exchange 2010 EMC and Powershell not connecting and initializing - WS-ADMIN service will not start HELP !!!!!!!!
sibensiben
sibensiben
  • 51
  • 42
  • 3
  • +1
endital1097Commented:
please post logs from event viewer when the attempted start of this service fails
sibensibenAuthor Commented:
getting an error 1079
here is event log
Log Name:      System
Source:        Service Control Manager
Date:          9/22/2010 9:36:29 AM
Event ID:      7000
Task Category: None
Level:         Error
Keywords:      Classic
User:          N/A
Computer:      server01.temp-art.net
Description:
The Windows Remote Management (WS-Management) service failed to start due to the following error:
The account specified for this service is different from the account specified for other services running in the same process.
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
  <System>
    <Provider Name="Service Control Manager" Guid="{555908d1-a6d7-4695-8e1e-26931d2012f4}" EventSourceName="Service Control Manager" />
    <EventID Qualifiers="49152">7000</EventID>
    <Version>0</Version>
    <Level>2</Level>
    <Task>0</Task>
    <Opcode>0</Opcode>
    <Keywords>0x8080000000000000</Keywords>
    <TimeCreated SystemTime="2010-09-22T13:36:29.929529700Z" />
    <EventRecordID>20272</EventRecordID>
    <Correlation />
    <Execution ProcessID="600" ThreadID="9732" />
    <Channel>System</Channel>
    <Computer>server01.temp-art.net</Computer>
    <Security />
  </System>
  <EventData>
    <Data Name="param1">Windows Remote Management (WS-Management)</Data>
    <Data Name="param2">%%1079</Data>
  </EventData>
</Event>Bottom of Form
go into services
view the properties of "Windows Remote Management (WS-Management)"
verify that the startup is "Automatic (Delayed Start)"
on the logon tab make sure it is using "Network Service"
on the dependencies tab make sure it is dependent on HTTP and RPC
Creating Active Directory Users from a Text File
If your organization has a need to mass-create AD user accounts, watch this video to see how its done without the need for scripting or other unnecessary complexities.
ok i got ws-management to star by adding the network service account to it....
emc will still not connect
still getting the 500 poowershell connect error
ok, so the service is now running and we can focus on powershell, correct?
go into iis manager
select the powershell vdir
open authentication and ensure anonymous is the only enabled option
open ssl settings and ensure require ssl is disabled
any update?
uninstalled and installed winrm iis ran winrm -qc  winrm and ws-management are working but emc still gives me the 500 error
did all that same result 500 error
what is the proper way to remove the powershell vdir and recreate it... I am thinking this is the next step
kerbauth and wsman should be modules in the powershell vdir right but not in default website correct ?
i haven't seen any documentation on that, since typically all vdirs are recreated using... powershell :(
they even have a new-powershellvirtualdirectory cmdlet
couple more items to check
within the powershell vdir, check the HTTP redirect (make sure nothing is enabled)
browse to C:\Program Files\Microsoft\Exchange Server\V14\ClientAccess\PowerShell
check the permissions on hte web.config file ensuring authenticated users have read
correct on the modules
http 500 is typically a permissions issue or ISAPI
checked permissions they have them... any other thoughts ?
here is what is in the actual web.cfg file
<?xml version="1.0" encoding="UTF-8"?>
<configuration>
    <system.webServer>
        <modules>
            <remove name="kerbauth" />
            <add name="kerbauth" />
            <add name="WSMan" />
        </modules>
    </system.webServer>
</configuration>
restored the old web.config which had ALOT more in it including all the exchange references and now when I go to browse i get a 401 in iis.... i checked permissions and they were good on this... i remember this problem was easy to fix but i have no idea how i did it last time i thought it was a permissions issue
check the iis authentication settings
where is the 401 being shown
what happens when you attempt to open the exchange management shell
401 is shown when i do a browse to in iis on http and on https in the powershell vdir
same error 500 on emc
401 is expected when browsing with IE
can you try to start the management shell
can you also post images if possible of the errors
i think we're close, but i feel blind :)
tried getting same error... i will get some images
thanks, at this point i think it would be easier to see
ok here are a couple
here is the web.config i restored
<configuration>
  <appSettings>
    <add key="PSLanguageMode" value="RestrictedLanguage" />
  </appSettings>
  <system.webServer>
    <system.management.wsmanagement.config>
      <PluginModules>
        <OperationsPlugins>
          <Plugin Name="PowerShellplugin" Filename="%windir%\system32\pwrshplugin.dll" SDKVersion="1" XmlRenderingType="text">
            <Resources>
              <Resource ResourceUri="http://schemas.microsoft.com/powershell/Microsoft.Exchange" SupportsOptions="true">
                <Capability Type="Shell" />
              </Resource>
            </Resources>
            <InitializationParameters>
              <Param Name="PSVersion" Value="2.0" />
              <Param Name="ApplicationBase" Value="%ExchangeInstallPath%Bin" />
              <Param Name="AssemblyName" Value="Microsoft.Exchange.Configuration.ObjectModel.dll" />
              <Param Name="PSSessionConfigurationTypeName" Value="Microsoft.Exchange.Configuration.Authorization.ExchangeAuthorizationPlugin" />
              <Param Name="PSMaximumReceivedObjectSizeMB" Value="75" />
              <Param Name="PSMaximumReceivedDataSizePerCommandMB" Value="500" />
            </InitializationParameters>
          </Plugin>
        </OperationsPlugins>
        <AuthorizationPlugin Name="Microsoft.Exchange.AuthorizationPlugin" Filename="%ExchangeInstallPath%Bin\Microsoft.Exchange.AuthorizationPlugin.dll" SDKVersion="1" SupportsQuota="true" />
      </PluginModules>
      <OperationsConfiguration MaxOperationTimeoutSeconds="900" MaxShellIdleTimeoutMinutes="15" />
    </system.management.wsmanagement.config>
    <modules>
      <add name="CertificateAuthModule" type="Microsoft.Exchange.Configuration.CertificateAuthentication.CertificateAuthenticationModule" />
      <add name="EMCVersionBlockerModule" type="Microsoft.Exchange.Configuration.RedirectionModule.EMCVersionBlockerModule" />
      <add name="ErrorReportingModule" type="Microsoft.Exchange.Configuration.RedirectionModule.ErrorReportingModule" />
    </modules>
  </system.webServer>
  <system.web>
    <authentication mode="Windows" />
    <compilation debug="true">
      <assemblies>
        <add assembly="Microsoft.Exchange.Configuration.RedirectionModule, Version=14.0.0.0, Culture=neutral, publicKeyToken=31bf3856ad364e35" />
        <add assembly="Microsoft.Exchange.Configuration.CertificateAuth, Version=14.0.0.0, Culture=neutral, publicKeyToken=31bf3856ad364e35" />
        <add assembly="Microsoft.Exchange.Data, Version=14.0.0.0, Culture=neutral, publicKeyToken=31bf3856ad364e35" />
        <add assembly="Microsoft.Exchange.Data.Directory, Version=14.0.0.0, Culture=neutral, publicKeyToken=31bf3856ad364e35" />
      </assemblies>
    </compilation>
  </system.web>
  <runtime>
    <assemblyBinding xmlns="urn:schemas-microsoft-com:asm.v1">
      <dependentAssembly>
        <assemblyIdentity name="Microsoft.Exchange.Configuration.RedirectionModule" publicKeyToken="31bf3856ad364e35" culture="neutral" />
        <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\Microsoft.Exchange.Configuration.RedirectionModule.dll" />
      </dependentAssembly>
      <dependentAssembly>
        <assemblyIdentity name="Microsoft.Exchange.Configuration.CertificateAuth" publicKeyToken="31bf3856ad364e35" culture="neutral" />
        <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\Microsoft.Exchange.Configuration.CertificateAuth.dll" />
     <dependentAssembly>
        <assemblyIdentity name="Microsoft.Exchange.Data" publicKeyToken="31bf3856ad364e35" culture="neutral" />
        <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\Microsoft.Exchange.Data.dll" />
      <dependentAssembly>
        <assemblyIdentity name="Microsoft.Exchange.Sqm" publicKeyToken="31bf3856ad364e35" culture="neutral" />
        <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\Microsoft.Exchange.Sqm.dll" />
      <dependentAssembly>
        <assemblyIdentity name="Microsoft.Exchange.Data.Storage" publicKeyToken="31bf3856ad364e35" culture="neutral" />
        <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\Microsoft.Exchange.Data.Storage.dll" />
      <dependentAssembly>
        <assemblyIdentity name="Microsoft.Exchange.StoreProvider" publicKeyToken="31bf3856ad364e35" culture="neutral" />
        <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\Microsoft.Exchange.StoreProvider.dll" />
      <dependentAssembly>
        <assemblyIdentity name="Microsoft.Exchange.Data.Directory" publicKeyToken="31bf3856ad364e35" culture="neutral" />
        <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\Microsoft.Exchange.Data.Directory.dll" />
     <dependentAssembly>
        <assemblyIdentity name="Microsoft.Exchange.Diagnostics" publicKeyToken="31bf3856ad364e35" culture="neutral" />
        <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\Microsoft.Exchange.Diagnostics.dll" />
      <dependentAssembly>
        <assemblyIdentity name="Microsoft.Exchange.Net" publicKeyToken="31bf3856ad364e35" culture="neutral" />
        <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\Microsoft.Exchange.Net.dll" />
