel card.
... Thinkpads_User
LVL 6
Expert Comment
by:dreamcomputer2000
This is a problem that a lot of us have had. After a lot of searching this is what I found to work.
Uninstall Windows Search Assistant 4.0 and the update WindowsServer2003.WindowsXP-KB963093-x86-ENU.exe. Then run Microsoft update and unselect those two items from the advanced list so they become "Hidden".
I noticed this after setting up 2 identical HP 1410s laptops, they worked out of the box until I did updates.
LVL 95
Expert Comment
by:John Hurst
Search in Windows 7 is integrated and is not uninstallable (at least not on my Windows 7 machines). But Search should have no impact on wireless, at least not in my experience with IBM machines. Strange if it does.
... Thinkpads_User
Everything You Need to Know about Petya 2.0
Get an overview of the what, when and how of Petya 2.0  from our threat analyst Marc Labilerte, as well as a look at how WatchGuard Total Security Suite protected our customers from the recent attack!
LVL 6
Expert Comment
Sorry, I should have said "turned off windows search" in "Turn Windows features on or off".
I couldn't see how search would make a difference either but I started uninstalling the updates one at a time and kept checking my connection.
Author Comment
by:artismobile
I uninstalled reltek and added an Intel driver. It still says no valid IP address.
O.k. I don't know how to Uninstall Windows Search Assistant 4.0 and the update WindowsServer2003.WindowsXP-KB963093-x86-ENU.exe. Then run Microsoft update and unselect those two items from the advanced list so they become "Hidden"
What are the steps and where do I find this?
Thank you
LVL 95
Expert Comment
by:John Hurst
If you are convinced your router works with Windows 7, then I think you may have to try a new wireless card. I am using machines certified for Windows 7 and search doesn't have anything to do with wireless.
... Thinkpads_User
Author Comment
by:artismobile
Well, I'm not convinced. It is a brand new laptop and I am running wireless with 2 computers on xp and one on Vista I tried to update my WRT610n Linksys but I can't find it so far
LVL 95
Expert Comment
by:John Hurst
Try to go back to the laptop manufacturer for wireless drivers. I looked a fair bit through Google and the only Intel drivers that come up with Realtek are Chipset drivers. Chipset drivers are important, but they are not wireless drivers at all, and if your laptop is brand new, then it would have chipset drivers already.
Try to get the Toshiba supplied wireless driver for your make and model of Toshiba machine.
I had to change my wireless card from Atheros to Intel with this machine I am on (Thinkpad T61p) came with Vista. IBM supplied drivers for Vista and then again for Windows 7 64-bt when I installed it.
... Thinkpads_User
LVL 6
Expert Comment
To turn off Search, Control Panel>Programs and Features>Turn Windows Features on or off--scroll down and uncheck windows search.
To uninstall the update: Control Panel>Programs and Features>view installed updates, choose the update from the list, choose uninstall.
to run updates: Start>All Programs>Windows Update>Custom, when the list fills look for the update in question and uncheck it.
Author Comment
by:artismobile
I updated the wireless adapter for Toshiba. I don't know if it installed but I still don't have wireless. I won't be able to try another wireless until tomorrow. Is the problem my router won't accept WIndows 7?
I don't see a windows search in this list It is installing 29 updates now
Author Comment
by:artismobile
I have tried uninstalling the adapter and reinstalling several different ways and it won't work
LVL 95
Expert Comment
by:John Hurst
I think you should call Toshiba support. While I have not used Toshiba recently, any brand name laptop I have used including older Toshiba models will work out of the box with the wireless card supplied by the manufacturer.
You could have a bad card. The router could be an issue (seen that before). Try the computer at another router to get a better idea. .... Thinkpads_User
Author Comment
by:artismobile
Good idea. I will try to pickup a transmittion from a  wireless router somewhere and advise.
Author Comment
by:artismobile
I do have a Linksys N Ultra range Plus wireless N USB network adapter with dual band.  If I use this, will that bypass my laptop's internal wireless card?
