help getting Xserver and VNC server running on Solaris 10 after power issue
paige386
paige386 used Ask the Experts™
on
Recently had a power failure and our Xterm and Vnc server seem to have stopped working I only have telnet access to box at the moment.
Watch Question
Do more with
Expert Office
Have you try to reboot the box?
you can try:
svcadm restart inetd
to see if it work.
If not manually start the Xserver (dtlogin), see the following doc:
http://saifulaziz.wordpress.com/2009/04/03/solaris-10-remote-x11-or-cde-login-problem/
then restart the VNC server.
If your VNC is not in SMF, have a look at the following doc to fix it:
http://birijan.com.np/?q=vnc+on+solaris+10
I have the java console back up and running but VNC is still hosed.
I think this is using the Sun VNC software as it is located in /opt/sfw/vnc
when I try connecting to the server with realvnc   ipaddress:1.0  I get connection refused
Turned out there was an extra entry in the Xservers file that was overiding the VNC entry that was there.
Thanks for trying.
Do more with
Expert Office
Start 7-Day Free Trial