      <dependentAssembly>
        <assemblyIdentity name="Microsoft.Exchange.Common" publicKeyToken="31bf3856ad364e35" culture="neutral" />
        <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\Microsoft.Exchange.Common.dll" />
      <dependentAssembly>
        <assemblyIdentity name="Microsoft.Exchange.Core.Strings" publicKeyToken="31bf3856ad364e35" culture="neutral" />
        <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\Microsoft.Exchange.Core.Strings.dll" />
      <dependentAssembly>
        <assemblyIdentity name="Microsoft.Exchange.Rpc" publicKeyToken="31bf3856ad364e35" culture="neutral" />
        <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\Microsoft.Exchange.Rpc.dll" />
      <dependentAssembly>
        <assemblyIdentity name="Microsoft.Exchange.Extensibility.Internal" publicKeyToken="31bf3856ad364e35" culture="neutral" />
        <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\Microsoft.Exchange.Extensibility.Internal.dll" />
      <dependentAssembly>
        <assemblyIdentity name="Microsoft.Exchange.Common.IL" publicKeyToken="31bf3856ad364e35" culture="neutral" />
        <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\Microsoft.Exchange.Common.IL.dll" />
      <dependentAssembly>
        <assemblyIdentity name="Microsoft.Exchange.StructuredQuery" publicKeyToken="31bf3856ad364e35" culture="neutral" />
        <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\Microsoft.Exchange.StructuredQuery.dll" />
      <dependentAssembly>
        <assemblyIdentity name="Microsoft.Exchange.Data.ThrottlingService.Client" publicKeyToken="31bf3856ad364e35" culture="neutral" />
        <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\Microsoft.Exchange.Data.ThrottlingService.Client.dll" />
      <dependentAssembly>
        <assemblyIdentity name="Microsoft.Exchange.Data.Storage.ClientStrings" publicKeyToken="31bf3856ad364e35" culture="neutral" />
        <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\Microsoft.Exchange.Data.Storage.ClientStrings.dll" />
      <dependentAssembly>
        <assemblyIdentity name="Microsoft.Exchange.OfflineRms" publicKeyToken="31bf3856ad364e35" culture="neutral" />
        <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\Microsoft.Exchange.OfflineRms.dll" />
      <dependentAssembly>
        <assemblyIdentity name="Microsoft.DKM.Proxy" publicKeyToken="31bf3856ad364e35" culture="neutral" />
        <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\Microsoft.DKM.Proxy.dll" />
      <dependentAssembly>
         <assemblyIdentity name="Microsoft.Exchange.Compliance" publicKeyToken="31bf3856ad364e35" culture="neutral" />
         <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\Microsoft.Exchange.Compliance.dll" />
      <dependentAssembly>
        <assemblyIdentity name="Microsoft.RightsManagementServices.Core" publicKeyToken="31bf3856ad364e35" culture="neutral" />
        <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\Microsoft.RightsManagementServices.Core.dll" />
      <!-- Resource DLLs -->
      <dependentAssembly>
        <assemblyIdentity name="Microsoft.Exchange.Configuration.RedirectionModule.resources" publicKeyToken="31bf3856ad364e35" culture="ar" />
        <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\ar\Microsoft.Exchange.Configuration.RedirectionModule.resources.dll" />
      <dependentAssembly>
        <assemblyIdentity name="Microsoft.Exchange.Configuration.RedirectionModule.resources" publicKeyToken="31bf3856ad364e35" culture="cs" />
        <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\cs\Microsoft.Exchange.Configuration.RedirectionModule.resources.dll" />
      <dependentAssembly>
        <assemblyIdentity name="Microsoft.Exchange.Configuration.RedirectionModule.resources" publicKeyToken="31bf3856ad364e35" culture="da" />
        <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\da\Microsoft.Exchange.Configuration.RedirectionModule.resources.dll" />
      <dependentAssembly>
        <assemblyIdentity name="Microsoft.Exchange.Configuration.RedirectionModule.resources" publicKeyToken="31bf3856ad364e35" culture="de" />
        <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\de\Microsoft.Exchange.Configuration.RedirectionModule.resources.dll" />
      <dependentAssembly>
        <assemblyIdentity name="Microsoft.Exchange.Configuration.RedirectionModule.resources" publicKeyToken="31bf3856ad364e35" culture="el" />
        <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\el\Microsoft.Exchange.Configuration.RedirectionModule.resources.dll" />
      <dependentAssembly>
        <assemblyIdentity name="Microsoft.Exchange.Configuration.RedirectionModule.resources" publicKeyToken="31bf3856ad364e35" culture="en" />
        <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\en\Microsoft.Exchange.Configuration.RedirectionModule.resources.dll" />
      <dependentAssembly>
        <assemblyIdentity name="Microsoft.Exchange.Configuration.RedirectionModule.resources" publicKeyToken="31bf3856ad364e35" culture="es" />
        <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\es\Microsoft.Exchange.Configuration.RedirectionModule.resources.dll" />
      <dependentAssembly>
        <assemblyIdentity name="Microsoft.Exchange.Configuration.RedirectionModule.resources" publicKeyToken="31bf3856ad364e35" culture="fi" />
        <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\fi\Microsoft.Exchange.Configuration.RedirectionModule.resources.dll" />
      <dependentAssembly>
        <assemblyIdentity name="Microsoft.Exchange.Configuration.RedirectionModule.resources" publicKeyToken="31bf3856ad364e35" culture="fr" />
        <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\fr\Microsoft.Exchange.Configuration.RedirectionModule.resources.dll" />
      <dependentAssembly>
        <assemblyIdentity name="Microsoft.Exchange.Configuration.RedirectionModule.resources" publicKeyToken="31bf3856ad364e35" culture="he" />
        <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\he\Microsoft.Exchange.Configuration.RedirectionModule.resources.dll" />
      <dependentAssembly>
        <assemblyIdentity name="Microsoft.Exchange.Configuration.RedirectionModule.resources" publicKeyToken="31bf3856ad364e35" culture="hu" />
        <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\hu\Microsoft.Exchange.Configuration.RedirectionModule.resources.dll" />
      <dependentAssembly>
        <assemblyIdentity name="Microsoft.Exchange.Configuration.RedirectionModule.resources" publicKeyToken="31bf3856ad364e35" culture="it" />
        <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\it\Microsoft.Exchange.Configuration.RedirectionModule.resources.dll" />
      <dependentAssembly>
        <assemblyIdentity name="Microsoft.Exchange.Configuration.RedirectionModule.resources" publicKeyToken="31bf3856ad364e35" culture="ja" />
        <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\ja\Microsoft.Exchange.Configuration.RedirectionModule.resources.dll" />
      <dependentAssembly>
        <assemblyIdentity name="Microsoft.Exchange.Configuration.RedirectionModule.resources" publicKeyToken="31bf3856ad364e35" culture="ko" />
        <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\ko\Microsoft.Exchange.Configuration.RedirectionModule.resources.dll" />
      <dependentAssembly>
        <assemblyIdentity name="Microsoft.Exchange.Configuration.RedirectionModule.resources" publicKeyToken="31bf3856ad364e35" culture="nl" />
        <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\nl\Microsoft.Exchange.Configuration.RedirectionModule.resources.dll" />
      <dependentAssembly>
        <assemblyIdentity name="Microsoft.Exchange.Configuration.RedirectionModule.resources" publicKeyToken="31bf3856ad364e35" culture="no" />
        <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\no\Microsoft.Exchange.Configuration.RedirectionModule.resources.dll" />
      <dependentAssembly>
        <assemblyIdentity name="Microsoft.Exchange.Configuration.RedirectionModule.resources" publicKeyToken="31bf3856ad364e35" culture="pl" />
        <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\pl\Microsoft.Exchange.Configuration.RedirectionModule.resources.dll" />
      <dependentAssembly>
        <assemblyIdentity name="Microsoft.Exchange.Configuration.RedirectionModule.resources" publicKeyToken="31bf3856ad364e35" culture="pt" />
        <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\pt\Microsoft.Exchange.Configuration.RedirectionModule.resources.dll" />
      <dependentAssembly>
        <assemblyIdentity name="Microsoft.Exchange.Configuration.RedirectionModule.resources" publicKeyToken="31bf3856ad364e35" culture="ru" />
        <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\ru\Microsoft.Exchange.Configuration.RedirectionModule.resources.dll" />
      <dependentAssembly>
        <assemblyIdentity name="Microsoft.Exchange.Configuration.RedirectionModule.resources" publicKeyToken="31bf3856ad364e35" culture="sv" />
        <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\sv\Microsoft.Exchange.Configuration.RedirectionModule.resources.dll" />
      <dependentAssembly>
        <assemblyIdentity name="Microsoft.Exchange.Configuration.RedirectionModule.resources" publicKeyToken="31bf3856ad364e35" culture="th" />
        <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\th\Microsoft.Exchange.Configuration.RedirectionModule.resources.dll" />
      <dependentAssembly>
        <assemblyIdentity name="Microsoft.Exchange.Configuration.RedirectionModule.resources" publicKeyToken="31bf3856ad364e35" culture="tr" />
