Reference a Class Library from another Class Library in a Solution with 3 projects
I've downloaded the Cassini souce code and modified it.  Built the project in "release" mode.  In another solution, which contains 2 exe's and a class library, I'm referencing the Cassini dll I just built by the Class library.
Everything compiles without any errors, but as soon as I run the solution (by double clicking the EXE), I get an error that it can't load the Cassini Assembly because the file cannot be found.  I've tried cleaning the solutions and rebuilding them but still no luck.  The only way I seem to be able to get it to work is to remove my reference to my custom Cassini build and instead reference Cassini from the GAC.
What gives?  I've referenced custom dll's a million times before and never had any issues.
davidcahan
davidcahan
  • 4
  • 3
AshokCommented:
Which Class Library has a reference to other Class Library?
If ClassLibrary2 has reference, add DLL in the bin folder of ClassLibrary2.
HTH
Ashok
davidcahanAuthor Commented:
Sorry, that doesn't help. This is a client app. There isn't a bin folder. I've tried just about every obvious thing I could try
AshokCommented:
Try adding dll to the PATH (Environment Variable).
HTH
Ashok
Cloud Class® Course: CompTIA Cloud+
The CompTIA Cloud+ Basic training course will teach you about cloud concepts and models, data storage, networking, and network infrastructure.
AshokCommented:
You can use (dependentAssembly and codeBase) entries in
App.Config to tell the application where to look for its Dll's.
I am not sure exactly what you have to add in App.Config right now.
HTH
Ashok
AshokCommented:
Here is sample.....
      <dependentAssembly>
        <assemblyIdentity name="ConsoleDLL"
                          publicKeyToken="[token]"
                          culture="neutral"/>
        <bindingRedirect oldVersion="[oldversion]"
                         newVersion="[newversion]" />
        <codeBase version="[newversion]"  href="file:///c:\bin\ConsoleDLL.dll" />
      </dependentAssembly>
HTH
Ashok
Was able to get it working.  Turns out that Cassini has to be registered in the GAC EXCEPT if you do the following:
1) reference your custom cassini.dll in your .NET project
2)build your project
3)install/move your project onto the client machine
4)copy Cassini.dll into the bin folder of your webroot
so, you have to have your cassini.dll in your client app folder and in the bin folder of your web root.  if there is no bin folder you have to create one and drop cassini into it.
figured it out myself
Join & Write a Comment
Cloud Class® Course: Certified Penetration Testing
This CPTE Certified Penetration Testing Engineer course covers everything you need to know about becoming a Certified Penetration Testing Engineer. Career Path: Professional roles include Ethical Hackers, Security Consultants, System Administrators, and Chief Security Officers.
  • 4
  • 3