Author Comment
by:artismobile
Nope, that didn't work either...
LVL 95
Expert Comment
by:John Hurst
So now you have tried a different wireless card and that did not work.  Yuo can disable the on-board card, so yes, the new NIC will bypass the internal card.
Try with a different wireless router (take the laptop to a friend or an office) and see if it works.
... Thinkpads_User
Author Comment
by:artismobile
It was a USB plug in.  The green light lit up but still gave me the same errors. I will try your latest suggestion today at a coffee shop.
Thanks for staying with me on this
Author Comment
by:artismobile
It does work on a different wireless router. Just tried at the local library and was able to connect to the internet.
What's the next step?
LVL 95
Expert Comment
by:John Hurst
That news suggests your router is suspect. I did have to replace my own wireless router when I moved from an XP laptop to a Vista laptop. The same new router supports Windows 7 when I moved to that. You seem to have nailed the router as the cause, so either ask the router vendor for newer firmware, or consider a new router (with a return guarantee if it does not work). ... Thinkpads_User
Author Comment
by:artismobile
Thanks for the answers.  Well, at least I know it's my Router now. I'll try a download for the Lynksys WRT610n.  Haven't had it long. I have Windows XP, and Vista running through it. I guess Windows 7 is giving it a strain.
LVL 95
Accepted Solution
by:
John Hurst earned 500 total points
Another approach is to see of you can get a used wireless G router (local ads, eBay, etc.). I use my Windows 7 Wireless at a number of places and it works everywhere.
You have tried two network cards with two sets of drivers and you know it works at another place. So the above is an approach to get going and to eventually have a spare router. .... Thinkpads_User
Author Comment
by:artismobile
O.k.  I just spent and hour on line with Linksys help. They say I need to reset my router BUT since it is not under warranty, I need to call a 800 number be charged $30.00 then they will tell me how.  Sad! Needless to say, I'm done with Cisco/Linksys. I cussed them out and I feel better.
O.k. If I get a wireless used G router form somewhere, will my other computers, Vista, windows XP and windows 7 work? Is there another option like a new router (not Linksys) I can buy today to have all the computers on a wireless network?
LVL 95
Expert Comment
by:John Hurst
There are lots of non-LinkSys routers new and used around. Belkin makes decent routers (I have used them), so also does Netgear (I have not used them).  I don't care for D-Link but others like them. ... Thinkpads_User
Author Comment
by:artismobile
ok but is there a chance that it will not work with Windows 7?  I the main problem here is that thys Linksys will not ork with Windows 7?
LVL 95
Expert Comment
by:John Hurst
There is always a chance of anything, so see if you can purchase locally, explain your issue, and be sure of a money back guarantee if you cannot make it work. ... Thinkpads_User
Author Comment
by:artismobile
Well, The laptop does work...I'll go get another or used router and see. I'll close this out for your points and repost later.  Thank you. You have been very helpful.
LVL 95
Expert Comment
by:John Hurst
Thanks. I was pleased to assist you. Good luck going forward. ... Thinkpads_User
SharePoint Admin?
Enable Your Employees To Focus On The Core With Intuitive Onscreen Guidance That is With You At The Moment of Need.
For Sennheiser, comfort, quality and security are high priority areas. This paper addresses the security of Bluetooth technology and the supplementary security that Sennheiser’s Contact Center and Office (CC&O) headsets provide.
DECT technology has become a popular standard for wireless voice communication. DECT devices are not likely to be affected by other electronic devices and signals because they operate in a separate frequency-band.
Viewers will learn how to connect to a wireless network using the network security key. They will also learn how to access the IP address and DNS server for connections that must be done manually. After setting up a router, find the network security…
After creating this article (http://www.experts-exchange.com/articles/23699/Setup-Mikrotik-routers-with-OSPF.html), I decided to make a video (no audio) to show you how to configure the routers and run some trace routes and pings between the 7 sites…
Suggested Courses
717 members asked questions and received personalized solutions in the past 7 days.
Join & Ask a Question