        <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\tr\Microsoft.Exchange.Configuration.RedirectionModule.resources.dll" />
      <dependentAssembly>
        <assemblyIdentity name="Microsoft.Exchange.Configuration.RedirectionModule.resources" publicKeyToken="31bf3856ad364e35" culture="zh-Hans" />
        <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\zh-Hans\Microsoft.Exchange.Configuration.RedirectionModule.resources.dll" />
      <dependentAssembly>
        <assemblyIdentity name="Microsoft.Exchange.Configuration.RedirectionModule.resources" publicKeyToken="31bf3856ad364e35" culture="zh-Hant" />
        <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\zh-Hant\Microsoft.Exchange.Configuration.RedirectionModule.resources.dll" />
      <!-- Common ClientString resources -->
      <dependentAssembly>
          <assemblyIdentity name="microsoft.exchange.core.strings.resources" publicKeyToken="31bf3856ad364e35" culture="ar" />
          <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\ar\microsoft.exchange.core.strings.resources.dll" />
      <dependentAssembly>
          <assemblyIdentity name="microsoft.exchange.core.strings.resources" publicKeyToken="31bf3856ad364e35" culture="bg" />
          <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\bg\microsoft.exchange.core.strings.resources.dll" />
      <dependentAssembly>
          <assemblyIdentity name="microsoft.exchange.core.strings.resources" publicKeyToken="31bf3856ad364e35" culture="ca" />
          <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\ca\microsoft.exchange.core.strings.resources.dll" />
      <dependentAssembly>
          <assemblyIdentity name="microsoft.exchange.core.strings.resources" publicKeyToken="31bf3856ad364e35" culture="cs" />
          <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\cs\microsoft.exchange.core.strings.resources.dll" />
      <dependentAssembly>
          <assemblyIdentity name="microsoft.exchange.core.strings.resources" publicKeyToken="31bf3856ad364e35" culture="da" />
          <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\da\microsoft.exchange.core.strings.resources.dll" />
      <dependentAssembly>
          <assemblyIdentity name="microsoft.exchange.core.strings.resources" publicKeyToken="31bf3856ad364e35" culture="de" />
          <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\de\microsoft.exchange.core.strings.resources.dll" />
      <dependentAssembly>
          <assemblyIdentity name="microsoft.exchange.core.strings.resources" publicKeyToken="31bf3856ad364e35" culture="el" />
          <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\el\microsoft.exchange.core.strings.resources.dll" />
      <dependentAssembly>
          <assemblyIdentity name="microsoft.exchange.core.strings.resources" publicKeyToken="31bf3856ad364e35" culture="en" />
          <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\en\microsoft.exchange.core.strings.resources.dll" />
      <dependentAssembly>
          <assemblyIdentity name="microsoft.exchange.core.strings.resources" publicKeyToken="31bf3856ad364e35" culture="en-AU" />
          <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\en-AU\microsoft.exchange.core.strings.resources.dll" />
      <dependentAssembly>
          <assemblyIdentity name="microsoft.exchange.core.strings.resources" publicKeyToken="31bf3856ad364e35" culture="en-CA" />
          <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\en-CA\microsoft.exchange.core.strings.resources.dll" />
      <dependentAssembly>
          <assemblyIdentity name="microsoft.exchange.core.strings.resources" publicKeyToken="31bf3856ad364e35" culture="en-GB" />
          <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\en-GB\microsoft.exchange.core.strings.resources.dll" />
      <dependentAssembly>
          <assemblyIdentity name="microsoft.exchange.core.strings.resources" publicKeyToken="31bf3856ad364e35" culture="en-IN" />
          <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\en-IN\microsoft.exchange.core.strings.resources.dll" />
      <dependentAssembly>
          <assemblyIdentity name="microsoft.exchange.core.strings.resources" publicKeyToken="31bf3856ad364e35" culture="es" />
          <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\es\microsoft.exchange.core.strings.resources.dll" />
      <dependentAssembly>
          <assemblyIdentity name="microsoft.exchange.core.strings.resources" publicKeyToken="31bf3856ad364e35" culture="es-MX" />
          <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\es-MX\microsoft.exchange.core.strings.resources.dll" />
      <dependentAssembly>
          <assemblyIdentity name="microsoft.exchange.core.strings.resources" publicKeyToken="31bf3856ad364e35" culture="et" />
          <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\et\microsoft.exchange.core.strings.resources.dll" />
      <dependentAssembly>
          <assemblyIdentity name="microsoft.exchange.core.strings.resources" publicKeyToken="31bf3856ad364e35" culture="eu" />
          <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\eu\microsoft.exchange.core.strings.resources.dll" />
      <dependentAssembly>
          <assemblyIdentity name="microsoft.exchange.core.strings.resources" publicKeyToken="31bf3856ad364e35" culture="fa" />
          <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\fa\microsoft.exchange.core.strings.resources.dll" />
      <dependentAssembly>
          <assemblyIdentity name="microsoft.exchange.core.strings.resources" publicKeyToken="31bf3856ad364e35" culture="fi" />
          <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\fi\microsoft.exchange.core.strings.resources.dll" />
      <dependentAssembly>
          <assemblyIdentity name="microsoft.exchange.core.strings.resources" publicKeyToken="31bf3856ad364e35" culture="fil-PH" />
          <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\fil-PH\microsoft.exchange.core.strings.resources.dll" />
      <dependentAssembly>
          <assemblyIdentity name="microsoft.exchange.core.strings.resources" publicKeyToken="31bf3856ad364e35" culture="fr" />
          <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\fr\microsoft.exchange.core.strings.resources.dll" />
      <dependentAssembly>
          <assemblyIdentity name="microsoft.exchange.core.strings.resources" publicKeyToken="31bf3856ad364e35" culture="fr-CA" />
          <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\fr-CA\microsoft.exchange.core.strings.resources.dll" />
      <dependentAssembly>
          <assemblyIdentity name="microsoft.exchange.core.strings.resources" publicKeyToken="31bf3856ad364e35" culture="gl" />
          <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\gl\microsoft.exchange.core.strings.resources.dll" />
      <dependentAssembly>
          <assemblyIdentity name="microsoft.exchange.core.strings.resources" publicKeyToken="31bf3856ad364e35" culture="he" />
          <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\he\microsoft.exchange.core.strings.resources.dll" />
      <dependentAssembly>
          <assemblyIdentity name="microsoft.exchange.core.strings.resources" publicKeyToken="31bf3856ad364e35" culture="hi" />
          <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\hi\microsoft.exchange.core.strings.resources.dll" />
      <dependentAssembly>
          <assemblyIdentity name="microsoft.exchange.core.strings.resources" publicKeyToken="31bf3856ad364e35" culture="hr" />
          <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\hr\microsoft.exchange.core.strings.resources.dll" />
      <dependentAssembly>
          <assemblyIdentity name="microsoft.exchange.core.strings.resources" publicKeyToken="31bf3856ad364e35" culture="hu" />
          <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\hu\microsoft.exchange.core.strings.resources.dll" />
      <dependentAssembly>
          <assemblyIdentity name="microsoft.exchange.core.strings.resources" publicKeyToken="31bf3856ad364e35" culture="id" />
          <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\id\microsoft.exchange.core.strings.resources.dll" />
      <dependentAssembly>
          <assemblyIdentity name="microsoft.exchange.core.strings.resources" publicKeyToken="31bf3856ad364e35" culture="is" />
          <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\is\microsoft.exchange.core.strings.resources.dll" />
      <dependentAssembly>
          <assemblyIdentity name="microsoft.exchange.core.strings.resources" publicKeyToken="31bf3856ad364e35" culture="it" />
          <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\it\microsoft.exchange.core.strings.resources.dll" />
      <dependentAssembly>
          <assemblyIdentity name="microsoft.exchange.core.strings.resources" publicKeyToken="31bf3856ad364e35" culture="ja" />
          <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\ja\microsoft.exchange.core.strings.resources.dll" />
      <dependentAssembly>
          <assemblyIdentity name="microsoft.exchange.core.strings.resources" publicKeyToken="31bf3856ad364e35" culture="kk" />
          <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\kk\microsoft.exchange.core.strings.resources.dll" />
      <dependentAssembly>
          <assemblyIdentity name="microsoft.exchange.core.strings.resources" publicKeyToken="31bf3856ad364e35" culture="ko" />
          <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\ko\microsoft.exchange.core.strings.resources.dll" />
      <dependentAssembly>
          <assemblyIdentity name="microsoft.exchange.core.strings.resources" publicKeyToken="31bf3856ad364e35" culture="lt" />
          <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\lt\microsoft.exchange.core.strings.resources.dll" />
