Clownie669
Intel S5000VSA won't POST -- System Status LED flashing green -- PSU LED solid red
My customer's Server recently stopped POSTing.
It has been working for a few years prior to this issue
The motherboard is an Intel S5000VSA w/ an SC5299BRP chassis
When the server is plugged in:
- the server enables standby / diagnostic mode
- the PSU fan turns on - the top led turns solid green
- the 4th front indicator LED from the top (triangle w/ an exclamation point inside) briefly flashes green & red then turns solid green
- the system status LED (upper left most portion of the motherboard - under the PS/2 connectors) briefly flashes yellow & green then turns solid green
When I push the power button on the front:
- the system doesn't start up
- the 1st PSU LED that was green turns off - the 2nd PSU LED that was off turns red
- after a brief period, the 4th front indicator LED that was solid green starts flashing green
- the system status LED also flashes green
I've currently stripped the Server to the core hardware - CPU, 1 stick of RAM, PSU, motherboard.
I've tried all 3 Memory DIMMs separately.
Sadly, the first time I did this earlier, the Server did boot. It continued to boot with all the other hardware included, until I added the case fan, then it reverted back to this issue.
I tried using a different case fan, and then removed all the additional hardware. It hasn't booted since.
Does anyone know what's causing this?
Thanks!
CORE HARDWARE SPECS:
Intel S5000VSA Motherboard
Intel SC5299BRP Chassis
HIPRO HP-Q6100XC 610W Power Supply
Xeon CPU (don't know the exact model) in Processor 1 socket
Processor 2 socket empty
Intel socket 771 stock Heatsink / Fan
4GB Kingston PC2-5300F DDR2-667 ECC Fully Buffered Memory (1 2GB DIMM, 2 1GB DIMMs)
Thanks!
Thanks for responding so quickly.
I don't have another Server PSU to test. I have an OCZ 600W Consumer PSU. It has the 24-pin and dual 4-pin connectors that are on this board. Could that be used for testing?
The caps on the motherboard appear undamaged.
The motherboard does not beep when I turn it on w/ no memory installed.
I removed the battery about 50min ago.
Removing the battery didn't work. Same issue.
Actually the issue has changed. When I push the power button, the 2 LEDs on the PSU still turn from green to red; but the 4th front indicator LED on the case, and system status LED on the motherboard, that were flashing green, now stay solid green.
Sorry for not responding sooner. Sick.
Burrcm's last solution was correct. I used a power supply tester on the server PSU, and it didn't work.
I tested my OCZ PSU in the server and it booted right up. In fact, it's been running on it since Monday.
Should be fine until a replacement can be ordered.
Thanks again!
Thanks again!
Chris B
