Solved
Cisco wireless lan controller model 4402 using 9 LWAP with 5ghz antennas
Posted on 2010-11-16
8
Last Modified: 2012-05-10
I have a Cisco wireless lan controller model 4402 using 9 LWAP with 5ghz antennas I'm looking into how lo limit the amount of users each LWAP can attach for large group load balancing?
Question by:IU1ADMIN
  • 4
  • 4
8 Comments
Author Comment
by:IU1ADMIN
Any help is great!
LVL 4
Accepted Solution
by:
jhclemente earned 2000 total points
Go to Wireless -> 802.11a -> RRM -> General
In Clients, configure the amount you want.
In older versions, I remember there was an aggressive load balancing option in Controller section. I can't find it in version 7.
You can try, via telnet/ssh this command:
    config load-balancing window <client_count>
Author Comment
by:IU1ADMIN
Thanks I found that but I can count 22 connections on 1 LWAP and the limit is set to 12??
I do have the aggressive load balancing disabled. Do I need enable it to stop the connections from exceeding the value set??
Evaluating UTMs? Here's what you need to know!
Evaluating a UTM appliance and vendor can prove to be an overwhelming exercise.  How can you make sure that you're getting the security that your organization needs without breaking the bank? Check out our UTM Buyer's Guide for more information on what you should be looking for!
LVL 4
Assisted Solution
by:jhclemente
Yes, you need to disable it.
However, I must say you, it's not always recommended. It depends of your coverage and client distribution (physical location with respect to AP) for your balancing to work without affecting clients service.
LVL 4
Assisted Solution
by:jhclemente
Sorry.... to enable it
Author Comment
by:IU1ADMIN
OK....I should enable??
LVL 4
Assisted Solution
by:jhclemente
You can enable it and test how this works.
If you have problems in the future (clients disconnection or not connecting), the fist thing to check is precisely that option.
Author Comment
by:IU1ADMIN
Thanks again I will test it out
What is SQL Server and how does it work?
The purpose of this paper is to provide you background on SQL Server. It’s your self-study guide for learning fundamentals. It includes both the history of SQL and its technical basics. Concepts and definitions will form the solid foundation of your future DBA expertise.
In this article I will describe how to setup a Cisco WLC 5508 to work with Apple's Bonjour protocol across VLANs.  I will also discuss using screen mirroring and Airplay on an AppleTV v3.  This article covers the wireless network only and requires m…
In this article we have discussed about the OS X EI Capitan and how to fix Wi-Fi issue in OS X El Capitan. We have explained how to delete system level preferences and create a new Wi-Fi location to resolve Wi-Fi issue.
This Micro Tutorial will show you how to maximize your wireless card to its maximum capability. This will be demonstrated using Intel(R) Centrino(R) Wireless-N 2230 wireless card on Windows 8 operating system.
Viewers will learn how to connect to a wireless network using the network security key. They will also learn how to access the IP address and DNS server for connections that must be done manually. After setting up a router, find the network security…
Suggested Courses
581 members asked questions and received personalized solutions in the past 7 days.
Join & Ask a Question