      <dependentAssembly>
          <assemblyIdentity name="microsoft.exchange.core.strings.resources" publicKeyToken="31bf3856ad364e35" culture="lv" />
          <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\lv\microsoft.exchange.core.strings.resources.dll" />
      <dependentAssembly>
          <assemblyIdentity name="microsoft.exchange.core.strings.resources" publicKeyToken="31bf3856ad364e35" culture="ms" />
          <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\ms\microsoft.exchange.core.strings.resources.dll" />
      <dependentAssembly>
          <assemblyIdentity name="microsoft.exchange.core.strings.resources" publicKeyToken="31bf3856ad364e35" culture="no" />
          <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\no\microsoft.exchange.core.strings.resources.dll" />
      <dependentAssembly>
          <assemblyIdentity name="microsoft.exchange.core.strings.resources" publicKeyToken="31bf3856ad364e35" culture="nl" />
          <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\nl\microsoft.exchange.core.strings.resources.dll" />
      <dependentAssembly>
          <assemblyIdentity name="microsoft.exchange.core.strings.resources" publicKeyToken="31bf3856ad364e35" culture="pl" />
          <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\pl\microsoft.exchange.core.strings.resources.dll" />
      <dependentAssembly>
          <assemblyIdentity name="microsoft.exchange.core.strings.resources" publicKeyToken="31bf3856ad364e35" culture="pt" />
          <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\pt\microsoft.exchange.core.strings.resources.dll" />
      <dependentAssembly>
          <assemblyIdentity name="microsoft.exchange.core.strings.resources" publicKeyToken="31bf3856ad364e35" culture="pt-PT" />
          <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\pt-PT\microsoft.exchange.core.strings.resources.dll" />
      <dependentAssembly>
          <assemblyIdentity name="microsoft.exchange.core.strings.resources" publicKeyToken="31bf3856ad364e35" culture="ro" />
          <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\ro\microsoft.exchange.core.strings.resources.dll" />
      <dependentAssembly>
          <assemblyIdentity name="microsoft.exchange.core.strings.resources" publicKeyToken="31bf3856ad364e35" culture="ru" />
          <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\ru\microsoft.exchange.core.strings.resources.dll" />
      <dependentAssembly>
          <assemblyIdentity name="microsoft.exchange.core.strings.resources" publicKeyToken="31bf3856ad364e35" culture="sk" />
          <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\sk\microsoft.exchange.core.strings.resources.dll" />
      <dependentAssembly>
          <assemblyIdentity name="microsoft.exchange.core.strings.resources" publicKeyToken="31bf3856ad364e35" culture="sl" />
          <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\sl\microsoft.exchange.core.strings.resources.dll" />
      <dependentAssembly>
          <assemblyIdentity name="microsoft.exchange.core.strings.resources" publicKeyToken="31bf3856ad364e35" culture="sr" />
          <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\sr\microsoft.exchange.core.strings.resources.dll" />
      <dependentAssembly>
          <assemblyIdentity name="microsoft.exchange.core.strings.resources" publicKeyToken="31bf3856ad364e35" culture="sr-Cyrl-CS" />
          <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\sr-Cyrl-CS\microsoft.exchange.core.strings.resources.dll" />
      <dependentAssembly>
          <assemblyIdentity name="microsoft.exchange.core.strings.resources" publicKeyToken="31bf3856ad364e35" culture="sr-Latn-CS" />
          <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\sr-Latn-CS\microsoft.exchange.core.strings.resources.dll" />
      <dependentAssembly>
          <assemblyIdentity name="microsoft.exchange.core.strings.resources" publicKeyToken="31bf3856ad364e35" culture="sv" />
          <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\sv\microsoft.exchange.core.strings.resources.dll" />
      <dependentAssembly>
          <assemblyIdentity name="microsoft.exchange.core.strings.resources" publicKeyToken="31bf3856ad364e35" culture="th" />
          <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\th\microsoft.exchange.core.strings.resources.dll" />
      <dependentAssembly>
          <assemblyIdentity name="microsoft.exchange.core.strings.resources" publicKeyToken="31bf3856ad364e35" culture="tr" />
          <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\tr\microsoft.exchange.core.strings.resources.dll" />
      <dependentAssembly>
          <assemblyIdentity name="microsoft.exchange.core.strings.resources" publicKeyToken="31bf3856ad364e35" culture="uk" />
          <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\uk\microsoft.exchange.core.strings.resources.dll" />
      <dependentAssembly>
          <assemblyIdentity name="microsoft.exchange.core.strings.resources" publicKeyToken="31bf3856ad364e35" culture="ur" />
          <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\ur\microsoft.exchange.core.strings.resources.dll" />
      <dependentAssembly>
          <assemblyIdentity name="microsoft.exchange.core.strings.resources" publicKeyToken="31bf3856ad364e35" culture="vi" />
          <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\vi\microsoft.exchange.core.strings.resources.dll" />
      <dependentAssembly>
          <assemblyIdentity name="microsoft.exchange.core.strings.resources" publicKeyToken="31bf3856ad364e35" culture="zh-Hans" />
          <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\zh-Hans\microsoft.exchange.core.strings.resources.dll" />
      <dependentAssembly>
          <assemblyIdentity name="microsoft.exchange.core.strings.resources" publicKeyToken="31bf3856ad364e35" culture="zh-Hant" />
          <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\zh-Hant\microsoft.exchange.core.strings.resources.dll" />
      <dependentAssembly>
          <assemblyIdentity name="microsoft.exchange.core.strings.resources" publicKeyToken="31bf3856ad364e35" culture="zh-HK" />
          <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\zh-HK\microsoft.exchange.core.strings.resources.dll" />
      <!-- Throttling service client resources  -->
      <dependentAssembly>
          <assemblyIdentity name="Microsoft.Exchange.Data.ThrottlingService.Client.resources" publicKeyToken="31bf3856ad364e35" culture="neutral" />
          <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\Microsoft.Exchange.Data.ThrottlingService.Client.resources.dll" />
      <dependentAssembly>
          <assemblyIdentity name="Microsoft.Exchange.Data.ThrottlingService.Client.resources" publicKeyToken="31bf3856ad364e35" culture="ar" />
          <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\ar\Microsoft.Exchange.Data.ThrottlingService.Client.resources.dll" />
      <dependentAssembly>
          <assemblyIdentity name="Microsoft.Exchange.Data.ThrottlingService.Client.resources" publicKeyToken="31bf3856ad364e35" culture="bg" />
          <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\bg\Microsoft.Exchange.Data.ThrottlingService.Client.resources.dll" />
      <dependentAssembly>
          <assemblyIdentity name="Microsoft.Exchange.Data.ThrottlingService.Client.resources" publicKeyToken="31bf3856ad364e35" culture="ca" />
          <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\ca\Microsoft.Exchange.Data.ThrottlingService.Client.resources.dll" />
      <dependentAssembly>
          <assemblyIdentity name="Microsoft.Exchange.Data.ThrottlingService.Client.resources" publicKeyToken="31bf3856ad364e35" culture="cs" />
          <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\cs\Microsoft.Exchange.Data.ThrottlingService.Client.resources.dll" />
      <dependentAssembly>
          <assemblyIdentity name="Microsoft.Exchange.Data.ThrottlingService.Client.resources" publicKeyToken="31bf3856ad364e35" culture="da" />
          <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\da\Microsoft.Exchange.Data.ThrottlingService.Client.resources.dll" />
      <dependentAssembly>
          <assemblyIdentity name="Microsoft.Exchange.Data.ThrottlingService.Client.resources" publicKeyToken="31bf3856ad364e35" culture="de" />
          <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\de\Microsoft.Exchange.Data.ThrottlingService.Client.resources.dll" />
      <dependentAssembly>
          <assemblyIdentity name="Microsoft.Exchange.Data.ThrottlingService.Client.resources" publicKeyToken="31bf3856ad364e35" culture="el" />
          <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\el\Microsoft.Exchange.Data.ThrottlingService.Client.resources.dll" />
      <dependentAssembly>
          <assemblyIdentity name="Microsoft.Exchange.Data.ThrottlingService.Client.resources" publicKeyToken="31bf3856ad364e35" culture="en" />
          <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\en\Microsoft.Exchange.Data.ThrottlingService.Client.resources.dll" />
      <dependentAssembly>
          <assemblyIdentity name="Microsoft.Exchange.Data.ThrottlingService.Client.resources" publicKeyToken="31bf3856ad364e35" culture="es" />
          <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\es\Microsoft.Exchange.Data.ThrottlingService.Client.resources.dll" />
      <dependentAssembly>
          <assemblyIdentity name="Microsoft.Exchange.Data.ThrottlingService.Client.resources" publicKeyToken="31bf3856ad364e35" culture="et" />
          <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\et\Microsoft.Exchange.Data.ThrottlingService.Client.resources.dll" />
      <dependentAssembly>
          <assemblyIdentity name="Microsoft.Exchange.Data.ThrottlingService.Client.resources" publicKeyToken="31bf3856ad364e35" culture="eu" />
          <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\eu\Microsoft.Exchange.Data.ThrottlingService.Client.resources.dll" />
      <dependentAssembly>
          <assemblyIdentity name="Microsoft.Exchange.Data.ThrottlingService.Client.resources" publicKeyToken="31bf3856ad364e35" culture="fa" />
          <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\fa\Microsoft.Exchange.Data.ThrottlingService.Client.resources.dll" />
      <dependentAssembly>
          <assemblyIdentity name="Microsoft.Exchange.Data.ThrottlingService.Client.resources" publicKeyToken="31bf3856ad364e35" culture="fi" />
          <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\fi\Microsoft.Exchange.Data.ThrottlingService.Client.resources.dll" />
      <dependentAssembly>
          <assemblyIdentity name="Microsoft.Exchange.Data.ThrottlingService.Client.resources" publicKeyToken="31bf3856ad364e35" culture="fil-PH" />
          <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\fil-PH\Microsoft.Exchange.Data.ThrottlingService.Client.resources.dll" />
      <dependentAssembly>
          <assemblyIdentity name="Microsoft.Exchange.Data.ThrottlingService.Client.resources" publicKeyToken="31bf3856ad364e35" culture="fr" />
          <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\fr\Microsoft.Exchange.Data.ThrottlingService.Client.resources.dll" />
      <dependentAssembly>
          <assemblyIdentity name="Microsoft.Exchange.Data.ThrottlingService.Client.resources" publicKeyToken="31bf3856ad364e35" culture="gl" />
          <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\gl\Microsoft.Exchange.Data.ThrottlingService.Client.resources.dll" />
      <dependentAssembly>
          <assemblyIdentity name="Microsoft.Exchange.Data.ThrottlingService.Client.resources" publicKeyToken="31bf3856ad364e35" culture="he" />
          <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\he\Microsoft.Exchange.Data.ThrottlingService.Client.resources.dll" />
      <dependentAssembly>
          <assemblyIdentity name="Microsoft.Exchange.Data.ThrottlingService.Client.resources" publicKeyToken="31bf3856ad364e35" culture="hi" />
          <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\hi\Microsoft.Exchange.Data.ThrottlingService.Client.resources.dll" />
      <dependentAssembly>
          <assemblyIdentity name="Microsoft.Exchange.Data.ThrottlingService.Client.resources" publicKeyToken="31bf3856ad364e35" culture="hr" />
          <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\hr\Microsoft.Exchange.Data.ThrottlingService.Client.resources.dll" />
      <dependentAssembly>
          <assemblyIdentity name="Microsoft.Exchange.Data.ThrottlingService.Client.resources" publicKeyToken="31bf3856ad364e35" culture="hu" />
          <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\hu\Microsoft.Exchange.Data.ThrottlingService.Client.resources.dll" />
      <dependentAssembly>
          <assemblyIdentity name="Microsoft.Exchange.Data.ThrottlingService.Client.resources" publicKeyToken="31bf3856ad364e35" culture="id" />
          <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\id\Microsoft.Exchange.Data.ThrottlingService.Client.resources.dll" />
      <dependentAssembly>
          <assemblyIdentity name="Microsoft.Exchange.Data.ThrottlingService.Client.resources" publicKeyToken="31bf3856ad364e35" culture="is" />
          <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\is\Microsoft.Exchange.Data.ThrottlingService.Client.resources.dll" />
      <dependentAssembly>
          <assemblyIdentity name="Microsoft.Exchange.Data.ThrottlingService.Client.resources" publicKeyToken="31bf3856ad364e35" culture="it" />
          <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\it\Microsoft.Exchange.Data.ThrottlingService.Client.resources.dll" />
      <dependentAssembly>
          <assemblyIdentity name="Microsoft.Exchange.Data.ThrottlingService.Client.resources" publicKeyToken="31bf3856ad364e35" culture="ja" />
          <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\ja\Microsoft.Exchange.Data.ThrottlingService.Client.resources.dll" />
      <dependentAssembly>
          <assemblyIdentity name="Microsoft.Exchange.Data.ThrottlingService.Client.resources" publicKeyToken="31bf3856ad364e35" culture="kk" />
          <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\kk\Microsoft.Exchange.Data.ThrottlingService.Client.resources.dll" />
      <dependentAssembly>
          <assemblyIdentity name="Microsoft.Exchange.Data.ThrottlingService.Client.resources" publicKeyToken="31bf3856ad364e35" culture="ko" />
          <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\ko\Microsoft.Exchange.Data.ThrottlingService.Client.resources.dll" />
      <dependentAssembly>
          <assemblyIdentity name="Microsoft.Exchange.Data.ThrottlingService.Client.resources" publicKeyToken="31bf3856ad364e35" culture="lt" />
          <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\lt\Microsoft.Exchange.Data.ThrottlingService.Client.resources.dll" />
      <dependentAssembly>
          <assemblyIdentity name="Microsoft.Exchange.Data.ThrottlingService.Client.resources" publicKeyToken="31bf3856ad364e35" culture="lv" />
          <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\lv\Microsoft.Exchange.Data.ThrottlingService.Client.resources.dll" />
      <dependentAssembly>
          <assemblyIdentity name="Microsoft.Exchange.Data.ThrottlingService.Client.resources" publicKeyToken="31bf3856ad364e35" culture="ms" />
          <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\ms\Microsoft.Exchange.Data.ThrottlingService.Client.resources.dll" />
      <dependentAssembly>
          <assemblyIdentity name="Microsoft.Exchange.Data.ThrottlingService.Client.resources" publicKeyToken="31bf3856ad364e35" culture="no" />
          <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\no\Microsoft.Exchange.Data.ThrottlingService.Client.resources.dll" />
      <dependentAssembly>
          <assemblyIdentity name="Microsoft.Exchange.Data.ThrottlingService.Client.resources" publicKeyToken="31bf3856ad364e35" culture="nl" />
          <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\nl\Microsoft.Exchange.Data.ThrottlingService.Client.resources.dll" />
      <dependentAssembly>
          <assemblyIdentity name="Microsoft.Exchange.Data.ThrottlingService.Client.resources" publicKeyToken="31bf3856ad364e35" culture="pl" />
          <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\pl\Microsoft.Exchange.Data.ThrottlingService.Client.resources.dll" />
      <dependentAssembly>
          <assemblyIdentity name="Microsoft.Exchange.Data.ThrottlingService.Client.resources" publicKeyToken="31bf3856ad364e35" culture="pt" />
          <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\pt\Microsoft.Exchange.Data.ThrottlingService.Client.resources.dll" />
      <dependentAssembly>
          <assemblyIdentity name="Microsoft.Exchange.Data.ThrottlingService.Client.resources" publicKeyToken="31bf3856ad364e35" culture="pt-PT" />
          <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\pt-PT\Microsoft.Exchange.Data.ThrottlingService.Client.resources.dll" />
      <dependentAssembly>
          <assemblyIdentity name="Microsoft.Exchange.Data.ThrottlingService.Client.resources" publicKeyToken="31bf3856ad364e35" culture="ro" />
          <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\ro\Microsoft.Exchange.Data.ThrottlingService.Client.resources.dll" />
      <dependentAssembly>
          <assemblyIdentity name="Microsoft.Exchange.Data.ThrottlingService.Client.resources" publicKeyToken="31bf3856ad364e35" culture="ru" />
          <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\ru\Microsoft.Exchange.Data.ThrottlingService.Client.resources.dll" />
      <dependentAssembly>
          <assemblyIdentity name="Microsoft.Exchange.Data.ThrottlingService.Client.resources" publicKeyToken="31bf3856ad364e35" culture="sk" />
          <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\sk\Microsoft.Exchange.Data.ThrottlingService.Client.resources.dll" />
      <dependentAssembly>
          <assemblyIdentity name="Microsoft.Exchange.Data.ThrottlingService.Client.resources" publicKeyToken="31bf3856ad364e35" culture="sl" />
          <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\sl\Microsoft.Exchange.Data.ThrottlingService.Client.resources.dll" />
      <dependentAssembly>
          <assemblyIdentity name="Microsoft.Exchange.Data.ThrottlingService.Client.resources" publicKeyToken="31bf3856ad364e35" culture="sr" />
          <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\sr\Microsoft.Exchange.Data.ThrottlingService.Client.resources.dll" />
      <dependentAssembly>
          <assemblyIdentity name="Microsoft.Exchange.Data.ThrottlingService.Client.resources" publicKeyToken="31bf3856ad364e35" culture="sr-Latn-CS" />
          <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\sr-Latn-CS\Microsoft.Exchange.Data.ThrottlingService.Client.resources.dll" />
      <dependentAssembly>
          <assemblyIdentity name="Microsoft.Exchange.Data.ThrottlingService.Client.resources" publicKeyToken="31bf3856ad364e35" culture="sv" />
          <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\sv\Microsoft.Exchange.Data.ThrottlingService.Client.resources.dll" />
      <dependentAssembly>
          <assemblyIdentity name="Microsoft.Exchange.Data.ThrottlingService.Client.resources" publicKeyToken="31bf3856ad364e35" culture="th" />
          <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\th\Microsoft.Exchange.Data.ThrottlingService.Client.resources.dll" />
      <dependentAssembly>
          <assemblyIdentity name="Microsoft.Exchange.Data.ThrottlingService.Client.resources" publicKeyToken="31bf3856ad364e35" culture="tr" />
          <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\tr\Microsoft.Exchange.Data.ThrottlingService.Client.resources.dll" />
      <dependentAssembly>
          <assemblyIdentity name="Microsoft.Exchange.Data.ThrottlingService.Client.resources" publicKeyToken="31bf3856ad364e35" culture="uk" />
          <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\uk\Microsoft.Exchange.Data.ThrottlingService.Client.resources.dll" />
      <dependentAssembly>
          <assemblyIdentity name="Microsoft.Exchange.Data.ThrottlingService.Client.resources" publicKeyToken="31bf3856ad364e35" culture="ur" />
          <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\ur\Microsoft.Exchange.Data.ThrottlingService.Client.resources.dll" />
      <dependentAssembly>
          <assemblyIdentity name="Microsoft.Exchange.Data.ThrottlingService.Client.resources" publicKeyToken="31bf3856ad364e35" culture="vi" />
          <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\vi\Microsoft.Exchange.Data.ThrottlingService.Client.resources.dll" />
      <dependentAssembly>
          <assemblyIdentity name="Microsoft.Exchange.Data.ThrottlingService.Client.resources" publicKeyToken="31bf3856ad364e35" culture="zh-Hans" />
          <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\zh-Hans\Microsoft.Exchange.Data.ThrottlingService.Client.resources.dll" />
      <dependentAssembly>
          <assemblyIdentity name="Microsoft.Exchange.Data.ThrottlingService.Client.resources" publicKeyToken="31bf3856ad364e35" culture="zh-Hant" />
          <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\zh-Hant\Microsoft.Exchange.Data.ThrottlingService.Client.resources.dll" />
      <dependentAssembly>
          <assemblyIdentity name="Microsoft.Exchange.Data.ThrottlingService.Client.resources" publicKeyToken="31bf3856ad364e35" culture="zh-HK" />
          <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\zh-HK\Microsoft.Exchange.Data.ThrottlingService.Client.resources.dll" />
      <dependentAssembly>
        <assemblyIdentity name="Microsoft.Exchange.Data.Storage.ClientStrings.resources" publicKeyToken="31bf3856ad364e35" culture="ar" />
        <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\ar\Microsoft.Exchange.Data.Storage.ClientStrings.resources.dll" />
      <dependentAssembly>
        <assemblyIdentity name="Microsoft.Exchange.Data.Storage.ClientStrings.resources" publicKeyToken="31bf3856ad364e35" culture="bg" />
        <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\bg\Microsoft.Exchange.Data.Storage.ClientStrings.resources.dll" />
      <dependentAssembly>
        <assemblyIdentity name="Microsoft.Exchange.Data.Storage.ClientStrings.resources" publicKeyToken="31bf3856ad364e35" culture="ca" />
        <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\ca\Microsoft.Exchange.Data.Storage.ClientStrings.resources.dll" />
      <dependentAssembly>
        <assemblyIdentity name="Microsoft.Exchange.Data.Storage.ClientStrings.resources" publicKeyToken="31bf3856ad364e35" culture="cs" />
        <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\cs\Microsoft.Exchange.Data.Storage.ClientStrings.resources.dll" />
      <dependentAssembly>
        <assemblyIdentity name="Microsoft.Exchange.Data.Storage.ClientStrings.resources" publicKeyToken="31bf3856ad364e35" culture="da" />
        <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\da\Microsoft.Exchange.Data.Storage.ClientStrings.resources.dll" />
      <dependentAssembly>
        <assemblyIdentity name="Microsoft.Exchange.Data.Storage.ClientStrings.resources" publicKeyToken="31bf3856ad364e35" culture="de" />
        <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\de\Microsoft.Exchange.Data.Storage.ClientStrings.resources.dll" />
      <dependentAssembly>
        <assemblyIdentity name="Microsoft.Exchange.Data.Storage.ClientStrings.resources" publicKeyToken="31bf3856ad364e35" culture="el" />
        <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\el\Microsoft.Exchange.Data.Storage.ClientStrings.resources.dll" />
      <dependentAssembly>
        <assemblyIdentity name="Microsoft.Exchange.Data.Storage.ClientStrings.resources" publicKeyToken="31bf3856ad364e35" culture="en" />
        <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\en\Microsoft.Exchange.Data.Storage.ClientStrings.resources.dll" />
      <dependentAssembly>
        <assemblyIdentity name="Microsoft.Exchange.Data.Storage.ClientStrings.resources" publicKeyToken="31bf3856ad364e35" culture="en-AU" />
        <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\en-AU\Microsoft.Exchange.Data.Storage.ClientStrings.resources.dll" />
      <dependentAssembly>
        <assemblyIdentity name="Microsoft.Exchange.Data.Storage.ClientStrings.resources" publicKeyToken="31bf3856ad364e35" culture="en-CA" />
        <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\en-CA\Microsoft.Exchange.Data.Storage.ClientStrings.resources.dll" />
      <dependentAssembly>
        <assemblyIdentity name="Microsoft.Exchange.Data.Storage.ClientStrings.resources" publicKeyToken="31bf3856ad364e35" culture="en-GB" />
        <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\en-GB\Microsoft.Exchange.Data.Storage.ClientStrings.resources.dll" />
      <dependentAssembly>
        <assemblyIdentity name="Microsoft.Exchange.Data.Storage.ClientStrings.resources" publicKeyToken="31bf3856ad364e35" culture="en-IN" />
        <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\en-IN\Microsoft.Exchange.Data.Storage.ClientStrings.resources.dll" />
      <dependentAssembly>
        <assemblyIdentity name="Microsoft.Exchange.Data.Storage.ClientStrings.resources" publicKeyToken="31bf3856ad364e35" culture="es" />
        <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\es\Microsoft.Exchange.Data.Storage.ClientStrings.resources.dll" />
      <dependentAssembly>
        <assemblyIdentity name="Microsoft.Exchange.Data.Storage.ClientStrings.resources" publicKeyToken="31bf3856ad364e35" culture="es-MX" />
        <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\es-MX\Microsoft.Exchange.Data.Storage.ClientStrings.resources.dll" />
      <dependentAssembly>
        <assemblyIdentity name="Microsoft.Exchange.Data.Storage.ClientStrings.resources" publicKeyToken="31bf3856ad364e35" culture="et" />
        <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\et\Microsoft.Exchange.Data.Storage.ClientStrings.resources.dll" />
      <dependentAssembly>
        <assemblyIdentity name="Microsoft.Exchange.Data.Storage.ClientStrings.resources" publicKeyToken="31bf3856ad364e35" culture="eu" />
        <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\eu\Microsoft.Exchange.Data.Storage.ClientStrings.resources.dll" />
      <dependentAssembly>
        <assemblyIdentity name="Microsoft.Exchange.Data.Storage.ClientStrings.resources" publicKeyToken="31bf3856ad364e35" culture="fa" />
        <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\fa\Microsoft.Exchange.Data.Storage.ClientStrings.resources.dll" />
      <dependentAssembly>
        <assemblyIdentity name="Microsoft.Exchange.Data.Storage.ClientStrings.resources" publicKeyToken="31bf3856ad364e35" culture="fi" />
        <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\fi\Microsoft.Exchange.Data.Storage.ClientStrings.resources.dll" />
      <dependentAssembly>
        <assemblyIdentity name="Microsoft.Exchange.Data.Storage.ClientStrings.resources" publicKeyToken="31bf3856ad364e35" culture="fil-PH" />
        <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\fil-PH\Microsoft.Exchange.Data.Storage.ClientStrings.resources.dll" />
      <dependentAssembly>
        <assemblyIdentity name="Microsoft.Exchange.Data.Storage.ClientStrings.resources" publicKeyToken="31bf3856ad364e35" culture="fr" />
        <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\fr\Microsoft.Exchange.Data.Storage.ClientStrings.resources.dll" />
      <dependentAssembly>
        <assemblyIdentity name="Microsoft.Exchange.Data.Storage.ClientStrings.resources" publicKeyToken="31bf3856ad364e35" culture="fr-CA" />
        <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\fr-CA\Microsoft.Exchange.Data.Storage.ClientStrings.resources.dll" />
      <dependentAssembly>
        <assemblyIdentity name="Microsoft.Exchange.Data.Storage.ClientStrings.resources" publicKeyToken="31bf3856ad364e35" culture="gl" />
        <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\gl\Microsoft.Exchange.Data.Storage.ClientStrings.resources.dll" />
      <dependentAssembly>
        <assemblyIdentity name="Microsoft.Exchange.Data.Storage.ClientStrings.resources" publicKeyToken="31bf3856ad364e35" culture="he" />
        <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\he\Microsoft.Exchange.Data.Storage.ClientStrings.resources.dll" />
      <dependentAssembly>
        <assemblyIdentity name="Microsoft.Exchange.Data.Storage.ClientStrings.resources" publicKeyToken="31bf3856ad364e35" culture="hi" />
        <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\hi\Microsoft.Exchange.Data.Storage.ClientStrings.resources.dll" />
      <dependentAssembly>
        <assemblyIdentity name="Microsoft.Exchange.Data.Storage.ClientStrings.resources" publicKeyToken="31bf3856ad364e35" culture="hr" />
        <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\hr\Microsoft.Exchange.Data.Storage.ClientStrings.resources.dll" />
      <dependentAssembly>
        <assemblyIdentity name="Microsoft.Exchange.Data.Storage.ClientStrings.resources" publicKeyToken="31bf3856ad364e35" culture="hu" />
        <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\hu\Microsoft.Exchange.Data.Storage.ClientStrings.resources.dll" />
      <dependentAssembly>
        <assemblyIdentity name="Microsoft.Exchange.Data.Storage.ClientStrings.resources" publicKeyToken="31bf3856ad364e35" culture="id" />
        <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\id\Microsoft.Exchange.Data.Storage.ClientStrings.resources.dll" />
      <dependentAssembly>
        <assemblyIdentity name="Microsoft.Exchange.Data.Storage.ClientStrings.resources" publicKeyToken="31bf3856ad364e35" culture="is" />
        <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\is\Microsoft.Exchange.Data.Storage.ClientStrings.resources.dll" />
      <dependentAssembly>
        <assemblyIdentity name="Microsoft.Exchange.Data.Storage.ClientStrings.resources" publicKeyToken="31bf3856ad364e35" culture="it" />
        <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\it\Microsoft.Exchange.Data.Storage.ClientStrings.resources.dll" />
      <dependentAssembly>
        <assemblyIdentity name="Microsoft.Exchange.Data.Storage.ClientStrings.resources" publicKeyToken="31bf3856ad364e35" culture="ja" />
        <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\ja\Microsoft.Exchange.Data.Storage.ClientStrings.resources.dll" />
      <dependentAssembly>
        <assemblyIdentity name="Microsoft.Exchange.Data.Storage.ClientStrings.resources" publicKeyToken="31bf3856ad364e35" culture="kk" />
        <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\kk\Microsoft.Exchange.Data.Storage.ClientStrings.resources.dll" />
      <dependentAssembly>
        <assemblyIdentity name="Microsoft.Exchange.Data.Storage.ClientStrings.resources" publicKeyToken="31bf3856ad364e35" culture="ko" />
        <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\ko\Microsoft.Exchange.Data.Storage.ClientStrings.resources.dll" />
      <dependentAssembly>
        <assemblyIdentity name="Microsoft.Exchange.Data.Storage.ClientStrings.resources" publicKeyToken="31bf3856ad364e35" culture="lt" />
        <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\lt\Microsoft.Exchange.Data.Storage.ClientStrings.resources.dll" />
      <dependentAssembly>
        <assemblyIdentity name="Microsoft.Exchange.Data.Storage.ClientStrings.resources" publicKeyToken="31bf3856ad364e35" culture="lv" />
        <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\lv\Microsoft.Exchange.Data.Storage.ClientStrings.resources.dll" />
      <dependentAssembly>
        <assemblyIdentity name="Microsoft.Exchange.Data.Storage.ClientStrings.resources" publicKeyToken="31bf3856ad364e35" culture="ms" />
        <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\ms\Microsoft.Exchange.Data.Storage.ClientStrings.resources.dll" />
      <dependentAssembly>
        <assemblyIdentity name="Microsoft.Exchange.Data.Storage.ClientStrings.resources" publicKeyToken="31bf3856ad364e35" culture="no" />
        <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\no\Microsoft.Exchange.Data.Storage.ClientStrings.resources.dll" />
      <dependentAssembly>
        <assemblyIdentity name="Microsoft.Exchange.Data.Storage.ClientStrings.resources" publicKeyToken="31bf3856ad364e35" culture="nl" />
        <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\nl\Microsoft.Exchange.Data.Storage.ClientStrings.resources.dll" />
      <dependentAssembly>
        <assemblyIdentity name="Microsoft.Exchange.Data.Storage.ClientStrings.resources" publicKeyToken="31bf3856ad364e35" culture="pl" />
        <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\pl\Microsoft.Exchange.Data.Storage.ClientStrings.resources.dll" />
      <dependentAssembly>
        <assemblyIdentity name="Microsoft.Exchange.Data.Storage.ClientStrings.resources" publicKeyToken="31bf3856ad364e35" culture="pt" />
        <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\pt\Microsoft.Exchange.Data.Storage.ClientStrings.resources.dll" />
      <dependentAssembly>
        <assemblyIdentity name="Microsoft.Exchange.Data.Storage.ClientStrings.resources" publicKeyToken="31bf3856ad364e35" culture="pt-PT" />
        <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\pt-PT\Microsoft.Exchange.Data.Storage.ClientStrings.resources.dll" />
      <dependentAssembly>
        <assemblyIdentity name="Microsoft.Exchange.Data.Storage.ClientStrings.resources" publicKeyToken="31bf3856ad364e35" culture="ro" />
        <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\ro\Microsoft.Exchange.Data.Storage.ClientStrings.resources.dll" />
      <dependentAssembly>
        <assemblyIdentity name="Microsoft.Exchange.Data.Storage.ClientStrings.resources" publicKeyToken="31bf3856ad364e35" culture="ru" />
        <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\ru\Microsoft.Exchange.Data.Storage.ClientStrings.resources.dll" />
      <dependentAssembly>
        <assemblyIdentity name="Microsoft.Exchange.Data.Storage.ClientStrings.resources" publicKeyToken="31bf3856ad364e35" culture="sk" />
        <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\sk\Microsoft.Exchange.Data.Storage.ClientStrings.resources.dll" />
      <dependentAssembly>
        <assemblyIdentity name="Microsoft.Exchange.Data.Storage.ClientStrings.resources" publicKeyToken="31bf3856ad364e35" culture="sl" />
        <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\sl\Microsoft.Exchange.Data.Storage.ClientStrings.resources.dll" />
      <dependentAssembly>
        <assemblyIdentity name="Microsoft.Exchange.Data.Storage.ClientStrings.resources" publicKeyToken="31bf3856ad364e35" culture="sr" />
        <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\sr\Microsoft.Exchange.Data.Storage.ClientStrings.resources.dll" />
      <dependentAssembly>
        <assemblyIdentity name="Microsoft.Exchange.Data.Storage.ClientStrings.resources" publicKeyToken="31bf3856ad364e35" culture="sr-Cyrl-CS" />
        <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\sr-Cyrl-CS\Microsoft.Exchange.Data.Storage.ClientStrings.resources.dll" />
      <dependentAssembly>
        <assemblyIdentity name="Microsoft.Exchange.Data.Storage.ClientStrings.resources" publicKeyToken="31bf3856ad364e35" culture="sr-Latn-CS" />
        <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\sr-Latn-CS\Microsoft.Exchange.Data.Storage.ClientStrings.resources.dll" />
      <dependentAssembly>
        <assemblyIdentity name="Microsoft.Exchange.Data.Storage.ClientStrings.resources" publicKeyToken="31bf3856ad364e35" culture="sv" />
        <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\sv\Microsoft.Exchange.Data.Storage.ClientStrings.resources.dll" />
      </dependentAssembly>
      <dependentAssembly>
        <assemblyIdentity name="Microsoft.Exchange.Data.Storage.ClientStrings.resources" publicKeyToken="31bf3856ad364e35" culture="th" />
        <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\th\Microsoft.Exchange.Data.Storage.ClientStrings.resources.dll" />
      <dependentAssembly>
        <assemblyIdentity name="Microsoft.Exchange.Data.Storage.ClientStrings.resources" publicKeyToken="31bf3856ad364e35" culture="tr" />
        <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\tr\Microsoft.Exchange.Data.Storage.ClientStrings.resources.dll" />
      <dependentAssembly>
        <assemblyIdentity name="Microsoft.Exchange.Data.Storage.ClientStrings.resources" publicKeyToken="31bf3856ad364e35" culture="uk" />
        <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\uk\Microsoft.Exchange.Data.Storage.ClientStrings.resources.dll" />
      <dependentAssembly>
        <assemblyIdentity name="Microsoft.Exchange.Data.Storage.ClientStrings.resources" publicKeyToken="31bf3856ad364e35" culture="ur" />
        <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\ur\Microsoft.Exchange.Data.Storage.ClientStrings.resources.dll" />
      <dependentAssembly>
        <assemblyIdentity name="Microsoft.Exchange.Data.Storage.ClientStrings.resources" publicKeyToken="31bf3856ad364e35" culture="vi" />
        <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\vi\Microsoft.Exchange.Data.Storage.ClientStrings.resources.dll" />
      <dependentAssembly>
        <assemblyIdentity name="Microsoft.Exchange.Data.Storage.ClientStrings.resources" publicKeyToken="31bf3856ad364e35" culture="zh-Hans" />
        <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\zh-Hans\Microsoft.Exchange.Data.Storage.ClientStrings.resources.dll" />
      <dependentAssembly>
        <assemblyIdentity name="Microsoft.Exchange.Data.Storage.ClientStrings.resources" publicKeyToken="31bf3856ad364e35" culture="zh-Hant" />
        <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\zh-Hant\Microsoft.Exchange.Data.Storage.ClientStrings.resources.dll" />
      <dependentAssembly>
        <assemblyIdentity name="Microsoft.Exchange.Data.Storage.ClientStrings.resources" publicKeyToken="31bf3856ad364e35" culture="zh-HK" />
        <codeBase version="14.0.0.0" href="file:///C:\Program Files\Microsoft\Exchange Server\V14\bin\zh-HK\Microsoft.Exchange.Data.Storage.ClientStrings.resources.dll" />
    </assemblyBinding>
  </runtime>
</configuration>
endital1097Commented:
check the basic settings for your powershell vdir
the physical path should be
c:\Program Files\Microsoft\Exchange Server\v14\ClientAccess\PowerShell
sibensibenAuthor Commented:
it is
can you start the exchange management console?
also check (as someone fixed by installing)
Server Manager -> Features -> Selected WinRM IIS Extension is installed
did a couple of things now when browsing through ssl i get
Server Error in '/PowerShell' Application.
Configuration Error
Description: An error occurred during the processing of a configuration file required to service this request. Please review the specific error details below and modify your configuration file appropriately.
Parser Error Message: It is an error to use a section registered as allowDefinition='MachineToApplication' beyond application level.  This error can be caused by a virtual directory not being configured as an application in IIS.
Source Error:
Line 38:   </system.webServer>
Line 39:   <system.web>
Line 40:     <authentication mode="Windows" />
Line 41:     <compilation debug="true">
Line 42:       <assemblies>
Source File: C:\Program Files\Microsoft\Exchange Server\V14\ClientAccess\PowerShell\web.config    Line: 40
it would be really beneficial to know if you can launch the management shell :)
you should not have access to the poweshell vdir using IE, 401 is an expected response
if we can verify the management shell launches, then the issue is not related to the powershell vdir anymore (which i don't think it is)
no EMC will not connect... same 500 error as above
winrm is installed and working whoever posted that
my main goal here is to get EMC working as I cannot administer the exchange server.....
THANKS AGAIN
i understand your goal, but we need to isolate the issue
please post whether the management shell opens
it opens but when you go to connect to exchange you get the 500 error
i thought i posted this already but maybe i am losing it (LOL)
can you post a screen shot?
i posted a screen shot see above
i saw that article last week that variable is set... thanks
here is the screenshot in emc again
i was hoping to see a screenshot of hte management shell
did you try installing the WinRM IIS Extension feature
winrm is installed and i ran winrm qc and it said it was up and running
this is an additional feature, not installed by default
hte shell ???? are you asking me if windows powershell launches ???  Yes if that is the question.
great, then we just need to focus on winrm
check in server manager and see if the WinRM IIS Extension feature is installed
if not, please add it
let me know where to access that install from it is not under features so i assume it is a third party shell
winrm is installed and operational...... the only thing that seems to be broken is the link to powershell from emc.
select add features
dude this is installed are you getting any of my posts ?
once again winrm seems to be working
ws-management service is working...
EMC 2010 NOT WORKING... getting the 500 error connecting to powershell..... (SEE SCREENSHOTS)
thanks
the try open the exhange management shell and run the following
Get-PowerShellVirtualDirectory
Remove-PowerShellVirtualDirectory <result from above>
New-PowerShellVirtualDirectory -Name Powershell -WebSiteName "Default Web Site"
getting the same 500 error on the shell hence it will not let me run the cmdlet
verify all services are started
do you have the windows firewall enabled? disable temporarily if you do
verified services and tried firewall....
ran through that entire article last week
ok, try the following from the exchange server
winrm e winrm/config/listener
Winrm id
winrm get winrm/config
winrm get wmicimv2/Win32_Service?Name=WinRM
were you able to test winrm with those commands
going to try now
i'm going to try to find another ee for input, he's been out for a few days
see shot
you misspelled config
should that read port 5905 or is this the issue ?
my environment returned nothing
checking another
both returned nothing
do you have any antivirus software running on the server?
if so, can you disable and reboot
hold on... i think i found it
remove the feature we talked about adding earlier
remove WinRM IIS Extension
http://207.46.16.252/en-us/library/ff859467(EXCHG.80).aspx
i removed it and readded it several times
we only want to remove this one feature, it is causing winrm to listen on a port that breaks exchange
did u read that article ??
exchange was installed already the emc worked until they did an exchange rollup and some other installs  winrm is needed  that isnt it
i did, did you?
After you install WinRM-IIS-Ext on a computer on which Exchange Server 2010 is installed, you may receive one of the following error messages when you try to use the Exchange Management Shell (EMS) or the Exchange Management Console (EMC):
The requested HTTP URL was not available.
HTTP server error status (500).
The connection to the specified remote host was refused.
HTTP status code of 403.
It cannot determine the content type of the HTTP response from the destination computer.
if you decide to remove, you most likely want to restart the server to refresh the services
i have to call it a night
i will remove but i tried this already
ok he just reminded me i did this today with same results
bu the way that is not the message I am getting there is no 403... check my screen shot... this was not the answer I went back and deinstalled it and rebooted server
same exact thing....
I am leaning toward a powershell vdir issue
I am at a loss here.... we are crippled
there should really be an alternative to emc
you can delete the vdir from iis manager for powershell
then recreate with the steps
right-click on default web site and select add application
Alias = Powershell
Application pool = MSExchangePowerShellAppPool
Physical path = C:\Program Files\Microsoft\Exchange Server\V14\ClientAccess\PowerShell
did that.... no change
i sill think it is the results from your winrm test
can you run the test again after the uninstall to see if anything changed
what results from the winrm test are in question... the only thing i saw strange about it was the http port and https port it said winrm was listening on... can that be changed to 80 and 443 ?
i checked the results on two unique exchange 2010 environments and both did not return any results for that command
i'm looking into how we can update this
let's delete the listener
WinRM delete winrm/config/listener
i noticed that when i ran the winrm get winrm/config command that  EnableCompatibilityHttpListener = False
any significance ?
Config
    MaxEnvelopeSizekb = 150
    MaxTimeoutms = 60000
    MaxBatchItems = 32000
    MaxProviderRequests = 4294967295
    Client
        NetworkDelayms = 5000
        URLPrefix = wsman
        AllowUnencrypted = false
        Auth
            Basic = true
            Digest = true
            Kerberos = true
            Negotiate = true
            Certificate = true
            CredSSP = false
        DefaultPorts
            HTTP = 5985
            HTTPS = 5986
        TrustedHosts
    Service
        RootSDDL = O:NSG:BAD:P(A;;GA;;;BA)S:P(AU;FA;GA;;;WD)(AU;SA;GWGX;;;WD)
        MaxConcurrentOperations = 4294967295
        MaxConcurrentOperationsPerUser = 15
        EnumerationTimeoutms = 60000
        MaxConnections = 25
        MaxPacketRetrievalTimeSeconds = 120
        Auth
            Basic = false
            Kerberos = true
            Negotiate = true
            Certificate = false
            CredSSP = false
            CbtHardeningLevel = Relaxed
        DefaultPorts
            HTTP = 5985
            HTTPS = 5986
        IPv4Filter = *
        IPv6Filter = *
        EnableCompatibilityHttpListener = false
        EnableCompatibilityHttpsListener = false
        CertificateThumbprint
    Winrs
        AllowRemoteShellAccess = true
        IdleTimeout = 180000
        MaxConcurrentUsers = 5
        MaxShellRunTime = 2147483647
        MaxProcessesPerShell = 15
        MaxMemoryPerShellMB = 150
        MaxShellsPerUser = 5
looks identical... so this is not it i am guessing
did you remove the listener?
says it cannot delete because it requires following selectors address transport
any ideas ??
have we given up ??
northja69Commented:
I have the same issue, do we have a resolution? I tried to run SP1 for exchange and broke the EMC and powershell (same as above)
We ended up redoing the entire server after weeks of no resolution
northja69Commented:
So I found the resolution and here are the steps.  I know it's a little late, since you rebult the server, but if others are looking for the solution, here is what worked for me.
1) I deleted the powershell VirDir in IIS Manually
2) uninstalled WinRM-IIS-Ext (in Features and than reinstalled it
3) recreated the Vir Powershell
Alias = Powershell
4) Unchecked () Required SSL for that VirDir
5) Right clicked on the VIrDir and Clicked Make into an Application (which will make the icon of that VirDir look like a World again
6) Copied the attached Web.Config to the Powershell Dir (Listed above) Make sure to back up the old one
7) Reboot the server
8) Start up Exchange Powershell to make sure that you have no Errors in the PS app and that it signs on to the Domain within powershell with no issues
9) After you have no issues powering up the exchange powershell start exchange EMC and it WORKS
northja69Commented:
Here is the file
web.config
ee_autoCommented:
Question PAQ'd and stored in the solution database.
Join & Write a Comment
Has Powershell sent you back into the Stone Age?
If managing Active Directory using Windows Powershell® is making you feel like you stepped back in time, you are not alone.  For nearly 20 years, AD admins around the world have used one tool for day-to-day AD management: Hyena. Discover why.
  • 51
  • 42
  • 3
  • +1
